Question about Hotpoint Ultima WF860 Front Load Washer
Machine doesn't recognize door is closed
My Hotpoint Ultima 1000 keeps telling me the door is not closed properly when clearly it is. I've tried taking the door off and re-fixing it but to no avail. Any ideas?
    Problem Solver:
  • 6 Answers
Open the door, and look closely at any little plastic latches to see if a small part hasn't busted off.
They usually have plastic prongs that tell a small switch inside the hole it goes into, that the door is shut. It's a toughie.
I'd google around for it. Use the talking marks " ". Like google something like "Ultima 1000" space "door won't close" or 'dryer' 'door won't close'.
That will bring up dozens of other people who've asked questions to OTHER sites.
Tried holding it shut? DOes it work when you stand there? You could tape it with gaffer tape.
Methinks, its a latch problem, something's busted off.
Posted on Feb 11, 2009
Hotpoint wf840 not starting
Machine may not be finding the signal from the door interlock, check the wire connections to it.
Dec 29, 2012 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima extra washing machine, door open sign flashing on lacd display even though the door is closed properly
first check all connections on circuit board are tight if ok change interlock,if problem still persists you have a circuit board fault which could have been caused by blown interlock
Sep 08, 2011 | Hotpoint Washing Machines
My Ultima condenser dryer keeps cutting out after 7-8mins of running. Ia this an overheating fault? How can I fix? Lawrence
have you cleaned all the filters so that it can work properly also are you over loading it. and the machine might be to close to the back wall hope this helps.
Nov 08, 2009 | Hotpoint Ultima WF860 Front Load Washer
Outlet Pipe
Your machine has detected a problem with draining. The place to check is the filter located at rear of machine.To access it remove plate at bottom rear of machine & you will see a black pipe hanging vertically from the drum secured by a spring clip.The filter is in this pipe. If this is clear take off other end & check pump is not obstructed.Be aware that there will be water in these pipes so may be wise to take machine outside.Let me know if problem persists.
Nov 18, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima wt741
f11 keeps flashing door won't open
Sep 01, 2008 | Hotpoint Ultima WF860 Front Load Washer
My hotpoint ultima plus washing machine door wont open after wash
Hi,I have a 2nd hand Hotpoint Ultima digital washing machine & cant seem to use it as when i turn it on on display screen the childlock icon flashes & beeps,even when door is open/closed,when i select a programme the icon still flashes & beeps therefore i cannot use machine.hope you can help me with my question Thanks.GILLI37
Apr 14, 2008 | Washing Machines
Hotpoint WF860
when the machine was flashing door this was telling you that either the door was not shut properly, try it again, or the interlock switch was faulty, chances are its probably shorted out and blown the circuit board, take care and remove the board to check for signs of blowing, if no signs then i would replace the interlock and start from there, ps i am a retired engineer and have had the same machine myself
Sep 30, 2007 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima washer dryer
isolate from mains. undo door gasket and check interlock id ok. interlock is mounted on cabinet on rhs
Mar 11, 2007 | Hotpoint Ultima WD72 Front Load...
Hotpoint Ultima WF860 Front Load Washer Logo
203 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
