Question about Mitsubishi VS-50607 50" Rear Projection Television
Powers on to blue screen and nothing else
I turned on my Mitsubishi VS 50607 big screen and all I get is a blue screen No sound nothing I tried running a test I pressed the two buttons on the front (input and menu ) at the same time and held them for 5 seconds or more and nothing happend the indicator light stayed green no flash nothing.... did I run the test wrong.
  • James Lupo Feb 13, 2009
    I did that but still nothing happened. I even held the button for about a minute and I noticed nothing. How lone does it normally take... please advise
  • James Lupo Feb 15, 2009
    I do not see any display nothing no menu text or anything
  • 43 Answers
Press the input button until it cycles through all of the inputs.
Posted on Feb 12, 2009
  • dhurt Feb 13, 2009
    Do you see any display or anything? does the menu text display?
  • dhurt Feb 15, 2009
    Sounds like you may have a bad CRT then. If the screen is all blue and you can't see text, then that is all I can imagine without seeing it for myself. I could be worth a repairman's estimate.
Mitsubishi VS 50607 big screen no picture and no sound blue black screen
HELLO. your problem is mostlikely in your singal u are putting to it . where u have it hook up to. or in your setting in your menu. are not right look at where you are put or cable in or ant in and put it on A or B. THEN WITH YOUR REMOTE BRING UP THE MENU AND GO TO SET UP THEN TO SEE IF YOU HAVE IT SET TO CABLE OR AIR.? ONCE YOU KNOW WHAT IT ON SET IT TO WHERE YOU HAVE YOU CABLE OR ANT HOOKED UP TO. (A) OR (B) then run the auto program. and see if it work's hope this help's u . rember to vote for me thank u.
Jun 08, 2011 | Mitsubishi VS-50607 50" Rear Projection...
My Mitsubishi vs 50607 has blue green and red lines jumping all over the screen what is the problem and fix
You have some bad filter caps in the convergence section of your set or a bad convergence chip
Aug 05, 2010 | Mitsubishi VS-50607 50" Rear Projection...
I have a Mitsubishi VS 50607 and the sound and color are good, but the screen is jumping. The picture is there but it is almost as if there are two of them. Anyone know of a solution?
Howdy,
CHECK and replace C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH ARE ON THE SIGNAL PCB. REPLACE NO MATTER WHAT.
gOOD lUCK, BIG irish.
Dec 29, 2009 | Mitsubishi VS-50607 50" Rear Projection...
How do i clean the projectors and screens of my mitsubishi vs-50607 tv
Pull the Front Bottom panel off under screen will be screws that hol pn screen remove all of them then lift up on screen anf remove it Now you should be where Mirror and Tubes Clean all lenses and mirror with windex.
Sep 19, 2009 | Mitsubishi VS-50607 50" Rear Projection...
Rolling screen
my screen on my mitsubishi won't stop rolling
Aug 22, 2008 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi VS 50607 Problems
Vertical output IC most likely needs to be re-solderd. However this model is famous for the CRT leaking coolant in the area of the Vertical output IC and corroding the solder. Check for a sticky residule near the Vertical IC indicating a leaky CRT seal.
Apr 09, 2008 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi VS-50607 has Jitter at top of picture- intermitant
IF you would like help diagnosing your set. Go to the enclosed link. They have the service manual for your set and offer unlimited chat support for only 10.99. Just click on your sets manufacturer and you will see your model. Then click on the contact us link and provide your email address and they will email your manual and instructions on how to obtain your support. I am one of their techs
http://servicemanuals.vstore.ca/
Jan 14, 2008 | Mitsubishi VS-50607 50" Rear Projection...
Wavy picture on television screen
First do the self test on these threads or goto ctechnicians.com
Dec 29, 2007 | Mitsubishi VS-50607 50" Rear Projection...
Blue screen
check the agc circuit it is becomming defected.good luck.
May 16, 2007 | Mitsubishi VS-60703 60" Rear Projection...
Mitsubishi VS-50607 50" Rear Projection Television Logo
101 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
