Back to:
Tags:
Dell Floppy Drive
HD disk drives (jumpers)
By 2Pansy - usenet poster
Hi Hallvard,
Isn't it possible to put a twist in the cable such that the drive 0 and 1
select lines are crossed over? I think you can also buy cables with such a
twist.
/ __ \ / __ \ / __ \
/ / / / / / / / / /_/ /
/ /_/ / / /_/ / / /
// // /_/ Translations
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 01, 2007
Not Rated (0)
kcw573
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Yes- exactly..!
The "twisted" section of cable on a PC floppy drive cable is actually
6 wires wide- I'm not sure exactly why they reverse that many wires,
but as you said, for the Atari it may just be a matter of reversing 10
and 12.
The reason IBM did this with the jumpers and twisted cables was that
back when they first introduced the IBM Personal Computer, most
systems were sold with only one floppy drive (and no hard drive)
because they were so expensive.
Then when people discovered they couldn't do much with a single floppy
system, they would have the second floppy drive added. As long as it
was done by an "official" IBM tech person, there was no problem.
But when people started buying the floppy drives by themselves and
trying to install them, the drives wouldn't work.
Rather than trying to explain to thousands of irate computer owners
how to change jumpers on their new floppy drives, IBM came up with a
way to allow ALL drives to be set the same, so no one ever had to
change the Device select jumpers.
Because the normal situation was someone trying to add a "B" drive,
they started shipping ALL floppy drives with the jumper set to
"Device_1" , and developed the twisted cable that allowed the drives
to also respond as Device_0 in the original installations.
Since the twisted cable became standard, the jumpers on the drives
themselves were superfluous and as you've seen, have finally been
removed from most designs available today.
In answer to your question about internal solder pad jumpers, there's
no real way to tell if they're present or not without the data sheet
(or taking the drive apart).
I don't know just how common they are, or indeed if there are drives
that don't have any provision for changing the Device number at all.
I guess you could try opening the drive you finally end up getting,
and keep the "cable twist" idea as a backup.
BobR
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on HD disk drives (jumpers):
I don't want to Accept this solution
Solution #2
Not Rated (0)
Peter1
Rating: 0%, 0 votes
On 17 Oct 2001 18:56:37 , Hallvard Tangeraas wrote:
I bought a Toshiba 3.5" PC drive for a friend's ST. I adjusted the
jumpers and now it works perfectly. Of course it will only support 720k
or less disks. I do not see a problem with the Sony after the jumpers
are set correctly.
Edward S. Baiz Jr.
(Gamer)
HADES 060: 256meg Ram, Yamaha CDRW Drive, 1 gig Jaz
Drive, MicroTek E3 Scanner, Mach 64 w/4meg Ram, Epson
Photo 700 printer, 56k US Robotics Modem, ICQ#91257633
PROGRAMS: Extendos Gold, Cab 2.8, ScanX, STiK2, aFTP,
Calamus SL2000, Newsie, PlayMyCD, Papyrus 8, Smurf,
Nova Driver 2.67, NVDI 5, Linux, Magic, N.AES, Geneva
Thank You!
Solution #3
Not Rated (0)
herself
Rating: 0%, 0 votes
Hi Derryck!
Yes or you can just switch 10 and 12 over on the board by scratching the
trace.
Lyndon Amsdon
Thank You!
Solution #4
Not Rated (0)
Gary10
Rating: 0%, 0 votes
Actually, "Master" and "Slave" are terms which only apply to IDE hard
drives, not floppy drives.
The settings on a floppy are Device 0 or Device 1.
(No big deal, but you'll only confuse any tech people at a store if
you ask them how to set a floppy drive to "Slave".)
Unfortunately, as you say, ALL 3.5" floppy drives available today come
pre-set to Device 1.
Also, as you've noted, most drives no longer have any convenient way
to change the Device setting because no one ever used it anyway, so
manufacturers simply stopped spending the money on jumpers, headers
and circuit board real estate to support the easy changing of Device
numbers.
The ONLY sure way to know ahead of actually purchasing a drive
(assuming you don't find a store that will let you rip one open),
would be to obtain the data sheet for the drive from the manufacturer.
I haven't looked specifically for floppy drive data sheets, but most
hard drive manufacturers have this information easily available on
their web sites. It comes in very handy for the occasional obscure
brand or model whose jumpers are hidden or not marked. If you're
lucky, similar info may be available for floppy drives.
Failing that-
You've no doubt seen the floppy drive cable on an IBM compatible
system with the "twist" cut out section of cable.
The "twist" allows BOTH drives to be physically set to Device 1. The
"twisted" section reverses the drive select lines so one drive
responds as Device 0, even though its jumpers are set for Device 1.
As a "last resort", "bottom of the barrel", "necessity is the mother
of invention" solution, you COULD rewire the Atari drive cable to
simulate this "twist" and allow a standard Device 1 3.5" drive to
respond as Device 0.
Then ANY available 3.5" drive would work without modification.
You'd need a diagram of the IBM floppy cable to study- once you see
how the reversing of the signals is done it's easier to understand.
There's also a very SLIM possibility that you might be able to obtain
a floppy drive cable which was originally used to connect QIC-80 style
tape drives which had the normal floppy drive female connectors, but
which also had a male connector on it to allow the tape drive to be
inserted into the cable. This could serve as an "adapter" which would
eliminate the need to do ANY rewiring of the Atari cable.
The cable from the Atari would plug into the male tape drive connector
and the new floppy drive would plug into the "A" drive connector. The
floppy drive cable already has the "twist" needed, and you should be
up and running.
The problem would be locating a dinosaur cable.
BobR
Thank You!
Can you Help with these Floppy Drives problems?
Floppy Drives
1. if a rectangle has a length that is 3cm less than four...
Floppy Drives
A positive number is 5 times another number.If 21 is added...
Floppy Drives
back lite is ok, but no data on display screen
Floppy Drives
The community concert hall is hiring a new agency to sell...
Floppy Drives
The monthly cost (in dollars) of a long-distance phone...
Loading problems.
Repair Service
Find Floppy Drive Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Computer Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
