Question about Polk Audio PSW10 Subwoofer
Best hook- up Polk psw10 sub woofer to yamaha rx-v663 receiver
I have one rca subwoofer connection on amp and a left & right rca on speaker. I would assume a y connector would be the answer. I cannot fine a 1 to 2 rcay connector, they all seem to have a 3.5 mil. plug at one end. Is there better way to hook this up?
    Scholar:
  • 93 Answers
You will not need to y connect your subwoofer, if you have only one RCA sub out on your receiver the other end of the RCA connector cable goes into the left input on most powered subs, there is no loss of signal, the option exist as some receiver do sport a double RCA sub out.
Posted on Feb 12, 2009
Have jvc rx-2020v receiver with mono rca out for sub and trying to hook it up with polk audio rm 1000 w sub woofer with +/- terminals for both left ane right channels plus blue terminal(?). How to?
Your Polk Audio subwoofer is a passive sub and your JVC mono output is for connection to a powered sub. If the JVC does not have an amplified output for a passive sub, you'll either need to get an amplified sub, a different receiver, or buy a dedicated mono subwoofer amplifier.
Oct 14, 2016 | JVC Audio Players & Recorders
Can I add Polk Audio PSW10 10" Powered Subwoofer, 35Hz-200Hz, 50W Continuous Power, Single with my Yamaha ATS-1050 Sound bar?
Yes. Connect a standard rca cable from the audio out jack of your yamaha to the input of the Polk sub.
Aug 18, 2016 | Yamaha Audio Players & Recorders
No sub woofer volume
Make sure Subwoofer power is on and connected with RCA cable in correct place.
Go into setup of "Speaker setup" and select 5.1 setup. Activate subwoofer to YES if setting is No.
On some Amps you need to select front speakers to SMALL even if you have large speakers to enabled subwoofer.
Sep 08, 2014 | Yamaha RX-V375 5.1 Channel Home Theater...
My receiver has one pre-out will a psw10 work
yes but a sub woofer out is better. You may have to crank up the sub response. If it has a level on the sub with a crossover set the cross over to around 120hz. And set the bass on your receiver as you feel appropriet.
Nov 09, 2013 | Polk Audio PSW10 Subwoofer
Psw111 hook up to vsx-522 subwoofer
Just use one of those jacks. Then turn the frequency select dial all the way up. This will work just as well.
Apr 21, 2013 | Yamaha 5.1-Ch. Surround Sound Home Theater...
Subwoofer
Without being able to access the receiver in person, the best advice I can give you is to sit down with your user manual and follow the instructions. You'll find, starting on page 85, the necessary settings for hooking up a subwoofer to the receiver. If you don't have the manual, you can obtain a pdf file at Yamaha.com: http://www.yamaha.com/yamahavgn/Documents/YEC/AV_Receivers/Manual/RX-V663_U-1.pdf
May 16, 2010 | Yamaha RX-V663 Receiver
I am trying to hook up a powered sub woofer to a yamaha rx-v461 and i dont know what cables go where on the back of the sub there are two speaker ports and there are two plug ins but each speaker port has...
Your subwoofer probably has both high-power inputs and "normal"low inputs. The first are for receivers, which don't have link-level output for sub, so they are able to take already amplified signal as input.
You need to use link-level input of your sub and connect it to subwoofer-output of your receiver. The output is marked as OUTPUT - Subwoofer and is black-color RCA plug (don't confuse with subwoofer INPUT under MULTI CH INPUT).
Receiver has only mono output for subwoofer. If your sub has stereo input (white/red RCA plugs), connect just the left channel to the receiver, it will still work.
Don't connect anything to the speaker output on the sub, you don't need that.
Sep 28, 2009 | Yamaha RX-V461 AV Receiver
Yamaha Dsp-A1000 5 ch amp Bought a used amp will be hooked to an awia reciever and speakers also have two subwoofers need help to install correctly witch connections to use
if you wanted to use your receiver as your controller and source then try to find out the receivber has got a bridge (jumper) between the pre-amp stage and the power amp stage. if your receiver does not have that, then you can just connect your receiver tape record out to one of your DSP inputs. subwoofers, the DSP has got a sub woofer out connector. you can use that (RCA type) to your sub woofers. put in series because DSP has got only one output for sub. or, you can connect your subs directly to the mains speakers, parallel connections. maybe one sub to your left and the other to your right channel.
Jul 24, 2008 | Yamaha DSP-A1000 5-Channel Amplifier
Polk Audio PSW10 Subwoofer Logo
1,982 people viewed this question
Top Polk Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
kdigby
kdigby
Level 1 Expert
Are you a Polk Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
