Tried the following codes 0065, 0696, 1177, 0642, 0688 & 0742
NONE WORK CANT STAND THESE KIND OF SITES WHERE PEOPLE SEEM TO GO OFF TRACK WITH THE TV MODELS !!! PLEASE READ MODEL BEFORE POSTING OVER OTHER MODELS NUMPTIES WASTED MY F ING TIME
SOURCE: Remote Sky+ handset
I systematically tried hundreds of codes and by chance this method worked for me...hope it works for you too! Press TV then hold select and red til LED flashes twice. Enter 3 digit code 253 then press select again. Good luck! Sara
SOURCE: BOUGHT SAMSUNG LE40A656 LCD CAN,T GET SKY REMOTE TO WORK
I tried the closest model no. in the Sky list in the system setup, I think the code was 0840. Cover the front of the remote and press TV, then press red & select button until the remote led light blinks twice, key in the code 0840 and then press select. Try the volume button and this should work. If you get stuck go into interactive and system setup and select setup of sky remote and it gives you a list of makes and models, this is the closed one to the LE40A656 and works with mine.
Hope this works for you.
SOURCE: remote control code for ONN tv, Model- LE 19L`cdd-vd0701`
Flat Panel Televisions I HAVE A SKY+ BOX AND NEED A Remote control code for ONN tv, Model- LE19LCD0801
