Question about Abit AW8-MAX Motherboard
Abit AW8 LGA775 Maximum memory
Well, I initially build this computer with Corsair XMS 2x1GB sticks. I am running bios version 20 released on 5/23/2007. Everything was running great, but I wanted some more memory for some other apps I need to run.
- I did some research and found that the Phoenix AW8 Motherboard can support up to 8GB of memory. Currently I had the XMS (2) 1GB sticks at DDR2 240 pin 667mhz. So I decided to bu 4 2GB sticks and upgrade to 8GB.
- So Installed the new sticks and I had trouble even powering up the Box, the fans would kick on but nothing. I did notice the error code 00.
- So I started the 1 stick troubleshoot and it appears that i can ge 1 new 2GB stick to work or the 2 1GB sticks to work, But anything over 2GB, I had problems powering up my box.
Is there some bios setting that I am missing? maybe this is a power supply problem? I can get it to boot, but I need to turn it on and off a few times to get it so kick in, but it will never power up with more than 2GB of DDR2 667 240 pin sticks in it.
Thanks for the help,
  • Abit Master
  • 4,806 Answers
Hi there
Sounds like the bios will need updating as the board will support 8BG ram.
Put your old memory back in the machine, boot into windows, go to the motherboards manufacturers website and download the latest bios update and install it and reboot.
make sure you read the info on how to install the bios update.
I must also warn you that if you are using a 32bit operating system it will only recognize 2.9BG of memory, there is nothing you can do about this apart from install a 64bit operating system if the board supports 64bit processors.
Good luck and thanks for using Fixya!!!
Posted on Feb 11, 2009
Using Corsair XMS Memory 2 1g sticks and works good, tried putting 2 more memory modules to upgrade to 4g and goes into a post loop??
The memory should all match each other (same type). That board should handle up to 16gb using DDR2 1066/800/667 modules, although Win XP can only go to 3Gb.
Apr 27, 2010 | Gigabyte GA-EP45-UD3L Motherboard
My ABIT AW8-Max motherboard is showing an error "83", the manual I got of ine does not explain much other than saying "save all data in stack back to CMOS"! I dont really know what i need to do to fix...
Error message: 83h, Save all data in stack back to CMOS. 84h. Initialize ISA PnP boot devices.
First try clearing the cmos jumper on the motherboard. You will need the manual to help guide you. If you no longer have the Abit manual for the AW8-MAX motherboard you can download it by opening the link provided below; http://www.abit.com.tw/page/en/motherboard/motherboard_detail.php?pMODEL_NAME=AW8-MAX&fMTYPE=LGA775&pPRODINFO=Manual
Click on the blue arrow to start the download.
You will also need WinZip to uncompress the zip file.
Download Winzip @ this link; http://download.cnet.com/WinZip/3000-2250_4-10003164.html
Than you'll need Adobe reader to view the manual. Download and install Adobe @ http://www.adobe.com/products/reader/
Open the manual to page 2-8. Follow the instructions to clear the cmos. (Wait 30 seconds). Reset the cmos jumper back to normal. Boot you're system and press the Delete key on you're keyboard to enter the bios. Turn to page 3-1. Once the bios/cmos has been cleared the cmos resets the bios back to default settings. You will have to change some setting depending what is connected to you're motherboard.
When finished save and exit the bios. The system will auto restart. If you receive the error massage again than you'll need to replace the cmos battery. If after replacing the battery the error message still returns the last option would be to flash the bios/cmos with the latest bios. You'll find the bios file and bios utility/firmware from the Abit link below;
Cheers'
Mike
Mar 02, 2010 | Abit AW8-MAX Motherboard
What is the maximum size of hdd to used with abit kv7
Good day sir/maam, yes you can use a 1 TB HDD, get the SATA version depending on the bios but im not sure it be compatible with SATA1 on your motherboard, any new hard disk canor cant be read by any old motherboard, you may have problems with SATA versions, there are 3 versions, but the problem is the response of the hard disk. The rule of thumb, fast motherboards, for large hard disk, because it can access large amount of data very fast usually they are SATA3. So slow motherboards with large hard disk is kinda slow, you be bored. I suggest you stick on the recommended hard disk. If you want extra storage, get 3 hard disk and daisy chained them as master/slave.
Oct 14, 2009 | Abit : KV7 Socket A KT600 Motherboard
Motherboards
Can buy DDR2700 (333) Corsair XMS RAM - it is not alot more expensive but considerably higher quality than run-of-the-mill generic RAM.
The Radeon 9700 is a very good choise of card and it is not overly expensive - and everyone else will recommend it
Personal opinion.
Thanks.
Sep 08, 2009 | Computers & Internet
2G Memory Upgrade
I had similar problem with CORSAIR XMS2 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory
If this is your RAM:
Corsair 1024MB Value Select PC2-4200 (533MHz) DDR2 RAM, 128Mx64non-ECC, 240-pin DIMM, Unbuffered, CL4, Lifetime warranty (VS1GB533D2) Then it is high density. You need low density to work, look for one ending with an 8, not 64.
Feb 26, 2009 | PC Chips P23G Motherboard
I have 4 sticks of memory that are Corsair XMS 2x1024, (2GB) and I have already got 2 installed. My question is I have installed the other two and now have 4 sticks. The LED lights are working, but the...
winlogon.exe has become corrupted....shouldn't be memory related.....try using safe mode to restore your pc from a restore point....alternativly you'll need a boot disk like ERD commander to boot from cd and get to a restore point
Dec 30, 2008 | Corsair Memory 2GB PC6400 DDR2 Desktop...
My Abit NF7-S v2.0 only works with one memory module at a time
I have read that there are dual memory controllers (duel channel) and that when you use 2GB like that you are using 1 memory controller for each stick. Maybe one of your memory controllers is bad... maybe popped a cap? Sounds like time for a new MB. See this thread...
http://www.motherboardpoint.com/t61060-nf7s2-can-it-use-highdensity-memory-chips.html
Oct 23, 2008 | Abit nForce2 NF7-S2 Motherboard
Ram install
1. bad memory
2. the motherboard doesnt support single sided and dual at the same time.
3. bios needs update
4. wrong slots for dualchannel?
Apr 05, 2008 | Intel Motherboard
New system not booting
Check in the BIOS that your RAM and / or CPU speeds are correct or put them on auto. Choose Default BIOS settings first.
Aug 03, 2007 | Gigabyte GA-M61P-S3 Motherboard
Abit AW8-MAX Motherboard Logo
171 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
David
David
Jerry Umali
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
