Question about Eiki LC-X1100 Multimedia Projector
Eiki LC-X1100 Powers "off" after 10-15 minutes
We have 2 of these at church in a very open ventilated ceiling. One will power off after 10-15 minutes for no apparent reason... the other is in the same environment and stays "on". It will manually (using remote) power "on" after a few minutes. I checked both small air filters... they're OK. I talked to a Eiki tech... possible lamp or ballast (expensive). Any other tips?
Thanks,
John
  • 2,237 Answers
Even if the filters are clean, you will still need to blow the dust out of it with canned air. may be overheating. otherwise, sorry to say, it is the ballast.
Posted on Nov 18, 2009
Eiki LC X1100 - the unit is loosing all power [no standby leds] when switching on after being off for 5 minutes or more. I've found that if power is disconnected and Reset switch is engaged it will come...
in primary power-supply circuit there are 2 smd capicitors,1uF and 2.2uF, replace them both by standard radial 105 C electrolytic, also replace the 220uF capacitor that is located beside these 2.
Oct 16, 2013 | Eiki LC-X1100 Multimedia Projector
Eiki lc x1100 multimedia projector lyrics are "shadowed" with multicolors
screen ,the color is ghost,
LCD panel is broken.you need a new one USD120
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
Sep 19, 2013 | Eiki LC-X1100 Multimedia Projector
Can get any power on on my eiki lcx 1100 projector
Thermal fuse, located under the lamp might be activated, open lampdoor and push carefully the little black pin. If it gives a click it was
activated due overheating. If not, replace 1uF, 2.2. uF and 220 uF capacitors in primary part of the power supply, it takes some work to get the pcb out of this model !!
Jan 23, 2013 | Eiki LC-X1100 Multimedia Projector
My Eiki lc-x1100 is not displaying very bright. I bought is used from a university and it only has about 900 hrs. on the present bulb. Is there something else that would make it dim? Don't want to...
i would check the physicality of the lamp. once you've removed it, look around the filament of the lamp, and if you notice any dark corrosion build around it, then that's what's causing the dim image. if it looks clean and clear, it might be one of the mirrors within the projector's optical engine.
May 24, 2011 | Eiki LC-X1100 Multimedia Projector
My church has an EIKI LC-X986 projector that turns on for about 2 seconds then shuts down. The lamp is brand new and the filters are clean. I know the signal is working as I can see it for those 2...
Have a close look at the fan and check if there is a make and model number on it.
If you cant see anything, unscrew the fan and check on the hidden sides.
see what voltage it is. ie 12v dc or 24v dc
Ring the EIKI agent and ask them how much for a replacement rear fan, the EIKI part number, and also if they can supply the manufacturer of it and their part number.
Check that the fan connector is OK, and the socket where it plugs in.
Check that the fan turns freely.
report back what you find
Mar 24, 2011 | Eiki LC-X986 Projector
Projector remote
go into the menu under settings. should find lamp hours under there. as for the remote, try www.projectordoctor.com
Nov 10, 2009 | Eiki LC-X1100 Multimedia Projector
Projector powers down and re starts over and over
the colorwheel, the ballast, or the power supply are not working properly.
Apr 16, 2009 | Eiki LC-XB20 Projector Multimedia...
EIKI LC-XNB4MS POWERS ON AND FANS START FOR 15 SECONDS AND THEN O
the lamp is near the end of it's life. time to replace it.
Mar 20, 2009 | Eiki LC XNB4 LCD Projector
Eiki LC-X1100 Multimedia Projector Logo
438 people viewed this question
Top Eiki Office Equipment & Supplies Experts
jasbo
jasbo
Jaime Hernandez
color wheel light...
Are you an Eiki Office Equipment and Supply Expert? Answer questions, earn points and help others
