Question about Magic Chef CAV4000AWW Top Load Washer
Laod with bath towels won't spin out
Magic Chef washer that won't spin out the water when bath towel(s) are in the load. The water drains but the clothes are dripping wet.
  • Anonymous Apr 28, 2009
    washer will not spin
  • 77 Answers
Hi, you may find that the towels when wet are to heavy for the belt to grip the drum if it spins with normal clothes in you need to reduce the load when you wash your towels, hope this helps.
Posted on Feb 11, 2009
My washing machine tub seems real loose. It starts banging on the sides when starting to spin. What causes that?
Hi Steve, This is usually caused by an uneven load. For instance, If you have a bath towel in with some shirts or tea towels, the bath towel absorbes more water than the tea towels, thus making an uneven load.
My wife tends to wash slippers in a pillow case with nothing else in the washer, and the drum will bang against the side.
Hope this helps
Kind regards
David
Nov 10, 2017 | Washing Machines
What is correct position of drain hose for top loading washer?
may have a bad clutch u can spray the clutch with solution of water and dish soap after it has finished cycle, if it sizzles clutch is bad.
Apr 27, 2014 | Dryers
We have Samsung WF448AAW steam, silver care washer. This problem only occurs on towel cycle. When we wash colored cotton terry bath towels and wash cloths there area areas about the size of your hand or...
Hi
This type of issues usually occur when the washer is unable to drain water completely, you can run your washer at its hottest temperature setting with 2 cups of vinegar inside the unit. After this take off the bottom front panel and clean it completely, also clean the drain hose and drain pump filter, the bleach marks should disappear after doing all this. Hope this helps...please post back for further assistance.
Daniel
Jun 17, 2011 | Samsung WF448AAW 4.5 cu. ft. Front Load...
How do i drain the freezer?
Some freezers have a plastic drain plug on the side that can be removed, but most do not. I have found the easiest way is to **** up any water in the cavity with a shop vac or bath towels.
FYI: An authorized servicer is required to drain the refrigerant from the system and requires specialty tools.
Aug 29, 2010 | Magic Chef Chest Freezer MCCF5WBX
WHIRPOOL washer model LSR8010PQ0, WHEN LOADED WIT...
If large items in the machine create an imbalanced load the machine is designed to switch off...Towels are notorious for doing this because they hold so much water. Jeans don't soak up much water. Wash towels with towels alone and the problem should be reduced....Good luck....Nomess
May 16, 2010 | Washing Machines
Washer won't spin. Washed bath mats (small) and
Read a post from someone else on this - turned out it works fine, just wouldn't work with the small wet load. I added towels to the bath mat load, washed them, it spins fine. Washed clothes & that worked fine too. Yay!! Not broken. Just not found of small loads of bath mats!
Jan 22, 2010 | Frigidaire ATF6000ES Front Load Washer
Water wont drain and it wont go into the spin
if it is'nt making anny sound at all in spin its probly the lid switch
Dec 08, 2009 | Magic Chef Washing Machines
Won't spin or drain
remove as much water as possible lean washer back against wall pump is on front of tub bottom pump twist locks into bottom of tub ..no tools needed pull release tab back and turn pump out and clean
Oct 30, 2008 | Fisher and Paykel GWL11 Top Load Washer
MAgic Chef top loading washer will not spin or drain
you have to open it,at the bottom of the drum it has a either clear or black plastic hose that goes to pump held together with pressure clips remove them water will flow then ,it also will flood the aerea around it,so plenty of soil to soak it up
Aug 31, 2008 | Magic Chef CAV2000 Top Load Washer
Magic Chef CAV4000AWW Top Load Washer Logo
595 people viewed this question
Top Magic Chef Washing Machines Experts
Ian Jones
Dan Webster
Dan Webster
Are you a Magic Chef Washing Machine Expert? Answer questions, earn points and help others
