Question about Brother DCP-9040CN Laser Printer
Yellow Toner Ink Spotting
Everything I print in color it has droplets of yellow spots down the line. I cleaned the drum, the toner and the belt but the spots keep recurring. I need help like yesterday.
  • Yvonne Davey
    Yvonne Davey Feb 11, 2009
    Brother DCP-9040CN Laser Multi-function Printer. What is causing yellow spotting on my color copies? I tried cleaning the drum and the belt but the spot keeps recurring on the belt. I even tried replacing the yellow cartridge. Help immediately, help!! - ydja
  • 62 Answers
Take a tissue and clean the area where the toner is. Do not use anything wet at all. Just a soft tissue. Re-install toner and try again to print. If the problem continues, it may be a leaking toner catridge. The cartridge has a cleaning blade built in and it may be deffective. Try a new toner cartridge if so.
Posted on Feb 12, 2009
Testimonial: "Thanks a lot for your suggestion. I'll certainly try it."
Why do I have yellow horizonal lines on printed page
Sounds like a faulty toner cartridge. Are all the cartridges OEM?
Jun 16, 2017 | Brother Hl3070cw Hl-3070cw Color Laser...
My Brother HL 4040cn printer is leaking toner, black and yellow. It leaves spatter spots of these colors on printed pages. The machine does not have any messages. Do you know what this may be from or how...
If you've taken the printer apart and cleaned the belt unit and everywhere else in the paper's path, then it is probably either a bad toner cartridge or the drum. Since it's multiple colors producing splatter, its most likely the drum unit. Try taking the drum out and removing all of the toner cartridges and then clean the drums and corona wires. If its still producing splatter afterward, you've got yourself a bad drum.
Jul 20, 2011 | Office Equipment & Supplies
Ink is smudged on envelope. How do I stop that from happening?
i bet you're printing in Black,
what happens is when black is selected, the 3 colored drums lift up 2 mm annd only the K drum is engaged, amd there is no static in the transfer belt under the CMY drums.
envelopes have air in them and can bounce along the bely after the black has printed, and seeing the toner is powder and not yet fused on, the toner touches the cyan drum as the envelope hits the fuser entry point as well as dragging on the Left transfer belt Blue lift handle(take out the belt and spring the handle off).
If you open the lid in this print mode, and lift out the cyan drum, turn it over and pull back the cover for the OPC drum, you will see the black toner on the green drum.
FIX 1. In the art work place a tiny dot of yellow. this will run the print mode in color and enagage all the drums. gaurantee your print will be fine, and know one ever sees that yellow dot.Problem is, this then runs down your CMY drums for black only printing.
FIX2.
If you have a later machine, downlaod iQueue from Xante.com (free) fantastic software. and get the machine updated with the latest X1.11 firmware from your dealer.
This allows with iQueue, to set the machine to print Black only, and you run the machine without the CMY drums installed....it works, it's great...
Aug 10, 2010 | Xante Ilumina Digital Color Press Printer
Hi Everytning I print has a very narrow pink line straight down the centre of the page, also every so often the print has a black/yellow/blue/pink thick line running across the page. Thanks
The narrow pink line is coming from your magenta toner/drum cartridge. You may be able to open the from cover and look at the 4 toners. If you look at the magenta (like pink) cartridge, you might see the thin line on the drum surface.
The multicolored band that sometimes shows up on your prints is most likely the transfer belt unit. This is caused by an area of the belt that is not being cleaned very well. This probably tends to show up when you are running mutilple prints of a page.
So it looks like to may need to replace your magenta toner and look at getting a transfer belt unit.
May 13, 2010 | HP Color LaserJet 2600n Printer
Colored ink is smearing on the page when I print
Did you change the toner?Developer unit? When did it occured?
FIRST: the copier must be cleaned and vacumed, it may be that toner falls onto transfer section and that causes the problem, you may also have problem with yellow developing unit or drum or transfer cleaning blade.
Pls. rate
May 07, 2010 | Canon imageRUNNER iR C4080 Color Copier
Yellow deposit
Remove the Yellow Drum unit, Check the drum for any toner. The drums should be clean and I believe a Green color. If you see any toner on the yellow unit replace the unit. Some models have a charge cleaner built into the image units, if that is the case with yours you will see a light blue knob on the front of the unit. Pull this knob in and out about 5 times to clean the units charger this may correct the problem without replacing the yellow image unit.
Mar 09, 2010 | Konica Minolta Magicolor 5670EN Color...
Oki 5150 color are not print right
You need to replace the magenta drum. Just because there is life left; it's possible it is scratched. Also, take a cotton ball dip in alcohol and wipe the LED's off when the cover is open; those black things that are hanging down from the cover. Also, make sure your drums are installed in the proper spots (magenta in magenta slot). If the toner "rubs off" after it prints... then the fuser is defective.
Jun 25, 2009 | OKI C5150n Led Printer
Sharp AR-C240P Printer Prints Everything with red cast
iF YOU HAVE NOT CHANGE THE DRUM TRY IT. FOR ANY COLOR THAT IS RUNNING OVER POWERING.
Jun 23, 2009 | Sharp AR-C240P Printer
Vertical line down left side of page aprox 2" from left side con
when I opened the front door to the cartridge compartement there was a green line of toner on the feed belt, I wiped it off. then I slightly closed the door to open the toner cartridges and found the one creating the mark and cleaned it.
no more line
Dec 27, 2008 | HP Color LaserJet 2600n Printer
Spots/Lines on the prints
Take out the drum cartridge (piece with the long green arm) and look down inside the printer for any toner that may be leaking on your pages.
So I understand correctly, you were seeing different color toner on the cyan and yellow rollers?. If so gently clean that side of the roller off. Rotate the white gear on the right side of the toner cartridge back towards you and see if the correct color comes back on the roller. If you were seeing grooves on the roller then they will have to be replaced.
Put the toner cartridges back in and run color calibration.
Press menu/select. Right arrow key until you get to engine. Press select. Left arrow key until you get to service.
Press select. Right arrow key until you get to color calibration.
Press select.
Any other information would be helpful.
Jul 17, 2008 | Konica Minolta magicolor 2430 DL Laser...
Brother DCP-9040CN Laser Printer Logo
604 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
