Question about HTC Touch P3450 Smartphone
Sync can not be started
This error comes up at the last moment just when I think it is gonna work, I have removed the program and statred from scratch 3 times
Sync can not be started because you are not able to log on to the network and access information.
    President:
  • 1,223 Answers
Try setting up ur device again from active sync in xp delete ur config and then re configure if vista then check WMDC mobile device centre do the same ur antiviurs software might be blocking this syc process try shutting down for a while firewall and antivirus see if it helps
Posted on Feb 20, 2009
Htc sync wont sync phone comes up with error 1001
Hi @fmarcoux260496. I have some troubleshooting steps for you that may get HTC Sync working again!
On your PC, go to Control Panel and click "Add and Remove programs" in Windows 7 and Windows Vista or "Programs and Features" in Windows XP. Double click HTC Sync and choose "Repair."
If Repair does not work and you still get the error, reinstall HTC Sync. To do this, click on "HTC Sync" and then click "Change" or "Change/Remove" and follow the on-screen instructions. Do this for "HTC BMP USB Driver," "HTC Driver Installer" and "Adobe Air" as well. Once that's done, go to http://www.htc.com/ca/support/amaze4g-videotron/downloads/ and download and install HTC Sync. It is under the heading, "HTC SYNC 3.0.5579 FOR HTC AMAZETM 4G ' 15.12.2011". Complete instructions can be found by clicking "More." This will also install the newest HTC drivers and the newest compatible version of Adobe Air.
After you've finished installing HTC Sync, connect your phone to your PC via USB. Select "HTC Sync" from the "Connect to PC" pop up on your phone, and the phone will search for and open HTC Sync!
If you're still seeing the error message, disconnect your phone and perform a soft reset, and then re-connect the phone to your computer. To do a soft reset, just turn the phone off and remove the battery for one minute, then re-insert it and turn the phone back on.
If you still experience problems, I recommend you contact my teammates in Customer Support. You can find their contact information at http://htc.com/support
Please check in and let us know how that helped!
Jun 01, 2012 | HTC Sensation 4G
Ipaq h2210 won't sync with desktop
Usually the simplest solution with Microsoft software such as active-sync is to uninstall it and install it again from scratch. When you reinstall it will ask you what programs you want to sync with, your old PIM software has been lowered in priority in favour of Outlook because MS think everyone should want to use it, so it's often easier to start using Outlook as your main PIM.
Aug 13, 2007 | HP iPAQ H2210 Pocket PC
Blue screen comes up
To fix the blue screen error try these steps:
1. turn off the computer unplug all the device plugged with the computer except keyboard and mouse.
2.restart the computer and start pressing the F8 the moment you turn on the computer you will get windows advanced boot options select last known good configuration and press the enter key twice. if it works fine if not then
3.restart the computer and start pressing the F8 the moment you turn on the computer you will get windows advanced boot options select safe mode and press the enter key twice after that let the computer boot up when its up go click on start go to all programs and then go to accessories then go to system tools and then select system restore.
you will get a window select the day when your computer was working properly. follow the screen prompts this should help you.
If not please reply back for future help.
Mar 13, 2010 | Dell Latitude D600 Notebook
Problem with JVC HD camera media browser- Program Stopped Working
Uninstall the program and install from scratch. Hopefully that will restore it. If it does not want to reinstall then you have to go into the registry to completely remove all fragments that may have been left behind by the normal removal process. Those left behind bits of data often confuse the computer into thinking that the program is till there and will block machine from an installation. Taking everything out is the cure.
Sep 06, 2017 | Cameras
I need to remove the front bumper cover in order to give it some repairs due to scratch/cracks. How can I remove it and reinstall it.
taking off the bumper is pretty easy ... i've done it plenty of times at work ... the good thing is that it comes off pretty simple without having to take off the headlamps or anything ... ok ... i'm gonna try ... open the hood ... take out the clips that are holding it on the top ... there's 5 of them i think ... then it's connected to the fender too ... remove the clips that connect the bumper to the fender liner on the side ... you're gonna need something like a clip remover for that cuz those sit pretty deep and are pretty hard to get out ... pull out the fender liner as far as you can and you'll see a screw that connects the bumper to the fender on the very tip of it ... i'm pretty sure it's a 7mm screw ... unscrew that and it should lossen up ... do that on teh other side too ... ok ... now ... bottom ... there are 7mm palstic screws on the bottom that hold the dirt blocker thing ... there's like 10 of them ... take out the cips and unscrew them ... the bumper should come off ... you might have to see what else is holding it ... but it's pretty easy ... top, sides, bottom ... doesn't matter which order you go in ... i usually start from the bottom ... then sided then top ... so yeah ... i hope this helps ...
Jun 14, 2009 | 2008 Pontiac G6 Sedan
Lg washing machine wf-t655th won't start
Auto/off is power button--correct?
start/pause button actually starts the unit--correct?
Jul 27, 2017 | LG Washing Machines
Gta error reading disk
Sounds like an issue with the laser.
Mar 02, 2009 | Sony PlayStation 2 (PS2) Console
Gta san andreas error reading disk
I would try a lens cleaning disk and see if that helps. Oftentimes if there's just a little smudge on the lens it can keep certain games from playing while others work perfectly. It's been a while since i used one bought i've bought them from Best Buy and Staples in the past.
Good Luck!
Mar 02, 2009 | Rockstar Games Grand Theft Auto: San...
CDJ 100 s PROBLEM E-9103 and E-7201
E-9103 is MECHANICAL TIME OUT,
Solution : some object in compartment slot, remove it, or clean player compartment
E-7201 is disc cant be read in 20 seconds,
Solution : Disc has scratch, Replace disc
Disc is dirty, Clean disc
Dj ajay
djajay@inbox.com
Feb 03, 2009 | Pioneer CDJ-100S CD Player
Error code 0x80040702
you should go into your computer to my computer. then file programs.look for palm then open. look for your user name open then look for backup file rename the back up file then hot sync the phone then use the same user name it will start up a new back up folder. you might have something on your phone that the phone do not agree with. this should work if you hot sync your phone to your computer.
Dec 23, 2007 | Palm Treo 650 Handheld
HTC Touch P3450 Smartphone Logo
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
