2001 Volkswagen Jetta TDI Logo
Posted on Feb 11, 2009
Transponder chip in key fob
Hi there i have a 97 sharan tdi just bought a key fob correct one from ebay could i put my transponder chip in key key fob and programe it to my car
  • leehallam Feb 11, 2009
    sorry the car is a vw sharan 1.9tdi on a r reg
  • Marvin
    Marvin May 11, 2010
    what make of car?
Anonymous
Level 1:
New Friend:
  • Contributor 15 Answers
  • Posted on Jul 24, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
15
Questions
0
Helped
8456
Points
22
This will all depend upon what country you are in, and if the vehicle even has the need for the chip to be programmed at all.
When you put a proper key in the ignition, is there a antitheft logo that cycles with the other indicators?
VW antitheft indicator in the USA often looks like a car with a key under it
In the USA, thought the keys have a MEGAMOS RFID chip, no system was active until 2000, and on some models, not until 2002
A system requires a VIRGIN chip. Once the chip is programmed to a car, the chip is locked to that car. Some new software can unlock and refresh some chips, but not 100%
I had a client come in TODAY with a 2003 Passat, and an EBAY flip key.... I wasted a half hour programming time..... but I carry the lower half of remote, which hold the blade and the chip, so was able to fix client up, when EBAY failed.
If this was helpful, please post a nice review for City Lock in Boulder Colorado listings on Google Maps, Yahoo etc. This listing will link you to my website as well. On my website are resources for finding a legitimate locksmith near you. Be sure you are hiring a REAL locksmith!
Thank You
Jeff
My key doesn't have a chip in it for my 2001 Chevy S10. So how is it the the passlock or passcode causes problem? This is trouble some as this
Although some keys do not have an embedded transponder, such keys are designed to give access to the vehicle only and not to allow engine starting.
To allow engine starting there must be an embedded transponder in the key, programmed with the correct code.
In the early days of passive immobiliser systems some manufacturers used a key fob to operate the central locking and to house the rice-grain-like transponder chip. Sometimes the key or the fob would break and the owner would attempt to start the engine fruitlessly as the fob would be in a pocket or handbag (purse). The fob had to be within a few inches of the ignition/steering lock...
The car will lock and unlock with key fob but when you put key inti ignition and turn to start car will not start
Year make and model helps. Older models don't have a chip/transponder in the key and the security would work with the fob or unlocking the door with the key. Newer models have to receive the signal from the transponder. It could be the key, receiver, wiring , or the BCM.
Bought used RX 300, master key fob broken, flat key doesnt work
You can get empty key cases on ebay, open the old key case and remove the transponder with the buttons on it and transfer it to the new key case, no programming necessary because you are using the same transponder, al that's left then is to have the key cut to fit the ignition switch.
1helpful
1999 vauhall zarira flashing engine light,starts but want run
Hi when you say it starts do you mean it turns engine over but not running , if so open you key fob up to see if the small transponder chip is still there it will be on the side of the main prt of the fob itself as most of the time these fall out when keys are dropped and deprecate losing the transponder chip if it is still there and no spare key you will have to get it recoded/ chipped
My peugeot 406 key is falling apart, if i bought a new key fob how do i reprogram it myself?
you dont just take teh little black chip out of old key and put it in new key or tape it to teh transponder behind the shroud on the column
Hi, got a 1998 vw sharan, only came with 1 key (not remote) i have bought a remote fob off ebay with reprograme instructions, which state to unlock the drivers door 3 time and the door led will stay on...
Check whether the fob has a transponder chip in it, if the unit is a bare shell blank remote then you will need the transponder fitted to be able to program it . The only alternative is to have the immobiliser turned off . Not a cheap service.
2answers
Key fob programin
I would suggest going to the Bentley Publishing site here:
http://tech.bentleypublishers.com/forum.jspa?forumName=volkswagen.a.a3
and maybe take a look at Dan Reed's Mk3 site here:
http://faculty.ccp.edu/faculty/dreed/Campingart/jettatech/index.htm
Transponder chip
yes you can do that to save you having the new key coded in
1helpful
Glow plug light flashes on97 tdi sharan
on some diesel engines the glow plugs will cycle after the engine is started. it does sound like your glow plugs are not all working that would cause the hard start and excessive smoke when it does start.
Top Volkswagen Experts
ZJ Limited
ZJ Limited
Bradley
Bradley
Thomas Perkins
Thomas Perkins
Are you a Volkswagen Expert? Answer questions, earn points and help others
