Question about Bosch 24 in. SHU53 Built-in Dishwasher
Bosch Dishwasher pump keeps emptying
The pump keeps working on this dishwasher. The float switch is not faulty and there is no water in the sump. Any ideas please?
  • 3 more comments
  • cerbop Feb 11, 2009
    The pressure switch sounds like an idea. Is it a white unit with several connectors and a microswitch in the middle of it to the right hand side of the motor?
    This
    The pressure switch sounds like a good idea. Is it the white unit to the right of the pump with a microswitch in the middle of it?
  • Anonymous Mar 27, 2014
    its not getting water but if I disconnect the hose and connect again it will work... until next time!
  • Anonymous Mar 28, 2014
    The float that switches on the pump doesn't float so the unit doesn't empty properly. The pump does work if you lift it by hand.
  • 32 Answers
Disconnect the power to the unit. Remove the lower access panels and check the tray under the dishwasher. You will probably find it is full of water. Use a towel or a sponge to remove the water. There is a float that will stop the operation of the unit and run the pump if water is in this tray. Test the unit. If there are no leaks, check the drain hose under the sink. THE DRAIN HOSE MUST RUN UP TO ABOVE THE TOP OF THE MACHINE THEN TO THE DRAIN. If the hose is not set up like this, water from the sink drain will flow into the dishwasher and overflow into the tray under it.
If there is no water in the pan under the dishwasher there may be a problem with the pressure switch at the side of the pump housing but the only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance.
Go here for Bosch Dishwasher Parts: http://www.repairclinic.com/Bosch-Dishwasher-Parts
www.RepairClinic.com
Posted on Feb 11, 2009
My dishwasher keeps flashing i30 and wont start what shall i do
In your case occurred intervention of anti-flooding system.
Displayed Error is "i30"
The cycle is interrupted and the drain pump switches on.
Could be:
Water leakage from the tub - sump and various
connections (pump, upper spray arm duct etc.);
floating sensor blocked mechanically; microswitch
faulty; fill solenoid blocked mechanically; circuit
board faulty (solenoid triac short-circuited); wiring
faulty.
First, try to tilt dishwasher and see if leaking water from its bottom.
This is most commonly occurs.
Dado
Jan 20, 2014 | Electrolux Genuine ZANUSSI ZDF511...
Hotpoint Built-In Dishwasher HDA3600DWWmy dish
there is an electronic solenoid near where the drainhose connects to the sump that changes the waterflow direction from recirculate(washing), to evacuate (draining). this is electronically controlled by the timer. you can test the power leads at the solenoid for voltage when it sould be draining. if none then the timer is faulty. if there is voltage then the solenoid is faulty. if the solenoid is engageing, then the water diverter is faulty. if the water diverter is broken, replace the dishwasher.
overflowing is another problem of its own. the water level float/ sensor is not working and could be caked with detergent. work the float from the inside of the dishwasher, it should move freely. if so, then there is a switch connected to the float on the underside. test it with an ohmmeter. if bad replace it. if it is an electronically timed water level control then it could be a problem with the timer as well, but with hotpoint they are usually manual.
Sep 27, 2013 | Hotpoint Dishwashers
Bosch dishwasher not completing its cycle
Sounds to me like you have a problem with with the overflow switch or float. To access the switch or float you must pull d/w out and remove the left side panel(as you face the d/w).
Mar 29, 2010 | Bosch Dishwashers
Bosch SGS5332GB dishwasher. drain pump runs all the time
There is a float under the machine that tells the pump to shut off. If the float is stuck or bad, the machine will keep draining. I am including a web site that might help. Bosch Dishwasher That Will Not Stop Draining Hunker
Nov 06, 2017 | Bosch Dishwashers
Drain pump runs continuously. Nothing else happens!
Water had accumulated in the sump - a plastic tray at the bottom of the dishwasher which catches any leaked water. This operates a float switch which makes the drain pump run all the time. The fix was to tilt the dishwasher backwards to drain away the water. It isn't filling up again, so I'm not sure where the water came from, but I'll keep an eye on it!
May 17, 2009 | Bosch Dishwashers
Viking dishwasher that does not stop draining cycle - keeps on running
I have the same thing, unit pump keeps running, when I pulled it from under the cabinet, if you tilt it back a little it stops, as soon as you lower it back down the pump starts to run again. Getting code as too much water in the tank even though it is empty. PLEASE HELP!!!!!
May 17, 2009 | Viking DFUD042 Built-in Dishwasher
Bosch SHU43C Dishwasher
Is there no water coming in( hear no water at all) or no water NOT staying in ( drain motor running) ... the float switch is a safety to keep the dishwasher from flooding ...turns on the drain motor as soon as the door is closed..
I could check the control and see if you have power to the water valve.. maybe a control problem if no power..
Sep 22, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
SHU43 running constantly
Intrrnal leak into base of appliance will make drain pump run constantly.
If appliance fills then dumps water with drain punp then keeps filling/draining sequence then the flow meter could de faulty.
Call in engineer.
Paul Winn Appliance Services (Cumbria)
Apr 02, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch 24 in. SHU53 Built-in Dishwasher Logo
920 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
