My stupid computer sais: " Media test failure, check cable, exiting broadcam PXE ROM, No bootable deivce -- insert boot disk and press any key." I hit Ctrl+Alt+Dlt, and it restarts, when i hit f2, to take it to the boot settings, there is like practically nothing to do, and the just keeps repeating itself.
When you boot your computer it checks a series of things like memory, etc. If it has any problems it will give you beep sounds or some lights will turn on, like where you have the usb sign etc. Can you notice anything like that happening? Also does it do nothing whatsoever, or at least the normal first black screen with the power on self test info it still shows?
You can't post conmments that contain an email address.
During the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS you can load failsafe defaultsor load optimized defaults ,press escape then press f10 to save to cmos to restart or During the boot process tap thef8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer Also you might try Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer)
when it goes to the black screen give it a few seconds after the mouse shows up. Ctrl+Alt+Del and select task manager, then select the process tab. click on explorer, then right click on it and select end process from the pop up menu. once it has disappeared go back to the first tab programs. click new task, type explorer and hit enter. see where it gets you from there. if that doesnt help please recover your computer per manufacture instructions.
Try this, before it boots up and just after in posts press F8, it should bring up a page where you can choose your boot option, choose "Safe Mode", if the computer does boot to safe mode there are a few steps you can do to remedy this.
First goto my computer, c:drive/windows and scroll down to a folder called prefetch open the folder, highlight everything in that folder by left clicking once on one of the icons and holding control(ctrl) then pressing A once everything is highlighted hold down the shift key and press delete, everything should now be gone, exit out of all the windows do a disk clean up, my computer right click on c:drive (your main drive) and click on disk cleanup tick all boxes and then click ok to start deleting the temp files. once finished reboot mechines and leave it to boot up. if you still are having problems or it wont boot up into safe mode post back. cheers.
Its probably caused by the RAM, have it checked. If you can do it yourself, remove the panel cover underneath the laptop and clean the RAM as shown in the image below:
(The actual RAM in your laptop is shorter than the RAM on the image.)
Install it back to the computer and turn it on. If problems persist try another RAM, it may already need replacement.
Sometimes when you use ram sticks on some older computers they do not handle taking teh ram stick out of the USB port without first closing out teh device OR if you have the RAM stick in while you are booting the machine... it will select the ram stick as the boot device and appear there is no oprerating system present.
In you case when you go to the boot menu.. be sure the boot menu is set to select the hard drive as the primary boot device. If it is not then you can make the change at teh bott up screen.
Good day sir/maam, the reson why it froze is caused by a bad memory module, you may need to replace it. Open up your computer and locate the memory modules, remove all memory modules and bring it to a computer vendor for testing. or if you have the cash, better buy a new one. make sure that what you install on your PC be it tested or new is good.
Did you try " Last known good configuration at start up. If after boot you press the F8 key where you said you went into safe mode, did you try to load the good known config. It sounds like you have a corrupted registry.
