Question about Toshiba 36A50 36" TV
Time Warner Remote Codes
I found the codes, but the instructions say to press the TV and the SELECT button at the same time until the light blinks twice...I hold them down together, but nothing happens...no blinking. Is there a different way to make it work?
  • customhomere Apr 30, 2009
    i need code for time warner remote for toshiba tv can any one help
  • 51 Answers
Find your remote instuctions and it will say in them. dont follow the tv stuff.
Posted on Feb 11, 2009
Need code for sansui 2453w Time Warner cable service
Hi ,
TV Codes: 1023, 1176, 1246, 1182, 1248, 1310, 1316, 1391
1. Find the manufacturer's code for your device. 2. Turn on your device.
3. Press and hold the SELECT/OK button and the the appropriate device
key (TV, VCR, DVD, AUX) until all the device keys blink twice.
4. Enter the 4 digit code you found in step 1. All device keys will blink
three times to indicate that the code entry was accepted.
5. Point the remote towards the device, and press
to test the device.
6. If the device operates correctly, write down the code.
Sep 07, 2015 | Sansui Televison & Video
Trying to find a remote code. The tv is a 19"PLEDV1945A-B and the remote is a Time Warner UR5U-8780L-TWC
TV Instructions:
TV Codes: try 333
or 116, 143, 258, 363
STEP 1 Turn on the TV.
STEP 2 Press the [TV] button and the [OK/SEL] button simultaneously for three seconds. The TV Device LED will turn on indicating that the remote is in the programming mode. The LED will remain on for 30 seconds and the next step must be entered while the LED is on.
STEP 3 Point the remote control toward the TV and enter the three-digit code number assigned to your brand device (codes can be found in the code tables in the user guide or online). If there are more than one three-digit number listed for your brand, try one code number at a time until your TV turns off.
Note: When the TV turns off you can verify that you have selected the correct code by pressing the [POWER] button. The TV should turn back on. Then try all of the functions on the remote control (i.e. volume, mute, etc.) to ensure you have the correct code. If any of the functions do not operate as they should, repeat the instructions from STEP 3 above using the next three digit code number from the brand list.
STEP 4 Store the three-digit code by pressing the [TV] button once again. The TV Device LED will blink twice to confirm that the TV code has been stored.
Program My Remote Time Warner Cable
Nov 13, 2014 | Proscan 19 In. 720p LED HDTV/DVD Combo...
I'm using a Time Warner remote as a universal for my TV but when I go to change channels, it just lights up the CBL button and doesn't change the channel. Can I program it to my TV or will it
Hi, you need to de-activate the "programming channel control lock" option. You can see instructions in the manual for the remote. They are as follows:
  1. On the remote control, press CBL once; It will blink once, Press and hold SETUP until the CBL key blinks twice.
  2. Enter 9 7 3. The CBL key will blink twice.
  3. Press CH- once. The CBL key will blink four times.
    Now the remote control will provide TV and VCR channel-control capabilities while in the TV mode.
for any other information with programming this remote:
Download the 1056B01 operating manual with codes for free.
Nov 30, 2012 | Televison & Video
Need Time Warner remote codes for a TLC TV
There are no Time warner codes for TCL tv's. You will have to perform a "code search"
1 Turn on the device that you wish to program. If you are programming a DVD or VCR player, then insert a media disc such as a DVD or VHS tape.
2 Press the device key on the remote once. This remote is capable of programming five devices, and each has its own respective button at the top of the remote. For example, if you wish to program a TV, press the "TV" device key at the top of the remote. The device key will blink once.
3 Press and hold the "Setup" button on the remote. The selected device key will blink twice, indicating it is ready to be programmed.
4 Enter "991" on the remote. The device key will blink twice again.
5 Aim the remote at the device you wish to program and press the "Power" button.
6 Press the "Channel +" button on the remote. Continue to press that button until the device turns off. Once that happens, press the "Setup" button to lock in the code.
7 Press the "Power" to turn the device back on and it will be ready to use
May 15, 2012 | TCL LE24FHDD20 24-Inch 1080p LED HDTV
I cannot find a solution to getting our remote to work. TV model is Flatron. The remote is Zoom Universal.
WIth out knowing which Zoom remote you have I have condensed the instructions. You should be able to program your remote in one of two ways.
First try entering the codes one at a time below. Those are the code numbers for LG television for Zoom remotes. Just follow the step by step instructions and one of those codes should work your tv. If by chance none of the codes work, I have also included instructions on how to do a code search to search for your televisions code..
At the bottom is the link to Zoom where I found this information.. Good luck!!!
ZOOM LG CODES 004 005 006 012 019 056 057 058 082 155 156 171 172
Instructions for programing remote by entering codes
1. Manually turn on the TV.
2. Press and Hold the CODE SEARCH button until the
INDICATOR LIGHT lights, then
release the CODE SEARCH Button.
3. Press and release the TV button.
(The INDICATOR LIGHT will
blink, then remain lit.)
4. Enter the code using the
Number Buttons. After your
code is entered, the INDICATOR
LIGHT will turn off.
5. Aim the remote at your TV and
press the OFF·ON button. Your
TV should turn off.
Note: If your TV does not
respond, try all the codes for
your brand.
If your TV does not respond after you have
tried all the codes for your brand try
searching for your code by following the steps below.
Code Search Option for Programing your Remote
1. Turn on the device you wish
to program.
2. Press and hold CODE SEARCH
until the INDICATOR LIGHT
illuminates, then release CODE
SEARCH.
3. Press and release the device
button for the device you are
programming (TV, VCR or
DBS·CABLE). The INDICATOR
LIGHT will blink once, then
remain lit.
4. Press and release OFF·ON until
your device turns off.
Important: You may have to press
OFF·ON up to 200 times.
5. When your device turns off,
press the ENTER button, and the
INDICATOR LIGHT will turn off.
link to website http://axistronix.com/suppor.html
Dec 04, 2010 | LG Televison & Video
Need Time Warner Remote code for LG 42LB5D HDTV
For Time Warner Cable digital remote controls to work with your 42" LG HDTV, do the following:
1. Press "TV" and "OK" simultaneously for 3 seconds, until the button "tv" light on the remote is on.
2. Enter the TV code. In this case, it's "113". With the right code, your component will turn off. Quickly press the power button on your digital cable remote to turn it back on. Press the "TV" button again so that the remote saves that code.
3. You should be done.
Feb 08, 2010 | Directed 434MHZ Remote Control
I want to set the remote to change volume on TV,we can change the channels using the Time Warner remote but cannot change the volume using thesame remote, we have to change the volume on the Toshiba...
I am not familiar with the Time Warner remote, but Tivo remotes require pressing "tv power" and the "Tivo" button at the same time to program them.
Maybe you are pressing one a little ahead of the other.
Oct 18, 2009 | Toshiba 26 26AV502R 26 in. LCD HDTV
Do you have innovage remote codes for Vizio VO320E
I don't see Vizio TV codes in the Innovage Jumbo Remote manual.
Here are the Code Search instructions:
  1. Turn on your TV.
  2. Press and hold down the CODE SEARCH button for 3 seconds until the red LED lights up solid red.
  3. Press the TV button on the remote. The LED will blink once and then remain solid red.
  4. Press the ON/OFF button on the remote slowly and repeatedly until the TV turns off. The LED will blink once each time you press ON/OFF.
  5. Once the TV turns off, press the ENTER button to store the code. the LED light will turn off.
Oct 10, 2009 | Innovage Jumbo Remote Control
Remote control codes needed
turn your device on, press device key(tv,dvd,etc) press and hold Setup (led blinks twice), pres 9-9-1(led blinks twice) press power key , press channel + repeatedly until device turns off, press setup untill device turns off. good luck
Mar 22, 2009 | Televison & Video
Sanyo DS31520 TV
I am relentless when it comes to problems like this. I had the same problem with my TV being stuck in video mode. I found out that there is a reset button......It's on the @*&#^&^ original remote!!!!! So I tried programming my Time Warner Scientific Atlanta AT8550 remote for the TV to see if the "video source" button would work. IT WORKED!!!! You have to use code 1062. Instructions are:
1. Turn the TV on.
2. Press and hold select and the TV keys until the lights blink twice.
3. Enter 1062. All mode keys blink twice to indicate that the code was accepted.
4. Point the remote at the TV and press power to test the TV.
5. You can then successfully use the "Video Source" button on the bottom left of the remote to change the video mode. VOILA!!!
If you don't have a Scientific Atlanta AT8550 remote, I'm sure you know someone that does. They're everywhere!
Feb 10, 2008 | Sanyo DS31520 31" TV
Toshiba 36A50 36" TV Logo
495 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
