Question about Toshiba Satellite A100-S8111TD Notebook
JUMPER SETTNGS WHAT ARE NTHE JUMPER SETTINGS ON THE TOSHIBA A100? I FORGOT MY PASSWORD AND NOW I'M LOCKED OUT OF MY LAPTOP. PLEASE HELP
  • Toshiba Master
  • 4,806 Answers
Hi there
Sorry there are no jumpers on a toshiba laptop motherboard, if its the boot password you have forgot then you are in big trouble!!!! but you can try this:
  1. Remove Memory Cover from base of machine
  2. Release & remove right side Memory Module
  3. Lift black plastic insulation
  4. Locate & short PAD500 Pin 1 & 2 together
  5. Power on machine while still shorting Pin 1 & 2
  6. As soon as the TOSHIBA logo appears, remove short
  7. If machine boots, password has been removed
Good Luck and thanks for using Fixya!!!
Posted on Feb 11, 2009
I forgot my passwords
Hi ,
are you talking about your cmos password ? and your log in password?
for cmos password you need to open up your laptop and find a jumper pin that says "PASSWRD" and remove this jumper ........
for your other password , use another computer and google password
recovery programs , copy ro dvd or cd and follow the instructiuns that comes with the program good luck Roy
Feb 18, 2012 | Toshiba Computers & Internet
I have laptop toshiba sat a100-467 and i forgot my bios password is there any solution so that i can bypass the bios passwork or remove
For you to be able to remove the BIOS password, you will need to reseat the CMOS battery on the Motherboard, that will reset the BIOS password as well.
Hope this will help... Please rate...
Jan 20, 2011 | Computers & Internet
FORGOT MY BIOS PASSWORD JUST WANNA RESTART TO FACTORY DATE PLZZZZZZZZZZZZZZZZ HELP ME OUT. JUST WANT TO SET IT TO OUT THE BOX SETTING
FOR TOSHIBA BIOS PASSWORD
It's very Easy.. remove ram cover then remove ram try to find a very small jumper near the ram bank .if u didn't get remove the sticker which is under the ram bank u will see a very small jumper .short the jumper for 15 second with flat screw driver.. if same ..do again but keep short jumper and turn on laptop for 15 second .... if this solution not help full.. then remove the battery cell and wait for 15min. Thanks
Dec 06, 2010 | Toshiba Satellite L505ES5018 Laptop
I have laptop Dell Inspiron 6400 and i forgot the Bios Admin password. can you help me please
WARNING: Some BIOS configurations will lock you out of the system completely if you type in an incorrect password more than 3 times. Read your manufacturers documentation for the BIOS setting before you begin typing in passwords.
Award BIOS backdoor passwords:ALFAROME BIOSTAR KDD ZAAADA
ALLy CONCAT Lkwpeter ZBAAACA
aLLy CONDO LKWPETER ZJAAADC
aLLY Condo PINT 01322222
ALLY d8on pint 589589
aPAf djonet SER 589721
_award HLT SKY_FOX 595595
AWARD_SW J64 SYXZ 598598
AWARD?SW J256 syxz
AWARD SW J262 shift + syxz
AWARD PW j332 TTPTHA
AWKWARD j322
awkward
AMI BIOS Backdoor Passwords:AMI BIOS PASSWORD HEWITT RAND
AMI?SW AMI_SW LKWPETER CONDO
Phoenix BIOS Backdoor Passwords:phoenix PHOENIX CMOS BIOS
Misc. Common PasswordsALFAROME BIOSTAR biostar biosstar
CMOS cmos LKWPETER lkwpeter
setup SETUP Syxz Wodj
Other BIOS Passwords by ManufacturerManufacturer Password
VOBIS & IBM merlin
Dell Dell
Biostar Biostar
Compaq Compaq
Enox xo11nE
Epox central
Freetech Posterie
IWill iwill
Jetway spooml
Packard Bell bell9
QDI QDI
Siemens SKY_FOX
TMC BIGO
Toshiba Toshiba
Toshiba BIOS
Most Toshiba laptops and some desktop systems will bypass the BIOS password if the left shift key is held down during boot
IBM Aptiva BIOS
Press both mouse buttons repeatedly during the boot
Using the Motherboard "Clear CMOS" Jumper or Dipswitch settings
Many motherboards feature a set of jumpers or dipswitches that will clear the CMOS and wipe all of the custom settings including BIOS passwords. The locations of these jumpers / dipswitches will vary depending on the motherboard manufacturer and ideally you should always refer to the motherboard or computer manufacturers documentation. If the documentation is unavailable, the jumpers/dipswitches can sometimes be found along the edge of the motherboard, next to the CMOS battery, or near the processor. Some manufacturers may label the jumper / dipswitch CLEAR - CLEAR CMOS - CLR - CLRPWD - PASSWD - PASSWORD - PWD. On laptop computers, the dipswitches are usually found under the keyboard or within a compartment at the bottom of the laptop.
Please remember to unplug your PC and use a grounding strip before reaching into your PC and touching the motherboard. Once you locate and rest the jumper switches, turn the computer on and check if the password has been cleared. If it has, turn the computer off and return the jumpers or dipswitches to its original position.
Removing the CMOS Battery
The CMOS settings on most systems are buffered by a small battery that is attached to the motherboard. (It looks like a small watch battery). If you unplug the PC and remove the battery for 10-15 minutes, the CMOS may reset itself and the password should be blank. (Along with any other machine specific settings, so be sure you are familiar with manually reconfiguring the BIOS settings before you do this.) Some manufacturers backup the power to the CMOS chipset by using a capacitor, so if your first attempt fails, leave the battery out (with the system unplugged) for at least 24 hours. Some batteries are actually soldered onto the motherboard making this task more difficult. Unsoldering the battery incorrectly may damage your motherboard and other components, so please don't attempt this if you are inexperienced. Another option may be to remove the CMOS chip from the motherboard for a period of time.
Note: Removing the battery to reset the CMOS will not work for all PC's, and almost all of the newer laptops store their BIOS passwords in a manner which does not require continuous power, so removing the CMOS battery may not work at all. IBM Thinkpad laptops lock the hard drive as well as the BIOS when the supervisor password is set. If you reset the BIOS password, but cannot reset the hard drive password, you may not be able to access the drive and it will remain locked, even if you place it in a new laptop. IBM Thinkpads have special jumper switches on the motherboard, and these should be used to reset the system. Also, Hirens Bot CD has Bios password crackers too. Good luck.
If this helps you resolve your problem, please
consider giving a good rating and a quick thanks
or good job.It will help me as well Thank you.
Oct 26, 2010 | Dell Inspiron 6400 Notebook
My laptop shows an error of Invalid password.Kindly provde me a solution to reset the password so that I can fix this problem.
It's very Easy.. remove keyboard then remove wirless card ... under the wirless card u can see small jumper short the jumper for 15 second with flat screw driver.. if same ..do again but keep short jumper and turn on laptop for 15 second .... Thanks
Sep 12, 2010 | Toshiba Satellite A100-S8111TD Notebook
Toshiba A100, how to clear cmos?
There may be a jumper setting you can use, check online for the technical manual or white papers. In most cases there will be a diagram or pictures to help you locate it.
Apr 22, 2010 | Computers & Internet
Hi I forgot my password for toshiba satellite 205 cds , for bios . What I can do ? Please HELP Emanuel
You can reset bios password with 2 method.
(1) open back cover of laptop then find motherboard .Pull cmos cell from motherboard for 15 minutes then again put it in it's position .then it not ask for password.
(2)You can clear password with jumper settings find jumper on motherboard named clear cmos it has 3 pin .1-2-3
Put jumper in 2-3 position then again put it in 1-2 position then check .
Let me know if you need more assistance.
Thanks.
Dec 25, 2009 | Toshiba Satellite A205-S4617 Notebook
Forgot my bios password on my toshiba laptop can't get into my computer please help
You'll have to actually partially disassemble the machine.
You need access to the motherboard to remove the CMOS battery so you can reset the password.
If you are uncomfortable with taking the computer apart, better get someone to do it for you.
Dec 13, 2009 | Toshiba Satellite A100-S8111TD Notebook
Forget password
you will need to clear the BIOS password by:
On the computer motherboard locate the BIOS clear / password jumper or dipswitch and change its position. Once this jumper has been changed, turn on the computer and the password should be cleared. Once cleared, turn the computer off and return the jumper or dipswitch to its original position.
on a laptop computer the location of the dipswitch (almost never a jumper) can be under the keyboard or on the bottom of the laptop in a compartment such as the memory compartment.
Alternatively you can locate the CMOS battery on the motherboard a remove it for at least 10mins allowing the computer to lose all of its information but please not that this does not work on all computers
Goodluck
Aug 26, 2008 | Toshiba 2405-S221 Notebook
Toshiba Satellite A100-S8111TD Notebook Logo
139 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
