Question about Estate ETW4100SQ Top Load Washer
Washer estate brand ETW4300SQ Model
I have had my washer for less than two years and yesterday it stopped at the rinse cycle. It is full of water and will not drain or spin. It only clicks like the agitator is trying to agitate but appears stuck. Same model as above, won't do anything! I checked the lid switch, (pulled the top off of it). The contacts are engaging, I even cut & hard wired the leads going into the switch just to make sure. Nothing! Any help would be appreciated.
  • Anonymous Mar 11, 2009
    I have exactly the same problem with my Estate washer
  • Anonymous Apr 29, 2009
    I think the agitator is just locked up. It hums and I had a rough smell to it, but I don't believe the motor is burned up. I sure wish there was a free manual online.
  • 32 Answers
Sounds like the motor may be bad but the only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance. If possible use the meter and the wiring diagram to check input/output voltages looking for discrepancies between the diagram and the actual meter readings.
Whirlpool / Kenmore Washing Machine (Direct-Drive) Repair Manual
Appliance Parts Guru
www.RepairaiClinic.com
Posted on Feb 11, 2009
It will fill but once full the motor will only spin for a few seconds then stop
IT MAY BE DUE TO A RINSE PROBLEM?
WASHER WILL NOT RINSE:
If your washer doesn't go through the washer rinse cycle, the most likely cause is the water valve. What happens is the water valve will stop letting cold water into the washer; therefore, once the washer gets to rinse it will either stop or not do anything during the whole rinse cycle.
This is because when you selected your water temperature, you selected warm/cold or hot/cold. The hot water came in and you didn't notice any problems. When it got to rinse, the cold water the cold water won't come in. Therefore, the washer does nothing.
To check the water valve, first cut the water off and remove the hoses off the back of the washer. Then one at a time point the hoses inside the washer tub and turn the water back on. If you don't have good water pressure, turn the water back off and remove the strainer that should be in one end of the hose. Inspect the strainer to see if it is stopped up, clean it and reinstall it. Now repeat this test. If you have good water pressure now, reinstall hose and your problem is fixed.
If you still don't have good water pressure, the problem is in your house plumbing and you need to call a plumber. If you had good water pressure the first time you performed the test, the water valve is bad and needs replacing.
TIMER
If your washer doesn't go through the washer rinse cycle the timer may be the problem. Sometimes the timer gets stuck in the middle of the cycle or won't turn at all. If the washer runs, but the timer doesn't turn, the timer is bad and needs replacing.
Do you have anti-flood hoses leading to the machine. If you do there is probably a loose tube in the back causing a small leak. When the hoses detect that water is still flowing after a certain amount of time due to the leak it shuts down and causes the machine to turn off during the rinse/spin cycle
Apr 19, 2015 | Washing Machines
Washer stopped during rinse cycle.
If possible, you can drop the hose to floor level and gravity will drain the water. You may need a hose extension. The other option is to pan the water out. What is the model number of your unit?
Oct 15, 2012 | Estate Washing Machines
Washer will not rinse
you can put the extraction pipe /drain hose to ground level and water will drain then should open vacume switch thw programer is at fault as the programe sticks
Aug 18, 2012 | Estate Washing Machines
Washer is full of water and agitating clothes. it will do nothing else. i have tried to switch to other cycles or rinse cycle, it stops. makes no noise whatsoever and the washer is full of water.
Most typical thing wrong when a washer agitate but wont drain/spin is a defective lid switch. Reply back w/brand and model number and ill tell you where yours is and how to check it.
Aug 06, 2011 | Washing Machines
Whirlpool Estate etw4300sq squeaks during spin
WASHER IS FINE, SOMETIMES SQUEAKS WHEN THE TEMPERATURE CHANGES
Nov 08, 2009 | Crosley CW5000 Front Load Washer
Whirlpool Estate Washer won't drain and won't work
Need a complete model number to help you. Access to the parts varies with different model numbers.
Aug 30, 2009 | Whirlpool Washing Machines
If the washer fills and stops at the rinse cycle, and then will not spin or drain, you more than likely have a defective lid switch. If you open and close the washer lid and do not hear a “clicking” sound, the switch has probably come loose, or has broken. There are two mounting screws that hold the switch in place along the washer rim. Also, inspect the lid to ensure the small plastic piece that pushes down on the switch when the lid is closed has not broken off. This is called the “lid strike”. If the lid strike is broken or missing, the lid switch will not activate. If you diagnose the problem and need to replace the switch, you can click on the following link for advice on how to replace it:
http://www.fixya.com/support/r397101-replacing_lid_switch
If you need further assistance, such as where to get replacements parts, please let me know. I hope this helps you.
NOTE: You do not need to drain the wash tub to replace the switch. Once the switch has been replaced, the washer should spin and drain, which will prevent you from needing to bail water.
May 23, 2008 | Estate TAWB600JQ Top Load Washer
I also need the answer...
where is the lint trap located
Dec 06, 2007 | Washing Machines
Estate washer stopped after filling with water
will any of the lights come on when you try to turn on a cycle?
Nov 21, 2007 | Frigidaire ATF6000ES Front Load Washer
Estate ETW4100SQ Top Load Washer Logo
501 people viewed this question
Top Estate Washing Machines Experts
Dan Webster
Dan Webster
dweatherby
Are you an Estate Washing Machine Expert? Answer questions, earn points and help others
