Question about Panasonic PT-43LC14 43" Rear Projection HDTV
IR code for the Samsung DTB-H260F HDTV tuner
I just purchased the Samsung DTB-H260F HDTV tuner, and I would like to use my Panasonic Tv remote with it, but I'm not sure what component I should pick and also I would need the code for it.
Thanks,
Barni
  • Anonymous Mar 08, 2009
    Need the code for it for my tv remote.
TTM77
  • 19 Answers
SOURCE: hdmi receiver to hd plasma tv
1) I believe the "3 prong" you mean the RCA A/V cable. This cable is color coded red/white/Yellow (Right Audio/Left Audio/Video). This cable is OK for regular TV but when it come to HD, the quality of the picture fall short.
But you also could mean the 3 wires component cable that color coded Green/Blue/Red. If you plug only this without the Red/White for the speaker then you will only see the picture. This component cable help make the pic a lot clearer. But I believe not as good as DVI and HDMI. More info here http://en.wikipedia.org/wiki/List_of_display_interfaces
2) Most universal remote control come with a preset of keys to emulate other remotes. You need to search for the owner manual to figure out how and what code to put to use with a certain device.
Most new Universal remotes has a learning mode too that the user can "teach" the remote to emulate that "IR signal".
Now for the "HOW". It's a little complicated. But here is my 2cents. Most basic remotes has a light in front and this light is Infra Red light. So you don't see the light but it blinks. The blinking is the data of 1 and 0 that computer uses. Most of the time the remote is in sleep mode which uses very little power. One press of the button, it switch on the remote and carry out the performance of that button. The brain of the remote figure out which button was pressed and search in it's memory for the blinking pattern and blinks the light with that pattern and then fall back to sleep.
For the pattern itself, it contain informations. It usually start with the ID of the device that suppose to receive the signal. Follow is the "flag" and then the information of the button that was pressed. Then the final signal is basically say "End" to indicate that the message end. All device within range will get this information but if the ID don't belong to it, it will ignore the entire message.
Hope what I said helped. :D
Posted on Jan 24, 2008
memorymaker
  • 20 Answers
SOURCE: my t v says it's a HDTV 1080 but does not recieve hd signal
To get HD you need an HD box for your cable.
Posted on Dec 20, 2008
  • 1126 Answers
SOURCE: need code for my panasonic tv
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=oneforall&dv=universalremote&kw=&st=&ar=&dt=&so=&au=&le=&pg=4
Locate urc-7562 file to download, then unzip it...codes are at the back of the user guide. Hope this helps.
Posted on Aug 22, 2009
Grubhead
  • 5259 Answers
SOURCE: DVD recorder has stopped picking up a signal from the tv.
Double check connections first and try using the factory settings reset, before replacing the card.
Posted on Mar 01, 2010
duane_wong
  • 6826 Answers
SOURCE: I had a IRC 550 starchoice remote and it ran my
SEARCHING FOR YOUR CODE=irc 551
If your home entertainment device does not respond to
the Star Choice IRC 551 IR and Star Choice URC 551 IR/
UHF Remote Controls after trying all of the codes listed
for your brand, or if your brand is not listed at all, try
searching for your code.
For example, to search for a code for your TV:
1. Turn on your TV.
7. To search for the codes of your other devices,
repeat steps 1 through 5, but substitute the
appropriate key (e.g., AUX, DVD, AUD, or SAT)
for the device you are searching for.
Posted on Jan 30, 2011
I have a samsung blu-ray C6300 DVD player do you know eny remote codes
Here is the list with the KNOWN working device codes for Samsung Blu-Ray DVD players. These should work with ANY remote as these remote codes are universal. Samsung Blu-Ray Player Universal Remote Codes (4 and 5 digit)
0199
12051
10812
10702
10060
20199
31868
10766
20573
11903
22069
11060
21075
20240
31295
31500
22329
22369
21470
22489
01877
21044
20820
10650
10814
22556
10178
20490
20045
01982
31304
20744
Below are instructions on How to Program your Samsung Blu-Ray Player to Control your TV.
Use Samsung Blu-Ray Remote Control To Control Your TV
remote-codes-for-programming-samsung-blu-ray-player-remote-to-tv-dfydxumns33ohqc3bsmt22yf-2-2.jpg
Remote codes for programming Samsung Blu-Ray Player Remote To TV
http://codesforuniversalremotes.com/samsung-blu-ray-player-remote-control-codes/
Samsung Remote Control Codes For All Devices
4 Digit Samsung Remote Control Codes = HDTV
0060
0030
0178
0056
0702
1199
1200
1245
1246
1325
1327
1352
1354
1443
1019
1171
1172
1173
1174
1175
1197
1198
5 Digit Samsung Remote Control Codes = HDTV
12051
12280
12281
10812
11632
10702
10814
10032
10178
10030
12284
11575
11597
10427
10408
10217
10056
13118
12278
11581
Samsung Remote Control Codes = TV
1098
1156
1161
1297
1314
1323
1360
1363
1364
1490
1492
1510
1004
1005
1011
1014
1018
1019
1061
1072
1073
1074
1097
4 Digit Samsung Remote Control Code = Blu-Ray Players
0199
5 Digit Samsung Remote Control Codes = Blu-Ray Players
31868
10766
20573
11903
22069
11060
12051
10812
10702
10060
20199
21075
Samsung Remote Control Codes = DVD Players
2233
2246
2271
2274
2279
2286
2290
2294
2295
2299
2311
2314
2333
2340
2347
2351
2012
2029
2049
2074
2085
2102
2120
2175
2186
2196
2214
4 Digit Samsung Remote Control Codes = Receivers/Tuners
5139
5 Digit Samsung Remote Control Codes = Receivers/Tuners
31868
31949
32137
31304
31950
32660
Samsung Remote Control Codes = Misc Audio
4065
4047
4064
4033
4036
Samsung Remote Control Codes = VCR Codes
3148
3184
3214
3215
3218
3232
3011
3069
3084
3089
3101
http://codesforuniversalremotes.com/samsung-remote-control-codes-for-all-devices/
Apr 20, 2017 | Samsung Televison & Video
I need a code for a remote for a Samsung dtb-h260f hdtv receiver
Google the model number of the remote for a owner "manual" to obtain a list of possible codes for the set. Most universals have about 50 possible codes built into them and also have a search feature where one can try each and every code to see if one works.
May 02, 2012 | Televison & Video
Samsung DTB-H260f. Does this unit suffer from the
Yes it probably has a bad cap in the power supply. See this link for more info: http://www.badcaps.net/forum/showthread.php?t=7804
Jan 24, 2010 | Samsung DTB-H260F
I came home yesterday simply turned on the TV the
Check the power supply for bad capacitors. See this link for more information: http://www.badcaps.net/forum/showthread.php?t=7804
Jan 22, 2010 | Samsung DTB-H260F
Unit will only stay on for 20 sec. after you unplug it for about 30 sec. Blue power light can not be turned on again unless you unplug it again. Unit is not functioning with the light off, so it is not...
I just had the same problem on my samsung DTB h260 on Dec 20 2009.I am trying to search a answer.A nephew brought his WII remotes over and his Wii remotes lite up and my wii and dtb h260 shut off.Had to unplug Wii and replug it into wall. It started up but the dtb h260. Wierd like interference.
Dec 11, 2009 | Samsung DTB-H260F
I have had an outdoor antenna for several years to recieve HD local. Before the conversion I purchased a Samsun HD Tuner. It was working fine will all channels working and guide providing all program...
8 11 & 14 are std definition. All digital channels are 1.1, 1.2, 1.3, etc. You may need to re-align your antenna. Digital is Very Very direct, analog was very scattered. Hope this helps
Jul 08, 2009 | Samsung DTB-H260F
Need product codes to program Universal Remote
I have the following toshiba codes
10154, 11256, 10156, 10093, 11265, 11060, 11356, 11369, 11524, 11635, 11656, 11704, 11918, 11935, 11936, 11045, 12006, 11343, 11325, 11306, 11164, 11156, 10845, 10832, 10822, 10650, 10149, 10036, 10070
Nov 28, 2008 | Toshiba Televison & Video
No audio from Samsung DTB-H260F
I have a sr605 Onkyo receiver and just hooked it up to a new Mitsubishi 73" and I could not get the picture to work, sound did though. Here is the problem the Onkyo is HDMI 1.3 but TV calls for HDMI 1.3a. There is a big difference between the 2 and the Onkyo will not work with TV. The newer model TV'S say in the manual Category 2 V 1.3a. You need to make sure that all your parts are compatable. It makes a big difference.
Dec 05, 2007 | Mitsubishi HD-6000 DTV Receiver / Video...
Panasonic PT-43LC14 43" Rear Projection HDTV Logo
204 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
