Question about Electrolux UltraLux 2000 Bagged Canister Vacuum
Older electrolux canister brush will not turn used reset button
I have a older electrolux canister the brush will not turn used the reset button without success.Brush spins manually (not frozen), but no power seems to be reaching the 'head'.
    Sergeant:
  • 326 Answers
How to disasseble the electrolux canister
This procedure works on almost all Electrolux plastic body canister vacuums. Caution: Always be sure that your machine is unplugged from the electrical outlet before servicing.
Remove the hose from the front cover and pull the electric cord out 2 or 3 feet. Remove the paper bag. Place the vacuum upside down on a work bench with some kind of pad underneath. Open the bag door and pull the end of the soft pastic rail cover out slightly (on both sides) to expose the rigid plastic side rails underneath. If you look directly at the side rails from the front you will see that the ‘T’ shaped part of each rail slides into a channel that locks the top and bottom halves of the machine together. The rails have notches or barbs on the last half inch or so which keep the rails from sliding out. You will need to get these notches away from the channel by sliding a narrow flat blade screw driver in between the top of the ‘T’ and the channel. Just tap it in and leave it there while you pull the rails out with a pair of needle nose pliers. Next, take a look at the bag door hinges. They have a square hole in the center through which a small tab from the bag compartment pokes through. Take a larger flat blade screwdriver and carefully pry the edge of the hinge away from the tab. This will release the bottom section (which is really on top now of course). If you remembered to pull out the two or three feet of cord before you started then you should now have enough slack so that you can lay the bottom section aside.
If you plan to do any electrical work be sure to mark the locations of the wire connections. Electrolux Service Centers are the only source of wiring diagrams
Posted on Feb 11, 2009
  • 679 Answers
It seems there is some fult in the control unit.
check out the all wireing in the unit.
Thnks
    Sergeant:
  • 250 Answers
Check out the internal motor is it getting short or any wires got loose from the motor.
    President:
  • 2,110 Answers
Usually you will find a brush assembly which includes the bearings. You could also be hearing the belt jumping across the brush gear if the belt is bad. If you order the parts online, you may want to get a brush and belt, since a belt won't be that much more money anyway. Aftermarket Aerus (formerly Electrolux) parts can be suspect sometimes, so I would suggest finding a dealer. You can go to their website to find the closest store. aerusonline.com Good Luck!!
  • Electrolux Master
  • 19,396 Answers
You need to test the brush contacts using a multimeter to see if there is voltage.
  • Ginko
    Ginko Feb 11, 2009
    The problem is usually with the wiring harness leading to the brush, a contact gets interrupted and the brush does not work.
    The technician will check if there is voltage on the contacts to the brush tool using a multiveter like this one: pocket MultiMeter .
    If there is no voltage the unit must be disassembled to fix the wiring problem.
Reset button on epic 8000 electrolux canister vacuum
Check the drive belt. could be broken. Not sure about reset button but i would say it has to do with the belt.
Jan 28, 2018 | Electrolux Vacuums
Where is the reset button on my electrolux guardian canister
There is a reset button on the power nozzle...not sure I heard of the vacuum canister has a reset button....hum.
Feb 15, 2013 | Electrolux Guardian Bagged Canister Vacuum
Hello! I have an Electrolux Ultralux 2000,
Sounds like the belt on the beater brush has broke.replace the belt on the beater brush.
Dec 06, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Electrolux vacuum power bar not turning
First thing is to push the circuit breaker button(reset button). If that dosen't work, check the belt. It could be broken.
Jul 10, 2009 | Electrolux Guardian Bagged Canister Vacuum
Power nozzle motor will not turn on
Try hitting the reset button,It is a small button on the top of the brush and make sure the switch is turned on on the handle.
Jun 22, 2009 | Electrolux Epic 6500 Vacuum
I have a Electrolux , EL6988 Canister Vacum, howeveer the brushes and motor will not run when turned on. I have take the plates and cleaned around the brushes, but it will not come one. The vacum comes on...
Turn the brush unit upside down, so you can see the brush roller. Then, with the brush roller positioned nearest to you, you will find the reset button close to the rear edge, near the wheel that's on the right hand side as you look at it.
Good luck! I hope this works for you. I value your feedback. Please remember to rate this response.
Feb 19, 2009 | Electrolux UltraLux 2000 Bagged Canister...
EL5 (large) powerhead
There is a no filter safety device part #1130912-01, maybe the new filter isn't in quite like it should be or this device has gone bad. Also check the brush roll and make sure it turns easily, if not then that could be the cause.
Nov 27, 2007 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Electrolux UltraLux 2000 Bagged Canister Vacuum Logo
37 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
