Question about Canon EOS Digital Rebel XS / 1000D IS Digital Camera
Have to press button down twice to take shot
This happens in advanced shooting modes only with or without flash
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 155 Answers
This is your first SLR?
The normal procedure is to press the button halfway to get the focus. This is indicated by one or more red LEDs lighting in the viewfinder and a confirmation beep. Once you have this, you press the button fully to take the shot.
As the camera will not take a photo when not in focus, then pressing the button once and letting go will focus it, and pressing it again will take the shot.
Get used to pressing it halfway before taking your shots and it will soon become second nature to you.
Posted on Feb 11, 2009
Need correct day and time on Olympus FE 170 digital camera
How do I set the date and time on the FE-170?
To access the clock controls, turn the mode dial to any shooting mode except [GUIDE] and then press the [MENU] button. Next, press the Right arrow on the arrow pad to select the [Setup] icon. Using the Up or Down arrow, navigate to the menu item depicting a clock. Press the [OK] button to access the clock settings feature.
Set the year, month, day, hour, minutes and date format using the following procedure: Use the Up and Down arrows to select values, and press the Right arrow to advance to the next item. (The FE-170 uses a 24-hour clock.) When all information has been entered, press the [OK] button to set the values. Press [MENU] twice to exit the menu.
To set the time precisely, with the cursor on either "minutes" or "date format," press the [OK] button as the time signal strikes 0 seconds.
The date and time settings will be returned to the factory defaults if the camera is left without batteries for approximately three days. Custom settings may be canceled more quickly if the batteries were only loaded into the camera for a short time before being removed. Before taking important shots, check that the date and time are correct.
Oct 22, 2012 | Olympus Fe-170 6.0 Mp 3x Optical Zoom...
How do I turn the flash on on my Nikon D70?
if u select mannual mode u have to press flash button,whitch is on left side below flash unit,if u select auto mode, flash itself elect when u half press the click button.
Mar 08, 2010 | Nikon D70s Digital Camera
How do I get consecutive shooting on my nikon DX? I need to take multiple shots of someone running so I can capture the movements but I don't know how to do this.
In any shooting mode, press the very bottom left button, it will change the display on the back to a darker color and you will be able to use your circular up, down, left and right buttons to select the shooting mode (It may show up as just a single square with an S in it). press the set button when that is highlighted and it will give you the option to select the single shot (the square with the s) continuous frame advance (looks like 3 pictures stacked) the timer and remote setting are also there. press set on the continuous frame advance and you are ready to rock at 3 frames per second!
Mar 16, 2009 | Cameras
Continuous mode
i think the frame rate is 1.3 frames per second.
Issue:
How do I set Continuous Shooting?
Solution: Setting Continuous Shooting mode PowerShot SD750 and SD1000.
Continuous Shooting In this mode, the camera shoots continuously while the shutter button is held down. Recording ceases when the shutter button is released. In addition, under the following conditions, continuous shooting can occur at a consistent interval until the SD card is full*.
  • A resolution and compression combination other than 145.gif and 129.gif is selected.
    * If continuous shooting suddenly stops, the SD card may be full.
Continuous shooting is available in all modes except 171.gif[AUTO], stitch_assist_icon.gif[Stitch Assist], coloraccentdropper.gif[Color Accent] and colorswapdropper.gif[Color Swap].
To set Continuous Shooting
  1. Press the cont_icon.gifbutton to display cont_icon.gif.
  2. Shoot the image.
    The camera will continue to record successive images while the shutter button is fully pressed. Recording will cease when the shutter button is released, the card is full or the card does not support a write speed to allow continuous shooting to continue.
To Cancel Continuous Shooting
  1. Press the cont_icon.gif button twice to display single_icon.gif.
caution_a70.gifTo enhance the continuous shooting performance when you suspect the speed has dropped, you are recommended to format the SD card in the camera (Low Level Format) after you save all its images to your computer. note_icon_a70.gif
  • The interval between shots may lengthen slightly when the camera's built-in memory fills.
  • If the flash is firing, the interval between shots will lengthen to accommodate the flash's charging requirements.
Feb 18, 2009 | Canon PowerShot SD1000 Digital Camera
Please help!
Try going into the M(anual) mode on the selector dial and then turn off the flash (press the right side of the controller button until you see the lightning bolt with a bar through it). The macro shooting option should still be available in the manual mode.
Apr 17, 2008 | Canon PowerShot A460 Digital Camera
CANNON SURE SHOT 80U
1. With power off, press the MODE button to select the DATE mode.
2. Press the zoom out (three trees) button for more than two seconds to enter the date/time set mode.
3. Press the zoom out (three trees) button to select year, month, day, hour, or minute (selected number will flash).
4. Use the zoom in (one tree) button to advance the number.
5. Repeat steps 3. and 4. to set each value.
6. Press the zoom out (three trees) button until the colon (in the hours:minutes) is flashing. When the colon stops flashing, date and time setting is completed.
7. Press the MODE button and the power will switch off.
Jan 22, 2008 | Canon Sure Shot 80U 35mm Point and Shoot...
How do I change the date? I don't have a manual.
Jan 13, 2008 | Canon Sure Shot Z180u 35mm Point and Shoot...
PENTAX IST DS PROBLEM WITH INTERNAL FLASH
First make sure the camera is not set to No Flash on the shooting mode dial.Also, in P, Tv, Av or M modes the flash reverts to manual and must be raised manually by pressing the button next to the viewfinder.
Jan 11, 2008 | Pentax *ist DS Digital Camera
Date and time
Nov 07, 2007 | Canon Sure Shot 80U 35mm Point and Shoot...
How do you set the time on the Canon sure shot 80u
Sep 10, 2007 | Canon Sure Shot 80U 35mm Point and Shoot...
Canon EOS Digital Rebel XS / 1000D IS Digital Camera Logo
74 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
