Question about Home
Bath tub faucet will only run hot.
I have a single handle valve that turns counter clockwise. When you turn water on you cycle through cold water first and the further you turn it the more hot water you add with it. There is no cold water coming through just the hot.
  • 547 Answers
If the hot comes out when you first turn on you have hooked up hot and cold backwards
Posted on Feb 12, 2009
Why does moentrol bath valve give hot water pointed to "C" and vice versa?
Easy one.
Feel the pipes. The pipe on the right should be cold. If the pipes are correct, turn the cartridge 180 degrees.
Jan 20, 2013 | Moen & One Handle Tub & Shower Faucet
I just put in a Moen single, chrome handle shower faucet in my hall bath. Got it all together and the hot water is not comming out. Cold water is fine, but, when i turn the handle to the position where the...
If this is a Moen posi temp valve you may need to adjust the temperature limit stop. It is located under the handle. Usualy a plastic peice with grooves in it so it fits in another peice in the valve. If I remember right you pull this peice out and turn it counter clockwise to get more hot water. Do this in small increments and reassemble and test. I hope this helps.
May 25, 2010 | Moen Posi-Temp Single HandleTub And Shower...
I have A whirlpool hot water heater I can get hot water downstairs but not upstairs through the shower and tub
Upstairs do you get hot water to your sink faucet. If you do this indicates to me that the temperature valve in your Shower & Tub may need to be adjusted.
For single handle please remove handle to gain access to dial that adjusts hot & cold water mixing.
Remember where it is and take it out and replace about a 1/8 to 1/4 turn counter clockwise and reinstall and try.
It is a plastic adjustment dial that will slide off after the handle is removed.
Trace lines if possible to assure correct pipe's are connected to valve.
May 20, 2010 | Home
Disassembled handle and initial pieces under handle to find leak source. Single handle shower assembly. reassembled. Cold water only, no hot water. What did I not assemble correctly?
Take handle back off and see if it has a dial that can be removed and repostioned. take off and move it about 1/4 turn counter clockwise and reinstalled and try to see if mixture is correct.
May 18, 2010 | Kohler K-T10335-4-CP Lyntier Rite-temp...
When turning on the shower faucet there is no hot water.
Can you remove handle , behind handle there should be a dial to move to increase hot or cold supply.
Remember where you start and remove it and replace a 1/8 to 1/4 turn counter clockwise, just put handle on try it and see if it changes and adjust accordingly.
May 14, 2010 | Kohler K-T12007-4s-BV Brushed Bronze...
Bath tub faucet will only run hot. Just started
It sounds like the seals are going bad. Moen is probably rebuildable. You can go to a Menards and ask if they have the replacement guts for your particular model.
Nov 17, 2009 | Home
No water pressure in bath tub after turning off hot water heater
It could be back flowing into the hot water heater tank which is not full because of the leak. Even though the valve is closed on the cold water entry side, there is probably no valve on the exit side. That is how it is returning to the tank.
Sep 14, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
No hot water
http://www.moen.com/contact.cfm?location=TopNavCustomerSupport
You will find a quicker answer and free parts for your bath room faucet at link above . I am sure it is the mixer valve assembly. If you are not a plumber I suggest a pro be called.
John
Mar 15, 2009 | Moen Plumbing
Not enough hot water, has to do with a shower valve
Hello, first if any water supply hot or cold is turned off, you will experience trickling as you mention. You must have both cold and hot in order to adjust the temperature on your valve. if you had a plumber intall this unit you should ask him to adjust it. Otherwise here is how:
Rotate the handle counterclockwise to stop and let water run till cold water is purged, check
temperature. Rotate handle to off, remove handle parts (see Disassembly in your manual) and temperature limit stop, rotate clockwise to decrease and counterclockwise to increase maximum hot water temperature, reinstall temperature limit stop and handle (TIP: Do not screw handle in until desired maximum temperature is achieved) Repeat steps until desired maximum
Feb 21, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Home Logo
429 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
