Question about Fedders A6Y12F2B Y Chassis Room Air Conditioner w/ 12,000 Cooling BTUs & Electronic Controls
Does not start, manual nor remote
Electric is hot when tested with a lamp
used a month ago with no problem
unable to get warranty service from Fedders
olease advise
Found fedders is bankrupt and another company is using the name
the tech there told me about the reset button on the other side of the plug, and the reset button worked
thanks
ALAN
Posted on Feb 12, 2009
When engine warm, turns over awhile before starts. Fine when cold. Chevy garage unable to find problem. 100,000+ miles. They replaced fuel pump 2 months ago. Still happens.
It sounds like a mass air flow sensor or coolant temp sensor or maybe a crankshaft position sensor problem ! Need to have hooked up to a oscilloscope check for a glitch in the electrical wave form ! Or do a fuel injector balance test ! Bosch CIS Fuel Injected Engine Cold and Hot Start Problems How to Troubleshoot Warm Starting Problems
Apr 01, 2015 | Cars & Trucks
I have a PowerStar tankless electric water heater, model #44-557710 and it was replaced about 3 months ago. This morning I had hot water and this afternoon I do not. When I call for hot water a red light...
Call Bosch. And exercise your 10 year parts warranty rights.
Copy following link for Bosch power star manuals:
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html#Ariston
Check circuit breakers, fully off and then fully back on. Test if voltage is at least 80% rating plate on unit. Check that temperature dial is set correctly. Call for service again.
Don't install tankless computer that heats water. You cannot fix this computer yourself, and they are problematic for owners.
Go to Lowes right now, spend $285 and buy tank-type electric water heater, roll it into your house, and save money, since the electric tankless computer heater costs average $100 more per year to operate than tank-type heater for average family of 4.
Tank type heater can be repaired by homeowner same day for $25 using off-the-shelf parts from hardware store. And that empowers the regular guy, and gets you off the junk tankless treadmill.
Gene
Aug 03, 2013 | Powerstar Water Heaters
I just replaced the starter on my 1989 Subaru DL 4DR Wagon and it started fine, now less then 2 months later, all it does is click when I tuurn the key. Do I need another starter this quickly? Could
Make sure battery has a full charge and battery connections all good.
At the starter motor, two voltage circuits. One comes from the battery, hot all the time. The other circuit goes hot with key in the crank position. The starter motor grounds through the engine block. You could use a test lite to check voltage at starter motor. There could be safety issues testing at starter motor, make sure tranny is in park or neutral and functional parking brake is set. If automatic tranny there is an inhibit switch, I usually call it a neutral switch. There could be other issues?
Oct 15, 2017 | 1989 Subaru DL
I HAVE A FEDDERS AIR CONDITIONER MODEL AED24E7F-C THIS UNIT TRIPS THE RESET BUTTON ONCE IN A GREAT WHILE IT RUNS FOR HOURS OR DAYS ON END AND THEN TRIPS. IT TAKE AWHILE AFTER THAT BEFORE I CAN RESET...
The reset button is part of the cord. The cord has built in arc detection. This is a complex circuit that monitors the unit and senses potentially dangerous sparks or arcing inside the internal components of the A/C (motors, switches, etc.) It sounds like the problem is getting worse - as they usually do. Sparking and arcing happen when dirt, corrosion, etc. accumulates and can result in pitted contacts. All of these conditions only make the sparks and arcs worse. Page 1 of the manual (left column) says this:
If the Arc Detection Device has tripped, the
reset button will pop up.
Follow these steps to reset the Arc Detection
Device:
1. Unplug unit from electrical outlet
2. Press the reset button
3. Plug the unit back into electrical outlet
4. Check to see if power has returned to the unit
Testing
You should test the Arc Detection Device
equipped power cord monthly, after every major
electrical storm, or if power to your Room Air
Conditioner has been interrupted.
Follow these steps to test the Arc Detection
Device:
4. Press test button. Unit should trip and reset
button will pop up.
5. Press reset button again for use
If above test fails, stop using the air
conditioner and contact customer service by
calling the following toll-free number:
1-800-332-6658 or email:
customerservice@fedders.com
I hope this helps & good luck!
Aug 30, 2011 | Heating & Cooling
Need to reset lamp. replaced lamp and installed new lamp.
Press RESET, <, >, ENTER keys on remote within 5 seconds to reset lamp timer.
Jul 29, 2010 | Sony VPL-CX86 Multimedia Projector
I am unable to start my Homelite blower, it is just out of warranty and has not been used since being returned for repair (whilst still in warranty 4 months ago-same fault), I have replaced the spark plug-...
I believe your carburetor needs to be rebuilt. It has very thin rubber diaphragms that meter in the fuel. If the diaphragms get hard (from sitting with gas in carb or hot weather) they won't allow fuel into cylinder to produce an explosion. if you need parts or more assistance email desertairrepair@aol.com
Feb 09, 2010 | Homelite Consumer Products Backpack...
Will not start when egine is hot on a hot day. Once egine cools down the car will start. Problem dose not seem to occure during the winter months. Car was serviced at dealership where it was purchased but...
You may either have a weak battery or the starter going out. Do a load test on the battery when it is hot.
Heat causes higher ressistance in all electrical circiuts the engine heat may be causing just enough for the battery to fail.
Jul 10, 2009 | 2003 Mercury Grand Marquis
Fedders A6Y12F2B Y Chassis Room Air Conditioner w/ 12,000 Cooling BTUs & Electronic Controls Logo
160 people viewed this question
Top Fedders Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
