Question about Pitney Bowes C180 Copier
Pitney bowes c 180
My pitney bowes C180 is showing error code E 3 40 what could be the problem and how can i fix it?
5 Suggested Answers
  • 168 Answers
SOURCE: Error Code
I think that is a Duplex error message. The duplex unit is not getting the correct power.
One thing you can try, is to slide the (ADU) duplex unit out and don't push it all the way in. Leave it out about an inch. Then turn the machine on and off. If the machine starts to warm up, but tells you to slide the duplex unit in, then you isolated the problem. Let me know if this works, and we can go from there.
Good luck.
Mac =)
Please always remember to post a feedback and a rating if I have helped you in anyway.
Posted on Feb 24, 2008
Bubbabear64
  • 2794 Answers
SOURCE: Service Manual
A good place to find one is on copytechnet.com. I checked some of the service manual websites and nothing was comming up with that model number. It could be because Pitney Bowes spun it off into Imagistics and now it's called Oce. Usually the copiers are made by Ricoh. Someone on there would know where to get the service manual under the Ricoh model number as well.
Posted on Jul 11, 2008
SOURCE: Pitney Bowes Copier - C180 - Error E3
The C180 was made by Panasonic and is no way comparable to Toshiba. The E3 code should flash with another code (01, 03, 11,... etc) This other code is required to diagnose problem and is a service issue. If it is an E3 10 or E3 11 there is a corona wire dirty or broken, these are the most common E3 codes. I'm not sure about other codes, you may have more luck looking for info on the Panasonic 7718 just remember to refence both parts of the code
Posted on Sep 17, 2008
  • 18 Answers
SOURCE: Pitney Bowes C180 copier: what does a U16 code mean?
Develepor unit failure. Did you by any chance remove the Develepor unit? or did you come close to the wire connector located behind the toner bottle if so reconnect it. NOTE ! Before checking any connector make sure the power is off and not plugged into the wall outlet ....Good Luck
Posted on Nov 27, 2008
  • 149 Answers
SOURCE: Pitney Bowes Model 9016 Error code E3 01
E3-01 is the toner bottle rotation. for some reason it is not rotating. Take out the toner bottle and be sure it is in coreectly, that the labels are not loose and preventing it from turning.
Posted on Feb 24, 2010
Pitney bowes c 180 copier red wrench error
The red wrench is a maintenance indicator. Your Pitney Bowes C180 is made by Panasonic and is a model FP7718. I was going to type up the maintenance reset procedure but I will just give you a link to a page that has step by step instructions. Here it is:
http://www.copytechnet.com/forums/panasonic/6754-panasonic-fp-7718-maint-counter-reset.html
Good Luck and Thank You for using Fixya.
WheatlandServices
Dec 31, 2010 | Pitney Bowes C180 Copier
C180 says E2 and printer tray light blinks
E2 means paper miss feed press resum button the go to print
Oct 30, 2009 | Pitney Bowes C180 Copier
I have a pitney bowes C180 that won't copy. The
the little wrench means it has shut down because it has exceeded the maintenance count, probably for the cleaner web in the fusing unit. Call service at 1 800 243 5556
My pitney bowes c180 copier after turning on it started to work but after a while E 340 displays on the top board what will i do to fix it?
There is a sensor by the drum that checks the image on the drum. If the sensor is dirty, or the image on the drum is too dark, it causes this code. 18002435556 for service.
May 11, 2009 | Pitney Bowes C180 Copier
Jan 19, 2009 | Pitney Bowes C180 Copier
FAULT CODE P0500
Fuser error code. unbend a paper clip and push in hole on right side of control panel. watch the control panel on the left side about 2/3 up a dot will appear. when it shows up, press 3. press trouble reset. Touch exit.
turn machine on and off. If it comes back up, reset again. 3rd time it needs a new fusing unit. Call 18002435556 for service.
Jan 05, 2009 | Pitney Bowes C180 Copier
Nov 26, 2008 | Pitney Bowes C180 Copier
C180 copier error code E7
The e7 code is for the sorter problem. you can either call for service 18002435556 or just remove the sorter and use the copier without it.
Oct 19, 2008 | Pitney Bowes C180 Copier
Sorry it took so long. Your copier probably is similar to a Toshiba E series. The error code is paper jammed in the bypass section.
Use this link as a lookup to the error codes
Use 4501 under Toshiba to find the error codes.
Aug 26, 2008 | Pitney Bowes C180 Copier
Pitney bowes c180
Try making a copy in Photo mode and see if it makes a difference
Nov 18, 2007 | Sharp AL 1631 Copier
43 people viewed this question
Top Pitney Bowes Office Equipment & Supplies Experts
Paul King
Paul King
richie46
Are you a Pitney Bowes Office Equipment and Supply Expert? Answer questions, earn points and help others
