Question about Spectra Logic Hello Kitty 13" TV
Won't turn on!
My Hello Kitty t.v. won't turn on first it wouldn't turn off, then it turned off by itself and now won't come back on. Don't know if its the power button or not.
  • 104 Answers
So long as you get a nice little 'tick or click' on the power button just like the rest of the buttons then it is not the button itself.
it is likely some 'safety' circuitry inside or the power supply both of which would require a TV tech. One thing that sometimes helps is unplugging it from the wall for a few minutes.
Posted on Feb 12, 2009
Net flix won`t come up on my tv
connect the internet to your tv
Apr 01, 2014 | Netflix
My U200E won`t charge unless it`s completely dead and the touchscreen won`t work anymore
Hi Bell, please don;t panic. Let us try to solve it.
> remove -- and don't replace -- the battery, than connect the charger and turning on the Laptop.
> also check the charging LED is turned On.
> if its working than check the battery else check the charger.
Feel free to revert back if issue not resolve.
Thanks
Nov 07, 2013 | ASUS Computers & Internet
Ice cusher not crushing
Just maybe, but do you use the same switch? If so, try using another switch, or, your ice crusher machine could be broken, the engine inside it could be water logged.
May 22, 2013 | Kitchen Appliances - Others
Wouldn't turn engine over
check battery, for correct charge level,are you getting gas ,how about fire to the spark plugs?
I don't know about that year,(to new),but 1988,and some later models
have a module in the distributor that sometimes goes out ,and are heat sensitive if this is the problem you won't
get fire to the plugs untill you change it BEWARE!!!,
the last one i bought,i think was about $64.00
that has been a while so make sure before you run out and buy one!
I hope this helps
Dec 11, 2011 | 1995 GMC Safari
I went out to move my 2005 cavalier and when I shifted from reverse to drive, it slipped right thru everything and wouldn't catch. It wouldn't even catch in park. I pulled the parking break and...
I don't know beans about automatice transmissions and the average person can only check the fluid levels and take it to a transmission shop if it is more serious.
As far as the engine goes, you need to localize the problem because with the other indications it might not be the normal stuff. So, what I would recommend is that you take the serpentine belt off and try to turn the crank with a large wrench (CW only) with the car in neutral. If you can turn it, then it is probably not your engine freezing up. If it won't turn then the transmission is probably not disengaging from the flywheel - maybe the torque converter.
If it does turn over, then you can put the belt back on and try to jump start the car with another vehicle or the boost function on a battery charger. It it starts then you know to look at the charging system - battery, alternator. If it doesn't start then the starter or the starter reley.
Sep 06, 2011 | Chevrolet Cavalier Cars & Trucks
The fan wouldn't start for the condenser unless I turned the blades with a stick so I replaced the start capacitor and it still won't start without turning the blades with a stick. It runs fine but...
This problem could be caused by a bad motor run capacitor. Please see our If your motor capacitor is not the problem, then more than likely you need a new motor.
Jun 13, 2011 | Ruud UBHC Air Conditioner
Hello. My 1997 Chevy Tahoe refuses to start. The problems began with a bad fuel pump. I changed. It worked. The fuel pump died again. I changed it again and it has been working. I parked it for two weeks....
Now you have a good battery & a starter that turns over the motor
Have you cycled the key on & off with a fuel pressure gauge on the
fuel rail?
Do you have a fuel filter that isn't over 3 or 4 years old?
Have you checked for spark while cranking ? Use an old plug on the wires,
if you have ignition wires,don't ground the wire without resistance
If you removed the ducting & MAF Sensor it won't start
Tell us what you checked & exactly how that was done.
Jun 09, 2011 | 1997 Chevrolet Tahoe
Why won`t my mp3 take itself off hold?
Power & Hold switch
Slide and hold in the opposite direction
of the arrow for power on/off.
Slide in the direction of the arrow to
lock the button functions.
If that fails,
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Apr 15, 2008 | Samsung YP-T10 Digital Media Player
Spectra Logic Hello Kitty 13" TV Logo
122 people viewed this question
Top Spectra Logic Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Spectra Logic Televison and Video Expert? Answer questions, earn points and help others
