Question about iRiver X20 MP3 Player
My iriver X20 has frozen...
After adding some music to my iriver X20, it froze on the blue initializing screen, saying it was 'building library'.
the solution is supposed to be that you hold down the menu button and then the power button, so you can reformat it. i've tried this, but it still won't work. is there anything else i can do?
help!
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
If you have a micro SD inserted, try removing that and/or formatting said memory using a memory card reader with your PC. If the iRiver does not have an external memory and is using solely its built-in memory, then chances are that the firmware has been corrupted. Try:
  • connect to your computer using the UMS mode (hold down the "o" button and turn it on);
  • the PC should read it as an exterbal storage device/Hard Drive;
  • right click on it and click format, click quickformat.
  • reload the firmware using the firmware upgrader program
Good luck and thank you for using FixYa.
Posted on Feb 22, 2009
    President:
  • 2,110 Answers
Remove the battery, put it back in, it works fine
  • Sibananda Jena
    Sibananda Jena Feb 22, 2009
    1. Turn the player off - you may need to take the battery out to do this.
    2. Hold the menu button in.
    3. Still holding the menu button in, press the power button.
    4. Keep holding both buttons in until you get a dialogue asking if you want to format internal memory ... say yes.
    5. Your internal memory will be formatted and you will now be able to start your X20.
    Brigadier General:
  • 3,614 Answers
better try to connect it on other PC and reformat it there. could be a virus infected your unit.
  • 1,031 Answers
Remove the battery, put it back in after 5min
  • 1 more comment
  • Starnley Johnwells
    Starnley Johnwells Feb 22, 2009
    that will solve the problem.hope that helps
    check the steps you followed before trying the above step if this fails
    If your player freezes on "Building Library" (usually a result of
    putting certain type of .m3u playlists or too big images in id3 tag):
    if this fails as before then remove the battery leave for 5-10 min as instructed before
    that will resolve the issue
I added to much music and it crashed
I use a microsd to load files that i havent tried on the device before, to test safely. If it crashes then i can simply remove the microsd and clear it. If the "bad" or incorrecly encoded files are loaded onto the internal memory of the device then you will be unable to clear or bypass the "building library" stage and the device is bricked. Take it back to where you bought it and get it replaced if this happens, that's what I had to do when I bricked it.
Maybe we all need to write to iriver and request much improved firmware that allows wiping of the internal memory BEFORE the build library stage as well as the option to disable or an improvement of the "build library" functionality. A simple solution would be to set a flag in a config file whenever files are added to the device and it doesnt do a build library unless the config flag says new files are present and that it is required.
Jul 10, 2010 | Nokia 5310 Cellular Phone
Iriver plus 3 not recognising iriver x20 player
try to upload the songs onto it with windows media player 11 i only use iriver plus 3 for videos
when ur in windows media go into sync then it has like a side bar just drag the music into that and down the bottom of the bar it says sync press that
and if that doesnt work u might have to buy a new one
Aug 29, 2009 | iRiver X20 MP3 Player
Song names in X20
i think you should try this...
if you dont already, download iriver plus 3
install it
open iriver plus 3
plug in iviver
go to tools>Portable Device>Disk Initialization
this should format your iriver and replace all the original files
i reccomend only putting music, video, pictures and ebooks on via iriver plus 3
and also please make sure you safely remove the iriver each time you connect it to the computer
if you dont, there is a chance that you will screw your iriver, you may have heard of the "building library" problem, which nobody has found a solution for yet.
i hope this helps you!!
good luck!
Jun 06, 2009 | iRiver X20 MP3 Player
My IRiver MP4 is stuck on "Build Library"
ive searched for hours, i couldnt find a solution..
but i will buy it off you for $30
..i like pulling things apart.. lol
anyway, if your interested, ill pay for postage too, contact me
deano_90@hotmail.com
Apr 26, 2009 | iRiver X20 MP3 Player
Iriver mp3 player
Same problem on a 2GB x20 I just bought. Easy to get things into the device, but nothing recognized as playlist either using iriver plus3 or Media Player.
Feb 05, 2008 | iRiver X20 MP3 Player
Frozen iriver screen
this problem seems to be common
it can happen if you dont safely remove the iriver from the computer
i havent found a fix for this problem anywhere
but ill purchace your iriver if you cant find a fix..
my contact is deano_90@hotmail.com
Jan 05, 2008 | iRiver Clix Digital Media Player
Frozen iriver x20
If your player freezes on "Building Library" (usually a result of putting certain type of .m3u playlists or too big images in id3 tag):
Try to figure out what file is causing X20 to freeze - i've found that pretty much any .m3u file will make it freeze on building library ... only about 2-3 out of about 100 i've tried have worked.
Oct 20, 2007 | iRiver X20 MP3 Player
I've had 2 crashed iriver X20
Hi. I just had solved my Build Library problem. Use my solution on your own risk.
The solution is the following:
1. open up a player (find 8 screws, not 6, 2 of them are on the left side of the player under the round stickers)
2. jently take off a circut board. (you need to access its bottom)
3. Find a memory chip. It is labeled like "samsung k9hbg08u1m"
4. find chip's key meaning start of pin numbering (small circle on the corner). There are 48pins. 24 on the left side (1-24) and 20 on the right (48-25) see chip's manual http://catalog.gaw.ru/index.php?page=document&id=11348 page 4
5. On the right side find pins 32-29 (find them as the second 4 pins from the chip's circle key opposite corner)
6. Connect them together with some metalic wire (don't touch two middle pins on the right side of chip, it is chip's power supply).
7. Holding those pins together connect USB cable to player's socket.
8. After a while player will show error on its screen, get metallic wire out of pins, and then the player will be available as flash storage on the PC.
9. Format flash storage with quick format.
10. Disconnect and assemble the player back.
11. Connect to PC and upload new music.
12. Feedback to fzymarev()yandex.ru
Oct 12, 2007 | iRiver X20 MP3 Player
iRiver X20 MP3 Player Logo
Top iRiver Audio Players & Recorders Experts
aliasger yq
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
