Question about Zenith XBV443 DVD Player/VCR
Zenith 5R688 I reasonally purchased an old AM&FM radio at a pawnshop for $80.00 dollars,I was wondering if you could possibly tell me what year it was built it's a Zenith Model 5R688 or 5R686.I,m having a had time reading the model number,because of the age.The radio and the record player still work,you should of seen the dust in side the radio.I was also wondering if you still sell the tubes.The turntable had an old 78 record in it.The songs are DANCE LIKE A LADY & THE BIRD'S COURTING SONG by Mary Stuart with Percy Faith and his Orchestra,the record is probaly more valuable then the radio.THANK YOU
    Top Expert:
  • Zenith Master
  • 75,157 Answers
1852. Just after the birth of Nepoleon.
Posted on Apr 11, 2017
  • 586 Answers
SOURCE: Zenith Model SR3238RK horizontal lines
There must be a capacitor which would be brust or leaked.So check it in th horizental section.And power supply section.Find that one and replace it. Good luck
Posted on Aug 12, 2007
SOURCE: Zenith ZN-501S remote control codes and instructions
http://www.thompsontv.com/zcodes.html
Posted on Feb 20, 2008
  • 17 Answers
SOURCE: zenith model #m52w56lcd tv?
For a really good step by step with pictures guide to replace it go to
http://www.fixyourdlp.com/blog/?p=34
For a good place to purchase the lamp go to http://www.discount-merchant.com/Original-Zenith-Projection-LCD-TV-Replacement-Lamp-p
/zenith_m52w56lcd_lamp.htm
I have found they have the best price on these replacement lamps. You might also check Ebay.
Posted on Feb 21, 2008
SOURCE: How do I connect my dvd recorder xbr716 to the television?
Tiene tu televisor entradas de audio y video,si las tiene no hay mucha dificultad para conectarlo,el aparato trae unos cables rca con diferente color rojo blanco y amarillo, el rojo y el blanco los vas a poner en las salidas (outputs) de audio del dvd las que son del mismo color,el conector amarillo lo vas a poner donde dice video output, y en la tv los conectas donde dice inputs en el mismo color del conector.Pones tu tv para entrada de video y ya esta.
Posted on Mar 23, 2008
SOURCE: Day Light Savings Time
If you tip your clock over you will see three little buttons under. They are each labeled. Press/hold the one that says "clock" until your display blinks. Use the forward/back buttons on face of clock to re-set time, then press the little "clock" button underneath it again to keep the time you just set. It probably will beep.
When Congress's ideal day comes, re-set it the same way. Sorry, but all this will do is keep you from having to look at the wrong time for a few weeks straight.
Posted on Mar 08, 2009
My old unit stopped working;(worked perfect for many years) so I replaced with a new same model and I have bad interference and FM static. Sometimes the FM station overrides the express radio and all you...
The very first XM radios, (SkyFi2, MyFi, Roady2) up until they were put in red boxes, had a VERY strong FM transmitter, so strong, that when Sirius was their enemy, they complained to the FCC and they made the FM transmitters real weaklings. So unless you have one of the first two batches of XM radios, the FM transmitters now are real junk and you're better off using an AUX input on the radio or a cassette tape adapter. Okay? Thanks.
Mar 26, 2015 | Audio Players & Recorders
Where can I purchase a replacement antenna?
I found mine at a every things a dollar store. You could try radio shack or an electronics repair store.
Mar 28, 2010 | Eton FR250 FM/AM Radio
Blurred picture and it's also dark rear projection zenith Z52Z95D
I'd get the lamp replaced for sure. If it has a ballast - change that at the same time. However, a Zenith repair center should be able to tell you whether it's worth doing or not.
Jan 05, 2009 | Zenith Z52Z95D TV
2003 dodge neon timing belt
At you mileage, I say its due, not worth risking it breaking and bending the valves, also recomended changing are the water pump, timing belt tensioner, and idler for teh regular belts
Probably cost around $500 - $750
Dec 16, 2008 | 2003 Dodge Neon
I have an old Zenith console radio model #8A02. Do you have any idea what it is worth and where I can purchase the tubes for the radio?
My problem had nothing to do with the Radio Shack VGA PC Camera Webcam. I was asking about an old Zenith console radio model 8A02. I was trying to find out where I can still buy the tubes for it and what the radio is worth.
Sep 13, 2008 | Radio Shack VGA PC Camera Webcam
Sirius question
Yes it should be very easy with use of the ear phone jack - depending on the model of course but generally all you need is an ac/dc power supply, the antenna connection, and for connection to receiver you can connect via FM or hard wire.
FM: as in your car pick an FM station frequency that is clear (no station on it) lets say 88.1 then set your home receiver on 88.1 and there you have it.
DIRECT: purchase a stereo 3.5mm headphone cable with two RCA male plugs at the other end. A faily common cable found in dollar stores or for five times the price at Walmart/Radio Shack etc.. Plug the 3.5mm plug into the 'headpone' jack of the satellite radio and the RCA plugs into the rear of your home receiver - usually a 'aux/line in plug" or "tape in" plug then turn the knob on the receiver to "aux or tape" selector. Bingo you should hear satellite radio all over the house....if the volume is UP! Take care Frank
Sep 05, 2008 | Sirius Satellite Radio Receiver
Toyota Previa 1993 AM-FM Cassette Unit Model 11709
Send me the code for the radio, I have all of the unlock codes.
Jun 29, 2008 | 1993 Toyota Previa
Roady XT Transmitter problem
Mine is doing the same as well. Been working for 1 year. Now it starts cutting out while listening. I noticed if it is broadcasting the fm frequency menu is there. The minute it cuts out I press Menu and that menu item is gone. It comes back once the radio starts working again. Mine is 1 year old. I got it Christmas of 2006. I do know that if you have it directly connected then this menu item will not appear and that is by design. I think my xm roady xt has gone bad.
Jul 02, 2007 | Delphi Roady XT XM Radio Receiver
Zenith XBV443 DVD Player/VCR Logo
59 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
