Question about Dell Dimension 9100 PC Desktop
My Dell 9100 desktop won't start.
When switched on the switch light shows green, the fan on (what I belived is the graphics card) runs, the green LED on the main board the other components are fitted to is on and and there is a peculiar noise (find it hard to described) which can be heard for a couple of seconds at a time and will come and go for maybe 15 seconds. The noise seems to be coming from somewhere on the main board which is fiited vertically to the casing. Nothing shows on the monitor, generally the monitor (Dell) power switch changes from amber to green on start up, however it stays amber.
  • donnellygrah Feb 12, 2009
    Changed the battery re set the time & date and it worked all day until I disconnected it to put it back under the desk, having worked on it on the desk. The diagnostic lights show, 3 & 4 on constantly. Dell give this as
    Memory modules are detected, but a memory failure has occurred.
    At a bit of a loss again
  • Peter Steiert
    Peter Steiert May 11, 2010
    Have you attempted a CMOS reset? This is fairly advanced as it requires you to open your computer and pop out a battery from your system's main board.
Or your cr2032 battery could be dead. Mine was.
Posted on May 05, 2010
Mine does the same thing 9100 too. To solve it I just remove the memory sticks and place them back in. Works for me. I've had to do it multiple times. Cheers!
Posted on Aug 12, 2009
    Scholar:
  • 75 Answers
Hey mate... Now there could be a number of things wrong with your PC.. First thing is that on the back of the main tower there are 4 Lights that glow if the system is ok but in case of issues they glow in different patterns according to the potential problem... look out for those lights n refer em to this chart
http://support.dell.com/support/edocs/systems/dim9100/en/SM/adtshoot.htm#wp1054146
Also in case of potential component failtures the system gives out beep codes in patterns (maybe the sounds u hear at startup)... Do a quick check
Now regardless we can perform a basic troubleshooting...now you seem to be tech savy enough so do one thing... remove all the chords from the system... then hold dowm the power button to discharge the flea power... now remove all the components one by one n reseat them immediately... this will reset the connections n then try n restart again... if the problem persists then post the 4 led code here n we'll go from there mate :-)
Posted on Feb 11, 2009
Will not boot
Sounds pretty desperate. I suggest you find the Dell boot disk and insert it before switching on. Then come back here to report progress. Wish you luck!
Dec 16, 2013 | Dell Dimension 9100 PC Desktop
Have dell Inspiron 546 minitower. Been acting up lately where it won't power up. The LED light on PSU below voltage switch is green. Light on MB is orange. No power or indication at all on front...
PSU's put out several different voltages if the 12Vs isn't working it won't power the motherboard. Some outputs may still be functioning therefore you may see some lights on and even some fans running. Replace the PSU.
Jun 29, 2013 | Computers & Internet
My dell inspiron pc 530 desktop monitor does not come on at all when starting
Check in order:
1 Is the monitor power line connected?
No? Connect it
2 Is the monitor switched on (bezel switch with telltale light)?
No? Find the switch and toggle it.
3 Is the data cable (VGA or whatever) properly connected?
No? Connect it.
4 Does another monitor work on this system?
No? You have bad graphics on your PC. Replace card or PC.
If you answer YES to all those questions, then your monitor is defective. If so your most likely problem is a failed back light. Consider replacing the monitor - the cost of a service call goes a long way to the $100+ you might spend on a replacement.
Oct 15, 2012 | Dell Inspiron 530s Desktop Computer
My Dell Studio Xps 9100 Desktop Computer recently restarts by itself or freezes a few days after I play games. My graphic card is compatible. Sometimes I can even get BSOD.
You could have a virus or infection. Try downloading and installing MalwareBytes and run a Quick Scan.
Go to www.google.com and in the search box type: "Download cnet Malwarebytes" (without the quotes). Download and install malwarebytes from the sites download.cnet/malwarebytes. When the site opens up click on the Green Download button on the left. Do not click the Red Download button, that's junk. When it finishes installing the Gui Interface will open up with an offer to Accept a Trial Version or Decline. CLICK DECLINE you want the totally free version. Run a QUICK SCAN. As it scans, if it finds infections the number will be in red. When it finishes scanning, click SHOW RESULTS. A notepad text document will open up showing you the results. You can close the text document and go back to the Gui Interface where you will click REMOVE SELECTED RESULTS. The objects will already be selected for you. When it finishes removing the objects click ok and it will sometimes reboot your machine.
Jun 05, 2012 | Dell Studio Xps 9100 Desktop Computer
Will not turn on when power button is Dell Inspiron 518 will not turn on when power button is pressed. Green LED on back of powersupply lights and orange LED on motherboard turns on. No fan operation on...
Green LED on back of power supply indicates it's getting power. That does not mean that it's distributing the power voltages to the computer. You could have a bad power supply or a bad motherboard. Just to make surethat nothing else is causing the problem, remove any PCI cards like modem,video card, sound card, etc... Remove the memory modules and disconnect cablesto CD/DVD drives. Look at the USB ports to see if any are damaged.
Apr 13, 2011 | Dell Inspiron 518 Desktop Computer
My Dell inspiron 518 will not turn on when power button is pressed. Green LED on back of power supply lights and orange LED on motherboard turn on. No fan operation on anything. Thinking it is the switch...
Green LED on PS means it's getting AC power. Orange light on motherboard means it's receiving power from PS but it may not be the correct voltage. The power supply isreceiving power from the source but is unable to properly distribute it to thecomponents. This can be caused by a defective power supply or a defectivemotherboard. Just to make sure that nothing else is causing the problem, removeany PCI cards like modem, video card, sound card, etc... Remove the memorymodules and disconnect cables to CD/DVD drives. Look at the USB ports to see ifany are damaged.
Feb 14, 2011 | Dell Inspiron 518 Desktop Computer
Amber light that looks like a battery sign is blinking on & off on the front panel
A blinking amber Pwer light indicates that there is something wrong with the power. You might check the following:
Make sure the AC switch is in the correct position. (115-US)
Are you getting any fan action or noise?
Is the green motherboard LED ON?
Make sure all you MB connections are secure.
Check (or have someone check) your power supply outputs.
And for reference, here is a link to your computer's Service manual:
http://support.dell.com/support/edocs/systems/dim9100/en/SM/index.htm
Thanks for using Fixya.
Jul 14, 2010 | Dell Dimension 9100 PC Desktop
My Screen might be out??
dear ...,
when switching on te laptop, does it make noises, does the fan run, the CD/DVD-drive
LED shows green light and the harddisk rattle little bit? - good for you if it does, as the system still boots up !
to check if the LCD screen is broke and not the graphics card malfunctioning:
hook it up to an external monitor (one usually used with desktop PCs)
when laptop is switched off, using the 3-pin input in the back or to the right side of your laptop, and make sure the external monitor's power cord is properly fused...
Now switch on the external monitor first and then your machine again, and wait for the laptop boot messages on the monitor!
see anything? if yes the laptop screen is broke and needs to be replaced.
If still the external monitor stays black the onboard graphics card is up in smoke and you're in big trouble then.
Good luck finding out!
Oct 22, 2008 | Toshiba Satellite M55-S135 Notebook
Dell Dimension 9100 PC Desktop Logo
1,510 people viewed this question
Alun Cox
