Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Water leaking from soap drawer large amount floods kitchen floor intermitent
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 100 Answers
There is a blockge so the water comes out the way it went in when spinning,
check the filter at the bottom of your drum.
rear of machine, take panel off and look in to see black rubber attached to drum about 3" diameter. filter in there.it's a kind of basket with a ball float in it.
put back the way it came off as only fits 1 way.
Posted on Feb 11, 2009
Water leaking from detergent drawer
The first thing to do is take note of what the washer is doing when water leaks out in order to help pinpoint the cause. Does it only leak when filling? Is it leaking during wash or rinses? Or is it leaking only when it goes into spin?
Only leaks when filling
  • Water pressure that's too strong. Some dispensers can't cope with high water pressure. Make sure the washer is level as one leaning forward can leak if combined with high water pressure. Try turning the tap on the washer down. Only suspect this if you know the water pressure is high and it looks like it's gushing in quite fast on fill
  • If there is an optional detergent flap fitted in the drawer for holding liquid detergent make sure it is removed or drawn into the up position if using powder otherwise it prevents detergent running down into the drum
  • A build up of grease and slime in the nozzles at the top of the dispenser where the water flows in causing water to spray at the front and run out when filling. Check this article -black jelly-like substance in soap dispenser and on soap drawer (In extreme cases I've had to replace the dispenser.)
  • A build up of undissolved detergent in the base of the soap dispenser under the drawer (depending on the design). Remove the soap drawer and check the bottom of the soap dispenser for a build up of detergent that could allow water to run over the lip of the dispenser
  • Blocked dispenser hose: Some washing machines can flood water out of the soap dispenser if the hose leading out of the dispenser into the tub gets blocked. Blockages can be something put into the drawer by a child or a chunk of undissolved detergent tablet. Indesit, and Candy, as well as some of the later Hoover washing machines suffered from this design flaw. The hose where the water is flushed down, was right at the front of the soap dispenser on these washing machines and it wasn't wide enough. Undissolved powder from a tablet or lumps of detergent through poor water pressure can block this hose solid causing water to back up. Unplug machine, remove lid and feel this hose carefully for obstructions.
  • Overfilling: If the washer starts to fill and never stops it will flood out of the drawer eventually - Washing machine overfills
Leaks out of drawer during the wash or rinse cycle
  • Too many suds? If you can see the door glass is white with foam up to the top it could be foaming out of the dispenser. Too much foam in the washing machine
  • Overfilling: If the washer starts washing but the water doesn't stop coming in it will eventually fill the drum so much it will start to pour out of the soap drawer and other places. If this is the fault you should be able to see the drum is so full of water it's making a different sound, maybe labouring under the load, and the door glass full to the top with water. You should also hear that water is still running into the machine and be able to detect it by opening the drawer. However, in most cases an over filling washing machine should trigger an error code long before it gets to this stage but if you suspect overfilling check this page - Washing machine overfills
  • Surging: There are (often intermittent) faults that can cause the motor to spin out of control on wash or rinses. Instead of turning slowly the fault causes the motor to surge into spin instead which throws the laundry and all the water about violently. Water can then be forced out of the soap dispenser drawer. This fault should be relatively rare these days but if you observe this behaviour call an engineer to diagnose the cause.
Leaks from drawer only when spinning
  • If it only comes out on spin it can be caused by a partial blockage preventing the water being pumped out fast enough resulting in excess water being thrown around on spin and backing up into the dispenser. This fault is similar to the surging fault described in the last list but different in that the problem only occurs when it's on a proper spin cycle and much of the water has been pumped away. Troubleshooting this fault is all about finding out why it isn't emptying the water properly which is usually due to a partial blockage. Follow the same troubleshooting as described for a washer not pumping any water out at all - Washing machine won't empty water
  • If water is being forced out of the drawer when the washer is spinning but it is on wash or rinse and shouldn't be spinning follow the procedure for surging in the previous section above
Dec 23, 2016 | Washing Machines
Lots of water pouring out on to the floor from the laundry soap dispenser in my front loader and doesn't say any error and when i start it pours out
Disconnect first the mains, power plug off the wall. You could have a clog in your soap drawer; pull the dispenser drawer completely out. There is a tab that needs to be depressed to release the drawer to remove. Clean the soap drawer with an old tooth brush. The usual block could be old soap, softener, etc. (you could also be using too much soap powder). I usually use just above 125ml (my measure cup says ml, I use front loader powder for the 5.5kg load) The wash is very gud. This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Next could be one of hoses has become loose, should be re-fixed. Examine by removing top of the front loader; this will give you a gud view of the pipes.If helped, click.
Apr 03, 2013 | Samsung WF328AAW Front Load Washer
Water is backing and flooding out the front from the soap drawer.
Sounds like this is the case check your hose from soap drawer that feeds drum, may need unblocked.
Apr 13, 2010 | Kenmore Elite 45986 Front Load Washer
Water coming out of soap drawer
Some washing machines, can flood water out of the soap dispenser when a hose gets blocked (usually with un dissolved soap powder) .Water flooding out of the front of a washing machine's soap dispenser can also be an indication of overfilling or a partial pump blockage if it does it when spinning.
Black gunge in the top of the soap dispenser can cause water to spray towards the front and leak. Take out the soap dispenser drawer and look at the roof of the soap dispenser. If it's covered in black gunge, blocking some of the water holes, it could be causing problems. In extreme cases you have to replace the dispenser.
Feb 05, 2010 | Hotpoint First Edition WMA22 Front Load...
Maytag ice maker will not release cubes
Sounds like it has a " seeping " water valve . Only thing to do is replace the water inlet valve . There is a certain amount of water to go into icemaker at fill . A seeping valve will let water continually drip into icemaker , making large cubes which icemaker cannot dump . A larger amount of seeping , will overfill the icemaker , and drip into the freezer and floor .
Aug 12, 2009 | Maytag Refrigerators
The dishwasher was full of soap suds but most of the water drain
Suds? If you use dishwashing detergent you shouldn't get suds. If a small amount of sink type dish soap is left on a dish before loading it into the dishwasher this can happen. I would use several rinse and drain cycles with the racks and dishes removed until the suds are gone.
Never use any type of liquid dish soap made for sinks. The same thing that makes suds in the sink will make even more in the dish washer.
Hope this helps!
Feb 15, 2009 | Fisher and Paykel 24 in. DD603H W Built-in...
Water leaking through soap dispenser drawer
OLDFIXER was exactly right ! I had water gushing out of my LIQUID detergent tray. I removed the tray by pushing down on the flexible tab at the back of the tray and when I had the tray out I discovered A LARGE AMOUNT OF DAMP powder detergent caked up on the inside. I removed it all and sprayed some hot water inside AND ITS COMPLETELY FIXED !!! GOD BLESS OLD FIXER.
Apr 27, 2008 | GE WSXH208A Front Load Washer
Hotpoint Aquarius WF 240 Front loader
first remove the soap drawer, this should expose locating holes for screws, remove these first, then remove the screws from on top of the plastic front panel and then the plastic front panel tilts forward to remove, taking extra care with wires etc the soap drawer is now loose still attached to the rubber pipe, which is now easy to get to for inspection, or removal to clear it out. first of all just check that the machine drum is not filling up totally so it is overflowing back out of the soap drawer, if so that is a different fault entirely and does not need taking to bits the same
Sep 21, 2007 | Hotpoint Aquarius WF215 Front Load Washer
Intermitant water leak.
Put a newspaper under the machine, it will help you to find out from where does the water leaks. Good luck!
Sep 06, 2007 | Hotpoint Ultima WF865 Front Load Washer
Water Leak
I have th same problem, apparently a possible cause could be a partially blocked pump filter. Just trying to get infoon where this is and how to get to it though.
Oct 31, 2006 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
283 people viewed this question
Top Hotpoint Washing Machines Experts
hungoverrr
Level 1 Expert
puggy666
Level 1 Expert
freddyfox
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
