Question about Toshiba Satellite A35-S159 Notebook
I have a lap top that wont start up It comes on for 5 sec.
Toshiba Satellite A35-S1592 It will only go to windows XP when attached to power supply then freezes up. Is it the CPU or Ram Or onboard powersupply? Help
When does it freeze up?
Posted on Feb 12, 2009
I have the toshiba satellite a35-s1592 and I want to know what preinstalled programs I can delete?
Try a google search for a program called 'pcdecrapifier' it checks for pre-installed software that you may not need. No you can't remove older windows updates, I believe the newer updates build on top of the older ones. Also I use a program called Revo Uninstaller, to remove programs and any left over files and folders and registery files that windows doesn't. Hope this helps.
Nov 11, 2011 | Toshiba Satellite A35-S1592 Notebook
I can not find Harddisk in Toshiba Satellite A35-S1592 PC Notebook,Pls help me now I can not open data in Harddisk.Thank so much for read.
You can purchase an external hard disk casing to plug in your hard disk and extract the data on another PC.
Mar 08, 2011 | Toshiba Satellite A35-S1592 Notebook
Where can I buy a new battry fo my labtop Toshiba A35-S1592
You can buy new batteries at the below link
http://www.laptoppartsshop.com/models/original-Battery/Toshiba-Satellite-A35-S1592
and also
http://www.amazon.com/Toshiba-Satellite-A35-S1592-Notebook-Replacement/dp/B0016WFPVA
Jul 02, 2010 | Toshiba Satellite A35-S1592 Notebook
My laptop's bratty A35-S1592 becomes empty after so what is the p
The cells in the battery have become degraded. You need a new battery i'm afraid.
Regards.
Toshiba satellite A35-S1592... Does it have bluetooth capability
I looked up the specs on the internet, and it doesn't have bluetooth capability. You would have to contact Toshiba or a repair shop to see if it can be added.
Mar 13, 2010 | Toshiba Satellite A35-S1592 Notebook
How do i get to the disk drive on a toshiba satellite a35-s1592
hi there is usally a plate on the bottom of the laptop ,remove it which will more than likely give u access to the hard disc drive,check for a lever or maybe a button to release the hard disc drive then download your models manual from http://www.toshiba.com will have everything u need to know u
Mar 11, 2010 | Toshiba Satellite A35-S1592 Notebook
On then off
Remove the memory and clear the cimos battary then reboot the system it will work
Sep 02, 2009 | Toshiba Satellite A35-S1592 Notebook
A35 s1592 battery won;t charge
You probably have a problem with your power adapter. Since you mentioned that the battery discharges when connected to the adapter, it means that the charger is acting as a load instead of the other way around. This is a typical behavior of a defective charger.
Try to check the output of your adaptor using any voltmeter. The voltage reading should be approximately close to the voltage rating as printed at the back of your laptop. If not, then its wiser to buy a new ac adapter instead of sending it for repair to electronic shops. Most of these chargers are no longer reliable when repaired, and might cause more problem to the laptop instead.
Nov 09, 2008 | Toshiba Satellite A35-S1592 Notebook
Toshiba Satellite A35-S1592 Sound
You might try browsing a few of these sites at the link bellow. It might help with the sound issue for the Debian Sarge install.
http://www.google.com/search?hl=en&q=Toshiba+AC%2797+Audio+Controller+drivers+for+Debian+Sarge
Aug 25, 2008 | Toshiba Satellite A135-S4527 Notebook
Toshiba Satellite A35-S159 Notebook Logo
128 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
