Sharp AR-168D Black and White Copier
Problem for Sharp AR-168D Black and White Copier
Having trouble installing a new toner cartridge in a Sharp 168D.
By tburns708 on Feb 11, 2009
We installed a new toner cartridge into our sharp 168D copier. The copier is not recognizing that the toner cartridge has been installed. We pulled one seal off but it says to pull a seal off of the shutter????? We can't find it.
Clarification Request
Posted by tehnik_bdg on Mar 13, 2009
Did you buy the toner cartridge from your local authorized dealer ? Because it has a CRUM chip with a code inside that different depends on the destination country and it must matches with the stored in the machine's EEPROM
Posted by BigdaddyTDW on Feb 14, 2009
Get your old toner bottle and compare and you should find problem. look carefully to see any different pieces or tabs.
Solution #1
posted on Sep 13, 2009
Not Rated)
goodgold
Rank: Wiz  Sharp Office Equipment  Expert
Rating: 84%, 150 votes
Much sorry. You should peacefully understand. On cassette there is hole with toner, he locked or plastic by bolt or film in either event you first install the cassette on image prezhney. usually she is fixed in slots by thereby that after you will open the way a toner, he falls downwards. So tuba with toner is made thereby that under got up tuba хвостик film remains is sat and available to his(its) pash on itself and push off, this can be a plastic bolt or film. Not it is difficult her(its) find, besides, on box is always enclosed instruction or she there is beside you in documentation, usually drawings with methods place on inner face of the front lid. Do Not hurry, all easy. Good luck!
Was this helpful?
Yes
No
Solution #2
posted on Jul 15, 2009
Not Rated)
xptareq2000
Rating: 81%, 649 votes
please sir you saw a cartridge instalation guide thaks
Was this helpful?
Yes
No
Solution #3
posted on Mar 23, 2009
Not Rated)
SALIH OBAID
Rank: Guide
Rating: 85%, 4 votes
green labeled facing you when you install the toner in the machune there is a wute tape on it
Was this helpful?
Yes
No
Popular Solutions for Sharp AR-168D Black and White
Questions and Unsolved Problems for Sharp AR-168D Black and White
Do you recommend Sharp AR-168D Black and White Copier?
Answer
Answer
Error Message C5100 Kyocera KM-4530
Answer
one thin 6" line appearing in direction of paper movement same place each page (about 2.5"...
Answer
a Sharp copier--model Al 1641cs--is not starting properly. Michael Katz 650-494-1136
Answer
Canon Image Runner 2200 cannot print with Apple Snow Leopard 10.6 OS because Canon has not come up... (More)
Answer
Hi, Can someone help with resetting error H2-00 on sharp 168d
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Copier Experts
Top Copier & Fax Repairmen
in , CA
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
