Question about HP DeskJet 5652 InkJet Printer
HP 5652 And Windows Vista
After installing Vista only the first page can be printed in black. The following pages are purple and red. When printing pictures only half of the picture is fine - the rest is purple and red.
It does not help to choose to print only in gray colour.
Can You help with this problem - It is not the carthrige because the printer can print correctly when I use my laptop with XP.
  • rasmus581 Feb 12, 2009
    No I am not sure - the only driver I can find is the one Vista finds.
    I cant find a solution (link to another driver) in your link.
    President:
  • 2,692 Answers
You know for sure that the VISTA driver is the correct and most updated on for your printer and version of VISTA, 32 or 64?
http://h10025.www1.hp.com/ewfrf/wc/product?product=304442&lc=en&cc=us&dlc=en&submit.y=4&submit.x=6〈=en&cc=us
Posted on Feb 12, 2009
  • Thomas F. Schneider Feb 12, 2009
    Wow! You did not see "Software and driver down loads"on the link I gave you? It was even specific for your model printer.
        Here I will link the specific page but you still have not stated if it is 32 or 64 bit VISTA.  It is one of the top two but you wil still have to know if you are running 32 or 64 bit. Go to "My computer" and hopefully it will tell you which version of VISTA you are running.
    1-Download the correct driver.
    2, Disconnect the printer then remove the software from the "add and remove" or "remove printer"  part under windows.
    3. Install the new software/driver that you downloaded.
    4. Hook the printer back up.
       The reason that I had asked the question instead of stating a solution is that I did not want the low score that you gave me anyway for attempting to help you, without the needed information to do so.
     http://h10025.www1.hp.com/ewfrf/wc/softw...
How to print test page for HP deskjet 5652?
Press and hold down the Resume button until the printer starts printing a self-test
page, then release the button.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Apr 16, 2011 | HP DeskJet 5652 InkJet Printer
Printer won't print in black -- changed the cartridges. Nothing comes out on the page when I try to print.
the inkjet nozzle or printhead may be clog.
you will need to run the clean inkjet tool atleast 5-10 times to clear the inkjet nozzle.
  1. Make sure there is plain white paper loaded in the input tray.
  2. Open HP Solution Center:
    • Windows XP: Click Start , click All Programs , point to HP , and then click HP Solution Center .
    • Windows Vista: Click the Windows icon (c01319360.gif ), click All Programs , point to HP , and then click HP Solution Center .
    HP Solution Center opens in a separate window.
  3. Click Settings (c01495176.gif ).
  4. Under Print Settings , click Printer Toolbox . The printer Toolbox opens in a new window.
  5. Click the Device Services tab.
  6. Click Clean the Printheads .
  7. Follow the on-screen prompts until you are satisfied with the quality of the output, and then click Done . When the cleaning is complete, the product prints a test page. Figure 13: Example test pagec01496479.gif
  8. Recycle or discard the test page.
Mar 06, 2011 | HP Photosmart C6380 All-In-One InkJet...
Only prints in black. Windows 7 driver update
Print a 'Configuration Page' from the printers <Information Menu>
Press the green tick button to enter the menus, and use the <, > arrows to scroll thru menus.
Then press the green tick button to select...
If, as I suspect, your Configuration Page is in colour, and looking ok - the the problem is in your computer - Printer Driver setup, or Windows......
Like all the others
Have fun.
Dec 21, 2009 | HP LaserJet 2605DTN Color Printer
Message "Black cartridge is not compatible with this printer"
my problem is i upgrade my operating system from windows xp to windows vista and my printer ishp deskjet 5652. whenever i print my documents it became smaller the actual size. may i know how can i solve it.
Feb 15, 2009 | HP DeskJet 5652 InkJet Printer
I have a HP TouchSmart computer. The Brother MFC 9160 printer won't print. It will print from my HP Lap Top. The printer lights up indicates receiving data. However, only one blank page comes out.
moz-screenshot.jpgTry unplugging printer USB and reinstalling printer software from disk.
  • Unplug printer USB.
  • Go to control panel >> installed printers in Windows and remove (delete ) any installed printer from printer list.
  • use the disk and run the install file.
  • Follow driver installation wizard.
  • Plug back printer when prompted from installation wizard.
Note:some printerdoes not work on Vista, if you do not find any driver download for Vista on your model page, that means your model is not Vista compatible.
Nov 24, 2008 | HP Office Equipment & Supplies
Hp psc 1210 not working in vista - but diagnostic utility shows all ok - and prints test page
Here is the full-write up on the HP PSC1210. Read through this thoroughly to ensure that you follow all the steps to make it work in Vista, since there is no Vista native driver.
Hope this helps - remember to rate :)
Oct 02, 2008 | HP PSC 1210 All-In-One InkJet Printer
Internal test page fine, external prints black in blue
before you print, you have to check your options.
For example, if you want to print black and white, when you select PRINT from the menu, you click on PROPERTIES to the right side or bottom side, depending on which windows you use, then select grayscale/black and white, etc in the options that will follow to correctly use your ink, you can always REMOVE the ink from your printer as you only want to print black and white or non color pages.
I hope this helps you.
ManOwar
Jul 12, 2008 | HP DeskJet 845c Printer
Printer Prints Blue Test Page but not in black
Your color cartridge is probably empty as well. you can go to>control panel>printers and faxes> your printer >right click on preferences then click on services. Do all of the maintenance possible on your cartridges and see if that helps. Are your cartridges HP cartridges or generic refills?
Apr 22, 2008 | HP DeskJet 810c InkJet Printer
5652 and Vista - duplex print not working
In Vista the default s the duplexer is "not installed". Go to Start, Settings, Control Panel, Printers, double-click on the Deskjet, Printers, Properties, Device Settings and set the duplexer to "Installed".
If the duplexer prints the back side upside down in Vista once it is enabled you can get a patch as described here.
Regards,
Bob Headrick, Microsoft MVP Printing/Imaging
Feb 19, 2008 | HP DeskJet 5652 InkJet Printer
HP DeskJet 5652 InkJet Printer Logo
166 people viewed this question
Ben Johnson
