Question about HP Officejet 5610 All-In-One InkJet Printer
My printer won't print
Can't print. When I clicl on printers, it say my printer is offline. how do I get back online printing?
  • 2 more comments
  • joyelaineg Feb 11, 2009
    the power is on. I've pulled plugs, shut down, restarted and when I click on print, it makes all of the sounds like it's going to print but it doesn't. On my screen it says printer is offline., don't know how to get it online - nothing in manual (that I can find)
  • glndlovu Mar 21, 2009
  • Deborah Stilligan Mar 23, 2009
    my 5610 officejet will copy but not print online documents ,, it use to but now it just says documents waiting to print are... etc.. i have the disc that came with it but what i try to reinstall printer it says i have the wrong disc in.. can u solve this
  • John Cole
    John Cole May 11, 2010
    Is the power on the printer?
  • HP Master
  • 19,396 Answers
Unplug printer power cable and USB, restart computer and empty printer cue before connecting back printer.
If that does not work reinstall printer software using the disk provided with the printer.
Posted on Feb 11, 2009
  • 28 Answers
Fiend your solution direct from hp. Here is your solution...
http://www.hp.com/printer/prob676ijt65/solution
26
Posted on Apr 05, 2009
Click start > settings > printers.
Right click on your printer model, look at the drop down menu. Does it say "use printer online"? If not, click that line, and retry printing.
Posted on Mar 21, 2009
    Sergeant:
    Champion:
  • 237 Answers
Once you reinstall drivers it should take care of the issue
How do i get my printer back on line?
NOT SURE IF THIS LINK WILL HELP YOU OUT....
Click the "Start" button and then click "Devices and Printers." Right-click the printerand select "See What's Printing" to display the print spooler window. Click "Printer" and select "Use Printer Offline" to remove the check mark. The printer should come online at this time.
How to Bring an Offline Printer Online ' Chron.com
smallbusiness.chron.com/bring-offline-printer-online-54836.html How do get my printer back on line Google Search
Dec 12, 2016 | PRINTER Office Equipment & Supplies
Printer offline wont print cant get back online
Check the status of the printer at Control Panel. Set it to online if it's shown as offline. If this doesn't fix the problem, check whether installing the vista driver available at your printer manufacturer's website helps.
Step 1:
a. Click Start, go to Control Panel and select Hardware and Sound.
b. Click Printer.
c. If the Printer is offline, it shows "Offline" status. If the Printer is online it shows "Ready".
d. If the Printer is offline, set it to online.
e. Right-click on the printer and select "Use Printer Online".
f. The display should change to ready when the printer is set to online.
Step 2:
If still you are facing issues, then update the printer driver. This should fix the problem.
For further precise instructions, please let me know the Operating Systems installed on the Computer.
Hope this helps..
Jan 12, 2014 | Canon PIXMA MX712 Wireless Inkjet Office...
HP Deskjet 6980 won't print. Says offline but i don't see how to turn it back online. was working. now not.
Printers often go off line for no reason. It can be genuinely off line or the pc is just not seeing the printer anymore To put it back on line all you need to do is open the print queue (double click on the printers icon in printers devices/ printer and faxes) go to File and in the drop down list it will say "Use printer Offline or Use printer online. click on it and if the pc is seeing the printer if will change and the printer will then start up and print. If this does not work then check your cable to the printer or your network connection to reestablish the connection.
Aug 07, 2011 | HP Deskjet 6980 InkJet Photo Printer
My printer won't print from computer to printer
hi there,
1- go to your printers folder and make sure the printer is online and your P4350 is set as default (checked).
2- If offline, right click on the printer icon and try to switch it back to online. The same to make it default in case it's not.
2- Once online, then right click on the printer icon again , go to properties and then try printing a test page from windows (I am assuming you are running Windows)
3- In case you were not able to bring it back online, turn off the printer, turn off your PC, reseat the printer cable connection between the printer and the computer (both ends), then turn the printer and the computer back on.
Jun 26, 2011 | Lexmark P4350 All-In-One InkJet Printer
My HP deskjet D4260 is offline. I have tried everything to resolve this but cannot find a way of etting it back online. Please help
Once you have added either a USB or networked printer to your PC or Mac computer, you can begin sending documents to print. However, on occasion, a print command will create an error on the printer and take it offline, which will prevent all future jobs from printing. To resolve this issue, you will need to change your printer settings from offline to online.
    PC Instructions - Open the Start menu and click on the "Printers and Faxes" icon. This will open a window with a list of the printers currently set up on your computer. - Double-click on the icon of the printer you want to change to online. A pop-up window detailing all current print jobs will open. - Go to Printer in the menu bar of the pop-up window and uncheck "Use Printer Offline." This action will change the printer from offline to online.
    Mac Instructions - Open System Preferences by clicking on the icon in the Dock. - Go to the Print & Fax control panel under the Hardware category. - Select the printer you want to take online from the list on the left side of the screen. Then click on the "Open Print Queue" button. - Click on the "Resume Printer" button at the top of the queue window to change the printer from offline to online.
Mar 02, 2011 | HP Deskjet D4260 Printer
Printer is offline. how do I get it online?
    PC Instructions - Open the Start menu and click on the "Printers and Faxes" icon. This will open a window with a list of the printers currently set up on your computer. - Double-click on the icon of the printer you want to change to online. A pop-up window detailing all current print jobs will open. - Go to Printer in the menu bar of the pop-up window and uncheck "Use Printer Offline." This action will change the printer from offline to online. Mac Instructions - Open System Preferences by clicking on the icon in the Dock. - Go to the Print & Fax control panel under the Hardware category. - Select the printer you want to take online from the list on the left side of the screen. Then click on the "Open Print Queue" button. - Click on the "Resume Printer" button at the top of the queue window to change the printer from offline to online.
Feb 28, 2011 | HP Office Equipment & Supplies
Blinking green light< will not print. staus says it is offline
hi
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} · Step 1
· Step 2
· Step 3
Mac Instructions · Step 1
· Step 2
· Step 3
· Step 4
Aug 02, 2010 | HP DeskJet 3650 InkJet Printer
My printer (MFC-490-CW)print status is offline change online
If you want to make it online, than make sure it is on and connected to your computer, Once you are sure about this than
Go to control panel than Printers and Faxes
There You need to right click on printer and than Use printer online
IT will Put you printer back online.
Nov 10, 2009 | Brother MFC 490cw Color Inkjet...
Trying to print 'offline'. Computer recognises it is offline but will not print. Error message says 'Printer is offline' which is as it should be. Printer is HP photosmart C4580.
So, if you want to print, the printer must be online. Offline method doesn't work to print. When the computer sayst that the printer is offline, it means ypur printer is turned off or you don't connected the printer to PC.
As in conclusion, if you want to print set the printer online.
Oct 05, 2009 | HP Photosmart C4580 All-in-One InkJet...
Printer won't print says it's offline
hi friend
this is very common problem for f300 series PSC
just delete the printer from printers and faxes and reboot the machine it will install printer again
there is funny thing abt this series it is saying offline when powered on and connected but when you disconnect iit will say "offline-use printer offline"
please try my solution and rate it
thanks
Apr 04, 2009 | HP Deskjet F340 All-In-One Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
181 people viewed this question
Seeker5211
Seeker5211
