Question about Toshiba 36A50 36" TV
Toshiba 36A50 tv has horizontal line when first turned on
Eventually, we will get a picture.
    President:
  • 2,992 Answers
This is usually due to bad solder connections to the vertical output integrated circuit. Because the part gets pretty hot during operation, the connections can degrade over time and cause the loss of picture. The solution is to resolder those connections. It's an easy job if you have some experience with electronic soldering. The hardest part, especially in a big set like yours, is getting the circuit board out and flipped over to access the solder side. Also, some parts in a TV can store possibly lethal charges even after it's been off for a while.
If you want to try it yourself, the output IC is mounted on a metal heatsink near the middle of the circuit board. I haven't faced one of these in a while but I think the part location marked on the board for this is IC401. Resolder the connections to the pins of this part and it should restore your picture.
If you have some doubts about trying this yourself, you might consider calling a servicer in your area and get an estimate for a repair call. The shop I used to work for charged around $90 for this kind of job, including the trip charge, but this is a number of years ago.
Posted on Feb 11, 2009
Toshiba, 36A50 picture is a thin white line. Can this be repaired?
Yes...this TV may be repaired. The line you describe is in the center and is horizontal across the TV. You will need to resolder the vertical IC pins. This vertical IC is mounted on a large heatsink. Under the board you will see there are 5 or 7 pins that will have rings around them. Resolder these. And you should replace two or three capacitors that are next to this IC. A bad cap will overheat an IC and separate the solder grounds. If you can find my expertise page on this website, you will see the repair in more detail. Thanks for asking and show a few hands of support.
Dec 12, 2010 | Toshiba 36A50 36" TV
Only thin white line across my toshiba tv
This is an easy repair if you've ever soldered and would not be too costly for a repair shop to do it for you. The problem is a bad Vertical Output IC (usually mounted on an aluminum heat sink with the part on it labeled LA78?? ) and 1 or 2 bad capacitors. Some times you can even fix the problem by re-soldering the contacts of the IC- To find the IC follow the 4 wires that come from the Yoke (which is a contained coil of wires slipped over the neck of the picture tube(s)) back to the board. 2 of the wires go to the horizontal o/p and 2 to the Vertical o/p the thinner gauge wires are for the vertical.
Sep 28, 2009 | Toshiba 36A50 36" TV
Toshiba TV (about 7 years old)
You had parts in the vertical deflection circuit failing, most common are the vertical output IC and possibly several capacitors also in the same circuit.
Sep 11, 2009 | Toshiba 36A50 36" TV
Two white lines on the screen - no picture. is the tube blown?
i dont think so
how the lines are?
horizontal or vertical?
Jul 28, 2009 | Toshiba 36A50 36" TV
Toshiba 36A50 sound, light line horizonally on black screen
It is my guess that you have some intermitent solder connections in the Vertical output circuit.
Hope this helps,
Skyassoc
Jun 23, 2009 | Toshiba 36A40 36" TV
Toshiba 32" tv wont give sharp picture (other tv does)
try to replace filter capacitor from power supply and in horizontal section.
Jan 26, 2009 | Toshiba 36A50 36" TV
No picture only sound, Toshiba 36A 36" TV tube type
my friend if you open the tv carefully look to see if the tube itself has light, or if you have high voltage i coulbe many different things.wish luck!!
caypianan@yahoo.com
Aug 10, 2008 | Toshiba 36A50 36" TV
Toshiba 36A50 Horizontal Line in the middle
  • the problem is most common & simple to repair at your home only at minimum cost by skilled technician.
  • as per problem is concern it is due to electrolytic capacitor failure in vertical output stage.
  • hope this will help
  • good luck.
Oct 21, 2007 | Toshiba 36A50 36" TV
Toshiba 36A50 problem with horizontal lines at the bottom of TV...
you'll need to replace bad capacitors on the vertical circuit stage , no expensive but you need the basic knowledge, and the tools to do it your self , if not . you need a tech depend on the tech 60 to 80 dls a shop 125
Jun 10, 2007 | Toshiba 36A50 36" TV
Toshiba 36A50 36" TV Logo
112 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
