Question about Kenmore 24032\24036 Top Load Washer
Kenmore 70 series adgitates but wont spin the clothes out
I have removed the front of the washer so I can get to the bottom but I can't find the belt.
    Scholar:
  • 31 Answers
The reason you did not find a belt on your washer is because this is a direct drive washer. There is no belt. The washer uses a clutch and transmission to agitate and spin your machine. It sounds like you have a problem with your clutch if it will agitate but won't spin.
Posted on Feb 12, 2009
    Scholar:
  • 99 Answers
This is joyce
The belt is usually found on the bottom or the back, but if you want the sceamatic on your machine go to kenmore.com and put in your model# and download your manuel and find out what you are looking for.
thanks
joyce
Posted on Feb 11, 2009
My kenmore 70 series washer quit agitating and spinning today. what could it be?
i think you will find the belt at the bottom has broken or come of here are the directions to replaced / re fit it
best of luck
merry christmas
  • Unplug the power cord of the Kenmore 70 series washer from the electrical outlet before attempting to replace the drive belt. Remove the end caps from the control console by pushing in on the center of the caps with your thumbs and pulling the caps forward.
  • 2 Unfasten the screws on the front of the control console with a screwdriver and set the screws aside. Flip the control console back so it is resting against the rear hinges.
  • 3 Locate the two-pronged electrical plug on the top of the washer near the back and unfasten it by pulling the plug straight up by hand. Remove the metal clips on the top of the washer, prying them up with a screwdriver and setting them out of the way.
  • 4 Lift the washer cabinet off the base and set it aside. Locate the motor at the base of the cabinet near the front and unhook the springs from the motor carriage with a pair of pliers.
  • 5 Unbolt the motor from the motor carriage, using a socket wrench to unfasten the bolts. Unplug the electrical wiring harness from the motor by hand.
  • 6 Lift the motor off the motor carriage and take the drive belt off the motor and transmission pulleys, discarding the belt. Place the new drive belt around the transmission and motor pulleys.
  • 7 Plug the electrical wiring harness into the motor by hand and secure the motor to the motor carriage with the bolts. Attach the springs to the motor carriage by hand.
  • 8 Place the washer cabinet back over the base and secure it with the metal clips on the top lid. Connect the two-pronged electrical plug to the top lid of the washer by hand.
  • 9 Flip the control console back down over the washer lid and secure the console with screws in the front. Place the caps back over the ends of the control console by hand.
  • 10 Plug the Kenmore 70 series washer into the electricity supply and test wash.
  • have fun
    Dec 08, 2010 | Kenmore Washing Machines
    Kenmore Series 70 washer, does not spin out the clothes like it used to. Makes a noise it didn't used to. Sounds like a dryer that has clothes with metal buttons on it.
    Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
    Problems with a washing machine not spinning or not draining are often inter related..
    If you are having a problem with your top load washer then check out this tip...
    Washing Machine does not Pump or Spin
    If you are having problems with your front load washing machine then checkout this tip...
    Front Load Washing machine not draining and or not spinning
    heatman101
    Aug 31, 2010 | Kenmore Washing Machines
    I have a top loading kenmore 70 series washer. It
    The drain line is probably clogged. Maybe that a sock or other piece of clothing get between the clothes tub and the outer tub that holds the water. In this case it may then get into the drain hose that's attached to the pump.Remove the hoses from the pump and pull the item out. In case it clean there, check the outer tub port- open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then,try to remove the clothing through the port.
    Sep 13, 2009 | Bosch Axxis WFL 2060 Front Load Washer
    Belt on my Kenmore series 70 dryer broke. How do
    broken belt......simple fix.......remove lint filter from top 2 screws remove.........insert screwdriver between top & front push down to pop top......1 screw on each side holding front on at top remove them....front will then pick up off the 2 remaining clips at the front bottom.....spin door around to the side belt should be laying in the bottom of the dryer or around the tub but broken.......hope this helps......check back.......
    May 05, 2009 | Kenmore Dryers
    Kenmore washer 80 series 110 model not spinning.
    unless your washer is over 20 years old, then it wont have a belt. the temperature of the water wont have anything to do with it spinning or not.
    need to know if it agitates or drains and just wont spin.
    if it agitates but no spin or drain, then you have a bad lid switch.
    if it wont agitate or spin, but will drain, then you have a broken drive coupling.
    Jan 08, 2009 | Kenmore 24032\24036 Top Load Washer
    Kenmore 70 series washer will not spin, clothes are too wet
    Not a belt, this is only a sound deadening devise on the brake housing. Not really needed. Replace the coupler
    Jan 03, 2009 | Kenmore 24032\24036 Top Load Washer
    Kenmore 70 series
    First thing is to remove the 2 screws from the console, they may be hidden in the front or bacl of console. After removing screws, lightly push the base of the console towards the front of the washer and pick up. This will expose your lid switch connection. Using a jumper wire, jump out the black and white wires then try advancing your washer into spin/drain. The culprit will usually be the lid switch assy.
    Apr 04, 2008 | Kenmore 24032\24036 Top Load Washer
    Kenmore 70 series
    Mrquest
    If it is draining the water then the motor is running. ou most likely have a broken motor coupler between the motor and gearcase.
    Remove the two screws that hold the console to the cabinet and flip the console back.
    Remove the two clips that hold the cabinet to the rear panel of the washer and unplug the lid switch harness. The cabinet will tilt forward and slide off.
    Remove the clips holding the water pump and move it to the side.
    Unplug the wires from the motor and remove the clips holding it.
    You will see the motor coupler.
    Make sure you can turn the gearcase shaft with a pair of pliers so it is not locked up.
    Post back with the complete model number from the washer if you need further help.
    Thanks, Mike
    Apr 02, 2008 | Kenmore 22422 Top Load Washer
    Belt on my kenmore 70 series washing machine
    Your washer should be a direct drive unit, it has no belt. If you hear the motor running but nothing is happening you probably have a broken motor coupler. The coupler is about $10.
    Pop off the trim pieces on each end of the console.
    Post back and let me know what you find or if you need any help.
    Dec 12, 2007 | Kenmore 24032\24036 Top Load Washer
    Kenmore 70 Series Washer
    i have a kenmore 70 series washer model 10020722990
    it will fill with water but will not wash. if you put it on spin the water will drain but it will not spin. it sounds like the motor turning. is it a clutch that has broken.
    Sep 05, 2006 | Kenmore 22422 Top Load Washer
    Kenmore 24032\24036 Top Load Washer Logo
    70 people viewed this question
    Fordexpert
    Archaeology
    Archaeology
    2mikecurtis
