Question about GE HO98012 Computer Speakers
Lost power supply to GE 2.1 computer speakers
Where do I buy a new one? what is the voltage I need?
2 Suggested Answers
frankzjm
  • 191 Answers
SOURCE: lost my power supply
ok, your speaker system power adapter DC=24V and 2A please see: http://www.nulime.com/Macally-AC-Power-Adapter/p64128
hope to help you fix it
Posted on May 11, 2009
My speakers just stopped working. No power when I turn know to turn on and increase volume
Ir you are lucky it will be your power supply that's gone dead. Use a volt meter to see if the power supply is working or try to find a power supply with the same characteristics (voltage, polarity and amperage). If that doesn't work, the amplifier may be busted. If so you'll need new speakers.
Apr 18, 2014 | Bose Companion 2 Computer Speakers
What is rating of Spin 50 Power Module. Lost mine
Should it be a power supply that outputs AC and converts to DC inside the speaker case, or is it a wall adapter the outputs DC straight to the built in amplifier?
Some speakers have the voltage and polarity for the plug on the back of the speaker where the power lead plugs in. As they are only small speakers of probably a couple of watts it may only need about 2 Amps or less. Higher current is fine as the amp will only use what it needs to work correctly but I would'nt go below 2 Amps.
May 06, 2012 | Labtec Spin 50 Computer Speakers
I have Bose® Companion® 2 Series I computer speakers. I need to replace the adapater and want to know if speakers accept +ve or -ve polarity voltage. Thanks!
Each device is different.
If the receptacle for the plug is not marked, you have few options.
I suggest the following.
Go buy the exact same setup from a store you can easily return it to.
Take the whole box to Radio Shack and explain that you need a power supply to replace the power supply in the box. They will sell you one, plug and all, for about $10-15.
If you have a DVM (Digital Volt Meter), you can check the voltage and polarity yourself, and buy what you need, test it out, and install it.
--Dave
Feb 08, 2010 | Bose Companion 3 Computer Speakers
I lost my GE Ultrasonic 2.1 Speaker power adapter and i need need ones but i dont know what to buy, the voltage it requires..6 or 9 volts?
at most electrical stores you can buy a universal power adaptors with a selection of socents to fit most connections. and which has a selector on it for various voltages settings.
take one of the little connectors and see which one fits. then checking the polarity on your device set the polarity the same when plugging the connector into the power supply cable. adjust voltage as needed.
Warning: when connecting a variable power adaptor alway connect on the lowest voltage setting and work up as too high voltage can distroy your appliance.
Nov 13, 2009 | GE Ultrasonic 2.1 Speaker
Ac adapter for my GE speaker system
This is an old type of PC speaker system. Can it be powered by batteries. How many batteries needed??
Multiply the number of batteries by 1.5 volts and you
get the voltage rating of your needed adapter. You can also take a look at the back of these GE speakers. Maybe you can find the voltage rating.
You may also consider buying a new set of PC speaker that can be plug direct to your power outlet.
You can buy it at a cost slightly higher than your
needed adapter.
Nov 11, 2009 | Computers & Internet
Adapter/power supply cord missing emachine model SP 30A speakers
AC/DC Adapter
Model MA-9200
Input 120 VAC 60 Hz
Output 9 VAC 200 Ma
Class 2 Transformer
Oct 17, 2009 | Audio Players & Recorders
I lost power adaptor , needs rating for power supply to speaker
Go to radio Shack thye tend to carry a varity of AC adapters or in amazo. Make sure you get the correct voltage and amp for the speakers.
Jun 03, 2009 | Coby 2.1 Channel Amplified Speaker System...
Lost my power supply
Having some trouble finding any info online about them. Did they have a large power pack that plugged into the wall? If so, there might be some information either right around where they plugged in (im assuming on the sub) or possibly on the product info sticker on the speaker. Make sure if its a round plug in that you look for the tip information (whether if is a positive tip or negative). You might be better off buying a new set, depending on the price of a new adapter, compared to the price of a new set. Let me know if this helps.
May 11, 2009 | GE HO98015 Computer Speakers
Power supply
there is an internal fuse in the power supply adapter but you have to cut the box open to get to it.did this myself replaced the fuse and it now works fine
Dec 06, 2007 | JBL CREATURE II Computer Speakers
GE HO98012 Computer Speakers Logo
57 people viewed this question
Top GE Audio Players & Recorders Experts
Greg Cann
Greg Cann
Carlos L. Burgos
Carlos L. Burgos
SHARCNET-USA
SHARCNET-USA
Are you a GE Audio Player and Recorder Expert? Answer questions, earn points and help others
