Question about NorStar Nortel Aastra B0240402 Phone Ash M5208 24 x 2 LCD display MADN-capable(B0240402, M-5208, M 5208, 52...
How to set up voicemail
How do I set up voicemail?, I don't know the codes and want to set up my outgoing message
  • 192 Answers
If you have an active voicemail... but have never activated it:
The default password is 0 0 0 0 (four - zero's)
The voicemail will talk you right through setting up voicemail, after the set up you can press 8 anytime you are in the voicemail to make changes to your account.
Posted on Mar 25, 2009
3 Suggested Answers
  • 214 Answers
SOURCE: I can't remember how to record my outgoing message ?
here you go...
Recording your greeting
You can record your own greeting
message (max. 2 minutes and 30
seconds). If you do not record a
greeting message, a prerecorded
greeting message is used.
1 {MENU}
2 {V}/{^}: “Answering devicei
3 {V}/{^}: “Record greetingi
4 After the handset beeps, speak
clearly about 20 cm (8 inches) away
from the microphone.
5 To stop recording, press {OK}.
6 {OFF}
If this helps you solve it, plz rate this fixya. Thank you kindly.
Posted on Feb 01, 2009
SOURCE: locked out of voicemail on T7316E. The code
retirar senha do telefone zte mod x760
Posted on Jun 23, 2010
How do I put a voice message on my phone when I am not available to take the call
Samsung Galaxy S6 Edge: How to put a voice message on phone when not available to take call:
Hello. If you did not set up your voicemail account yet..
Simply, on your S6 call your own phone number. When you do this it will ask you to set up your outgoing voice message.
Setting up Visual Voicemail
Visual Voicemail Samsung Galaxy 6 edge G925T
Feb 10, 2016 | Samsung Galaxy S6 Edge
Change outgoing message
Usually, the voicemail message is stored in the voicemail system, which is handset-independent. Call in to your voicemail (usually hold down the 1 key or look for the key with the envelope and hold it down - it will dial your voicemail account) and follow the prompts to set up your mailbox, and "change your greeting."
Dec 11, 2013 | Motorola Cell Phones
I want to change the greeting on my outgoing voicemail and cannot remember how to do so? I know I pushed a particular button and held it but it's been years since I've needed to change.
The TGA-101S isn't an answering machine, and thus doesn't have an outgoing message. Please consult the documentation for your answering machine, or else repost your question specifying the make and model of the answering machine.
Jan 29, 2013 | Panasonic KX-TGA101S Cordless Handset
How do I set up voice mail
Call services From your phone, you'll be able to access and change the settings of various call services for your phone.Contact your mobile operator to find out about the availability of call services. From the Home screen, press MENU and then tap Settings > Call. Fixed Dialing Numbers Restrict outgoing calls to a fixed set of numbers. To enable this feature, you must know your SIM card's PIN2 code.
Voicemail service Shows the current voicemail service being used.
Voicemail settings Specify another voicemail number aside from the voice mail number on your SIM card.
Clear voicemail notification If you have a notification of a new voicemail, you can clear the notification with this option.
TTY mode Enable this mode to connect and use a compatible TTY device with the phone.
Hearing aids Enable HAC (Hearing Aid Compatible) to amplify in-call volume.
Phone settings Edit the call reject message, choose whether to open the message editor when you reject a call with a message, and choose whether to allow automatic saving of an unknown contact number when a call with that number ends.
Cell broadcast Enable or disable receipt of cell broadcast messages from your service provider.
Cell broadcast settings Configure channels and language for cell broadcast messages.
Call forwarding Select how you want your phone to handle busy, unanswered, and unreachable calls. You can also set the call forwarding option for all incoming calls. Call barring settings Choose whether to block various categories of incoming and outgoing call.
Additional settings Enable or disable operator services such as caller ID and call waiting.
Jun 28, 2011 | HTC Inspire 4G Smartphone
I am trying to record my personal greeting on my message machine with the DECT 6.0...can you please explain to me how I can record my greetings?
Which model phone do you have? For the CL82509 and related DECT 6.0, you need to set the outgoing message from the handset when the answering machine is on. (It can be turned on from the handset).
For the outgoing message: with the handset in Idle mode, press Menu/Select. Use the up (Dir) and down (CID) arrows to highlight Ans Sys Setup. Then press Menu/Select. Use the same arrow keys to select Announcement and press Menu/Select again. Press 7 to record a new announcement. At the tone, speak your message clearly then press 5 when you have ended the message. The message will play back.
This model's manual is available here: . See page 15 to set the answering system outgoing message. (This is different than Voicemail. To set up Voicemail, you will need to see your telephone provider's documentation.)
Most AT&T phone manuals are available here: .
I hope this helps.
Apr 01, 2011 | AT&T DECT 6.0 Cordless Phone System with...
1) voice mail light blinks but don't know how to retrieve messages (we are renters and don't own phone) 2) Our outgoing works ok but we aren't getting messages.
You apparently have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Mar 04, 2011 | Vtech DECT 6.0 Cordless Phone with Digital...
How do you change the outgoing message on this phone?
Need to acces the mailbox for that phone as the mailbox owner, then enter the options menu and listen to the prompts to record the outgoing message.
Dec 08, 2010 | Lucent PARTNER18 Corded Phone
How do I record new outgoing voicemail message
depends on your provider, if you call your own phone number (voicemail) it should give you options to change a few things, if not contact ur provider
Dec 03, 2009 | Motorola Mobility W385 Cellular Phone
Cannot change outgoing message on Lucent Partner 18D phone system
For an extension of the Main Automated Attendant greeting when callers call in.
Which voicemail do you have? You indicated the phone model, but not the voicemail model.
Jun 16, 2009 | Avaya Lucent Partner 616 Phone
Record outgoing message
Call your service provider and ask them what their voicemail service number is an dset up your voicemail that way.
Mar 11, 2009 | Samsung SGH-G800 Cellular Phone
NorStar Nortel Aastra B0240402 Phone Ash M5208 24 x 2 LCD display MADN-capable(B0240402, M-5208, M 5208, 52... Logo
5,867 people viewed this question
Top NorStar Lands Phones Experts
Oloyede Monsuru
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
