Display says "printing online" but it is not connected to a PC
We cannot get it act just as a fax machine. It will not allow us to print reports; we get no dialing when we send a fax, but it says sending. The other person does not receive it. Incoming will show on the display, but do not come in. Cannot copy, or print reports - printing reports says "printer busy".
Re: display says "printing online" but it is not...
Unplug machine, press and hold down the "stop/exit" key while pluggung back in. continue to hold the button down for 5 secs, then release. if machine returns to the regular date/time display, you should be alright. if not, then you'll have to call brother or an authorized service center. this is usually caused by a fax stuck in memory, which this procedure should clear.
We encourage you to use our knowledgebase
MRC Smart Technology Solutions is here to help!
We offer a program to cover up to 3 printers of any manufacturer for an entire year! We can solve your problem!
Email [email protected] for more info.
Solutions for : How To Print Reports
Solution : Print Reports
NOTE: Some report options may not be available depending on the product configuration.
Press the [Menu] button on the Control Panel until "System Setup" is displayed on the bottom line of the Display Screen.
Press the [OK] button.
Press the [Left] or [Right] arrow button until "Reports" is displayed.
Press the [Left] or [Right] arrow button until the required report is displayed. The following options are available:
[Configuration] - This report lists the status of the user-selectable options. Print this list to confirm changes after modifying settings.
[Address Book] - This report lists all of the fax numbers and e-mail addresses currently stored in the machine's memory.
[Send Report] - This report lists the fax number, the number of pages, the elapsed time of the job, the communication mode, and the communication results for a particular fax job.
[Sent Report] - This report lists information about the faxes and e-mails that have recently been sent. The machine can be configured to automatically print this report every 50 communications.
[Fax RCV Report] - This report lists information about the faxes that have recently been received.
[Schedule Jobs] - This report lists the documents currently stored for delayed faxing, including the starting time and type of each operation.
[Junk Fax Report] - This report lists the fax numbers specified as "junk fax" numbers.
[Network Info.] - This report lists information about the machine's network connection and configuration.
[Network Auth List] - This list shows authorized users who are allowed to use the e-mail function.
Press the [OK] button. "Print?" will be displayed.
Press the [Left] or [Right] arrow button until "Yes" is displayed.
Press the [OK] button to print the selected report.
Reports you can print You can print these reports whenever you need to. Some of these reports can be set to print automatically also. 1. Press Report/Help. 2. Choose the report you want by using left or right arrow. 3. Press Start/Enter when the desired report is displayed. 4. The selected report will be printed.
Sending Confirm A confirmation report shows whether the transmission was successful or not, how many pages were sent, etc. ON: prints a confirmation report automatically each time you send a fax. OFF: never prints a confirmation report (You can print one manually using the Report/Help button (see Print reports on page 51). ERROR: prints only when an error occurs.
2. Choose the report you want by using !".
4. The selected report will be printed. The available reports are shown below:
Report name Content
Multi-Communication This report prints automatically if you have faxed documents to
more than one location by using Broadcasting.
Power Fail Report If you have a scheduled job (such as, delayed fax and send poll)
and there is a power failure, this report is printed automatically
when power is restored.
Report name Content
Help List This report covers the machine’s basic functions and commands.
It can also be used as a quick reference guide.
Sent Journal
Received Journal
These reports show information concerning the transmission and
reception activities. They can be printed on command. Or if the
machine is set to do so, they will automatically print after every
40 transmissions or receptions. For more information, see Fax
Log under the “BASIC FAX menu” on page 13
Phonebook This report shows all of the numbers currently stored in the fax
machine’s memory as One-Touch Dial and Speed Dial.
Sending Confirm This report shows the fax number, the number of pages, elapsed
time of the operation, the communication mode, and the
communication results. To set up your machine to automatically
print, see Sending Confirm under the “BASIC FAX menu” on
page 13
Checking a report for the transmission result (?TX Report? function) A report containing the transmission results can be printed. The machine can be set to either print or not print the transmission report or to print it according to the machine setting or only when a transmission fails. To print the transmission report 1 Press the [Fax/Scan] key to display the Fax mode screen. 2 Touch [FAX Menu]. 3 Touch [TX Report] on the Set 1 tab. 4 Select how to output the report, and then touch [Enter]. ? Default: The transmission report is printed according to the previously specified method. For details, refer to ?Specifying report output settings (Report Settings)? on page 10-48. ? ON: The transmission report is printed with each transmission. ? If TX Fails: The transmission report is printed only if the fax could not be sent. ? OFF: The transmission report is not printed, regardless of the transmission result.
Press the [Menu] button on the Control Panel, until Reports is displayed on the top line of the Display Screen. The Phone Book menu item will be displayed on the bottom line.
Press the right or left arrow button to scroll until the report or list you want to print is displayed on the bottom line.
Phone Book: Phonebook list
Sent Report: Sent fax report
RCV Report: Received fax report
System Data: System data list
Scheduled Jobs: Scheduled job information
MSG Confirm: Message confirmation
Junk Fax List: Junk fax number list
Press [Enter] to print the selected information.
Your machine can print reports containing useful information. The following reports are available:
Phonebook List: This list shows all of the numbers currently stored in the machine's memory as Speed Dial and Group Dial numbers. You can print this phonebook list using the [Phonebook] button.
Sent Fax Repor: This report shows information of the faxes you recently sent.
Received Fax Report: This report shows information of the faxes you recently received.
System Data List: This list shows the status of the user-selectable options. You may print this list to confirm your changes after changing any settings.
Scheduled Job Information: This list shows the document currently stored for Delayed faxes or Toll Save faxes. The list shows the starting time and type of operation.
Message Confirmation: This report shows the fax number, the number of pages, the elapsed time of the job, the communication mode, and the communication results. You can set up your machine to automatically print the message confirmation report after each fax job.
Junk Fax Number List: This list shows up to 10 fax numbers specified as the junk fax numbers by using the Junk Fax Setup menu. When the Junk Fax Barrier feature is turned on, incoming faxes from those numbers will be blocked. This feature recognizes the last 6 digits of the fax number set as a remote fax machine’s ID.
Multi-Communication Report: This report is printed automatically after sending documents from more than one location.
Power Failure Report: This report is printed out automatically when power is restored after a power failure, if any data loss occurs due to the power failure.
NOTE: The lists you have set to automatically print out will not print out when there is no paper loaded or a paper jam has occurred.
Sounds like you have the machine set up to print reports on all occasions, fax transmission, error, etc. You can change this by doing the following: 1 Press these keys: The display will show: 4 FUNCTION TRANSACTION LIST 2 Press a number from 1 to 5 to select the condition for printing. ALWAYS PRINT A report will be printed after each transmission, reception, or error. ERR/TIMER/MEM A report will be printed after an error, timer operation, or memory operation. SEND ONLY A report will be printed after each transmission. NEVER PRINT A report will never be printed. ERROR ONLY A report will be printed only when an error occurs. To print from memory: If the memory becomes full... If the memory becomes full while the document is being scanned, MEMORY IS FULL will appear in the display. ♦ Press the START/MEMORY key if you want to transmit the pages which have been stored up to that point in memory. The remaining pages will be ejected from the feeder. After transmission, the memory will be cleared and you can transmit the remaining pages. You will also need to transmit the page which was being scanned when the memory filled up. ♦ Press the STOP key if you want to cancel the entire transmission.
The machine can print a transmission (confirmation) report after each transmitted fax. This report indicates whether or not the fax has reached the intended recipient. Four different settings are available for the transmission report:
With: a report is printed when the fax transmission was successfully sent or when it is completely abandoned. There is only one report for each fax sent.
Without: no transmission report is automatically printed, however, the machine will save all fax transmissions that took place in memory. The faxes sent can be viewed by printing out a transmission log (report).
Always: a report is printed after each successful or interrupted transmission.
On Error: a report is printed only if the transmission failed or is abandoned.
NOTE: With each transmission report from memory, a reduced version of the first page is automatically reproduced.
To modify the report type setting:
Press the [OK] button directly below the Display Screen. '1 Installation' and '2 Fax' will be displayed.
Press [2], [5] on the numeric keypad. ‘25 >Send Report’ will be displayed.
Press [OK]. The transmission report screen will be displayed.
Press the up or down arrow button directly below the Display Screen to select a transmission report setting, then press [OK]. ‘25 Send Report’ will be displayed.
NOTE: As the up and down arrow buttons are pressed, the menu will scroll through the available choices and move the greater than symbol (>). Stop when the greater symbol is in front of the appropriate selection.
Press the [Stop] button on the Control Panel. The 'Date / Time' screen will be displayed
Press the [Menu] button on the Control Panel until 'Reports' is displayed on the top line of the Display Screen.
Press the [Left] or [Right] arrow button until one of the following reports is displayed, and then press the [Enter] button to print the report.
Report / List
Description
Phonebook List
This list shows all of the numbers currently stored in the machine's memory as Speed Dial and Group Dial numbers. NOTE: This list can also be printed by pressing the Phonebook button on the Control Panel.
Sent Fax Report
This report shows information on recently sent faxes.
System Data List
This list shows the status of the user-selectable options. This list can be printed to confirm any modifications to settings that have been modified.
This list shows the documents currently stored for Delayed faxes. The list shows the starting time of the Delayed fax.
Multi-communication Report
This report is automatically printed after sending documents from more than one location.
This report is automatically printed when power is restored after a power failure, if any data loss occurs due to the power failure.
when this happens, unplug machine, hold down the "stop/exit" key while plugging machine in. continue holding the stop/exit key for 5 seconds. display should return to the regular date and time screen. if it doesn't, contact brother customer support. this problem is caused by a fax stuck in memory.
Seeing old already printed report is your only hope i'm afraid,
once activity report is printed the memory is reset to allow it to remember next lot of fax's for you.
