Question about HP LaserJet 8000 Printer
HP laserjet 8000 tray 2 not empty
I have a HP laserjet 8000 that after about half of the paper is gone it says tray 2 is empty. Then it also says tray 3 is empty when it is full. I think the little black thing hanging down in there is the paper senser. It is in tack and I can not think of anything else to check to find out what is causing the issue. All of the rollers are all still good if that matters.
  • 34 Answers
I install paper input units all the time for $275 including labor. HP printers are our only business.
I do agree that this sounds like it is indeed a PIU problem.
Posted on Mar 17, 2009
    Genius:
  • 2,120 Answers
Do you hear the paper "drop" when you pull out the paper tray. If not, it could be a lift motor
You will have to pull the Paper Input Unit to repair it.
Small items are not available for us to purchase.
If you can't fix, you need a new unit. About $400.00
Posted on Feb 11, 2009
Says tray empty
Assuming that you have physically checked that there is paper in the tray.
1) Ensure that there is some 'springyness' under the paper. If not, is something sticking?
2) Is the paper tray damaged or not fitted properly?
3) Consider buying a Roller service Kit
4) Consider buying a new Paper tray
Jan 21, 2014 | HP Laserjet P3015X Printer
Tray 1 doesn't feed while tray 2 has paper, after I empty the paper from tray 2, tray 1 work fine.
if you setup tray 1 any type, any size and tray 2 to plain, and letter size, it will allow you to use tray 2 for your plain letter jobs but will pull from the manual feed tray first only if the paper is in the manual feed tray if this makes any sense to you... please mark this as a fixya...
Nov 24, 2013 | HP LaserJet P4015N Printer
Trying to print using my new hp Laserjet 2420 yet being told error printing. The printer shows tray 2 is empty yet it has some papers. Is there a way to only use tray 1 if the tray 2 cannot operate...
Tray 2 paper senor not sensing the paper either it may dusty,failed or sensor flag mis placed.. verify where is the fault..Location: remove tray2 cassette, under you can observe the paper sensing flag..
Aug 30, 2011 | HP LaserJet 2420 Printer
My hp laserjet 9050 show paper jam when the tray is empty
(1) dose it work ok when you install paper.
(2) when it runs out of paper it dose not a sheet going through it so it gives that code .If its still works dont worry about it should be fine.
Aug 13, 2010 | HP LaserJet 9050 Printer
Configure HP 4050 printer to prompt 'load paper'
You'll have to change the paper TYPE of tray 3 to a different type as in tray 2.
Jul 28, 2010 | HP LaserJet 4050 Printer
LaserJet 2420 Printer: hp 2420n 13.20.00 jam inside rear door...
i have 2420 dn printer..printer reddy mode the power on...but not initlizing...13.20 paper jaming error coming but paper is not jam..hw to resolve
May 06, 2010 | HP LaserJet 2420 Printer
Can not print to Tray 2 on HP 3800 printer. Says Tray is empty
check the paper type and the paper size from the printer menu, if it is ok then you will try to check the paper sensor on tray 2
Jan 08, 2010 | HP LaserJet 3800n Printer
HP laserjet 4L paper jam after printing one page.
You need the pick up rollers replaced. Call your service centre to replace pick rollers as these are feeding the pages crocked
Aug 31, 2009 | HP LaserJet 4L Printer
HP LaserJet 2430dtn - "Tray 2 open or empty"
1-Is the paper set correctly in the tray? if you have Letter paper in it make sure the guides are snug against it
2-Check the lever inside the tray, remove the tray and look at the tires there should be a lever that you ca move freely that is the paper sensor
Oct 10, 2008 | HP LaserJet 2430dtn Printer
HP LaserJet 8000 Printer Logo
721 people viewed this question
Seeker5211
Seeker5211
