Question about HP OfficeJet G85 All-In-One InkJet Printer
Feeds to many pieces of paper into feed Officejet G85
When I make one copy from glass, paper supply feed on front, it pulls through numerous paper 2, 3 somtimes 5 or 6 sheets with the copy wasting paper. Can this be fixed or adjusted? Thanks.
Bob Spang
Wakefield, MA
    Sergeant:
    Champion:
  • 237 Answers
Hey Bob,
Sounds like the pick up rollers and seperation pad could be the cause of this. They might need to be replaced
Posted on Feb 11, 2009
Black line going down page only when feeding paper through feeder
There should be a thin piece of glass to the left of the big glass that you put the original to be copied on. Clean the small glass very well and try copying again. If there is a spot on the glass, it will show up on the copy as a line.
Sep 06, 2013 | HP Officejet Pro 8600
HP G85 / Auto feed
You need first to take the printer apart and clean the rollers and make sure no foregn object is causing the problem and after that after cleaning and still have problem reller replacement maybe needed....
Oct 30, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
My hp g85 will not take paper from the "top load".
I don't know about why it is not acknowledging that you have placed anything up there to be copied, but when mine would not pull paper, I cleaned the rollers with Q-Tips and water or rubbing alcohol. It would then pull the paper through. I do this when it won't pull from the lower paper tray too. Hope it helps!
Jan 28, 2011 | HP OfficeJet G85 All-In-One InkJet Printer
I cannot get my copier to copy papers. Please refresh my memory on how the 5610 all in one copies. Thanx
We have a 6210 at work, must be similar though.
Make sure you have blank paper in tray, Put piece you want copy of face down on scan glass, close lid, hit copy, it takes a minute to wake up. Or put piece you want copied in auto-feed face up, hit copy, it takes a while to wake up, seems as though it is not working, then it will.
Jun 15, 2010 | HP Officejet 5610 All-In-One InkJet...
Printing works fine but copying or faxing results in large black lines across the whole page
You have a dirty scanner glass strip. If you open the cover like you are going to scan a book on the lft side you will see a strip of glass separate from the larger piece. This glass is the area use when you use the paper feed assembly. Dampen a piece of paper towel with window cleaner and wipe the glass strip. You may need to clean it several times if there is dried ink or something on it. Allow about 2 minutes to dry and then copy or scan something and it should be much better.
I hope this helps, If so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Jul 16, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Lines appear when making a copy using document feeder tray
If the lines are vertical (in the direction the ADF feeds, 11in long for 8 1/2 by 11) You can try cleaning the glass the scanner uses when it's using the document feeder. Pull up the top left part of the printer where the documents feed, there's a little rib in the middle of the side to help you do this, then simply pull up the assembly underneath with all the rollers in it, you should see about an inch of glass underneath and a centimeter long strip of white plastic on the assembly (this serves as the white background when feeding slimmer papers) Clean them both. I'd recomend any glass cleaner, just don't spray it in there, spray it onto a cloth.
Jan 16, 2009 | HP Officejet 6310 All-In-One InkJet...
Vertical paper feeder for the copier not grabbing next original sheet
I'm having a similiar problem. Can't consistantly feed one sheet at time. If i load several sheets it pulls all through, etc
Sep 03, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
Document Feed
first u switch off and switch on the machine, that time ur document feeder get rotating its not feeder problem. otherwise pls u check ur feeder driveres.
Jul 23, 2008 | Office Equipment & Supplies
Feeds more than 1 sheet
Yes, I have had the same problem at times. The best solution is to 'fan' the paper well (put air between the sheets) BEFORE putting it in the tray. Also, tap down the front edge of paper (that enters the printer) to align the sheets better. You can also clean the rollers with a damp rag to help traction. Hope this helps!
Apr 17, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
HP OfficeJect 7310 Uses 2 Pieces of Paper when Printing Fax
Sounds like the feed rollers need to be cleaned or replaced.
Dec 03, 2007 | HP OfficeJet 7310 All-In-One InkJet...
HP OfficeJet G85 All-In-One InkJet Printer Logo
110 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
