Question about Samsung HT-DS610 System
Samsung ht-ds610 wont work at all
Wen turn on it goes to dvd mode and load display appears and noting happens and it does not even have a disc inside. It cant go to other modes.
  • 10,594 Answers
Loading mechanism is stuck some where in loading or unloading process.
Unplug unit form AC outlet for couple of minutes and replug back in, power up and check.
Posted on Feb 11, 2009
Why wont any of my disc load?
Available from Partsmaster for about 70 quid Panasonic SAHT870 DVD Mechanism Assy Panasonic DVD, Video, Home Cinema SAHT870
Sep 18, 2014 | Samsung HT-DS610 System
Its not able to eject
Some components in your amp board short, if you can replace yourself search the board model no. and buy it , much cheaper than send the unit for repair
Feb 12, 2010 | Samsung HT-DS610 System
Hi my ht-q100 dvd player not working saying there is no disc even if the disc is inside
Often helps to blow in the hole where the disc goes. Blow hard a few times then try disc again.
Jan 17, 2010 | Samsung HT-Q100 System
Samsung HT-DS610: Music louder than Voices
press the MODE button until you see MATRIX
it has something to do with the audio setting of the unit
Jun 29, 2009 | Samsung HT-DS610 System
Display reads OPEN LOCK when I try to open dvd tray.
Samsung Home Theater Systems have a Dealer Lock or Tray Lock Function that prevents the disc tray from being opened.
There are four procedures for turning off the Dealer Lock function. Try one, then the other, to see which works on your system.
Unlocking Procedure 1 To turn off the Dealer Lock function, follow these steps:
  1. Turn on your Home Theater System.
  2. Press the Stop button on the front panel and the Power button on the remote control simultaneously for four seconds.
Note: Repeating the two steps above turns the dealer lock on again.
Unlocking Procedure 2 To turn off the Dealer Lock function, follow these steps
  2. Press and hold the Function button on the front panel for 3 seconds. The display shows the word Unlock.
Unlocking Procedure 3 To turn off the Dealer Lock function, follow these steps
  2. Press and hold the Open/Close button on the DVD player on the front panel for more than 4 seconds.
Note: Repeating the two steps above turns Dealer Lock on again.
Unlocking Procedure 4 To turn off the Dealer Lock function, follow these steps
  1. Using the HTS remote press the Menu button + 712, and the HTS will display CAN OPEN.
The Dealer Lock feature is mainly used by retailers to ensure that the display discs are not removed. However, parents of young children may find this feature very useful as well.
Jun 26, 2009 | Samsung HT-DS610 System
No Sound From Samsung HT-DS610
your problem is in your pre-amp. the audio amflipier is bad. change your pre-amp IC.
May 25, 2009 | Samsung HT-DS610 System
Ht-x30 samsung cinema system display unknown disc
TThe player does not play this type of dvd disk! only pre-recorded movies and CDs Try hooking Up a player that plays DVD+ and DVD- disks!Hope I was of help!
(please use The ratings to keep this site free!)
Dec 14, 2008 | Samsung HT-X40 System
Yes...
Ok I'm being told to try a couple of different things... nobody seems to be 100% sure of the factory reset on that model.
To reset your Samsung home theater system, follow the steps below:
  1. While NO DISC message appears on the display of the home theater, hold the [STOP] button for longer than 5 seconds. INITIALIZE appears on the display and all settings will return to the default values.
  2. Press the [POWER] button, the home theater has now been reset and will power on. Note: Using the RESET function will erase all stored settings. Do not use this unless necessary.
If that fails try Service mode. But I'm confident the first solution is the correct one.
First on the remote with the unit off
try pressing (Mute 1 8 2 Power) This should kick into "Service Mode" Most samsung products use this code I use it alot. Volume up/down to navigate Mute/Menu to change settings
May 07, 2008 | Samsung HT-DS610 System
Protection Problem on Samsung Digital Home Theater
Protect mode will kicking whenever a fault is detected.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Apr 14, 2008 | Samsung HT-DS610 System
Samsung HT-DS610 System Problem
I found this online. Don't know if it helps you guys or not?
Samsung HT-DS610
1. Remove any discs from the tray
2. Flash the RAM (disconnect from the mains for 30 seconds)
3. Plug it back in, switch on from the remote
4. Wait for "No disc" message
5. Press Enter.
6. Press 8,4,2,6,9 slowly.
7. Press Enter.
You may need to repeat steps 4 through 6 before the try is open.
Nov 25, 2007 | Samsung HT-DS610 System
Samsung HT-DS610 System Logo
201 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
