Question about Powerware Series 9 9150 UPS System
Alarm mode question
I get 2 beeps every minute? I have reversed the incoming power leads (single-phase)
  • 167 Answers
Sounds like battery failed, check the connections and clean them, then try it again. see if the battery is ok, check voltage, and shake the battery, if you hear little objects rattle inside, it is bad. i hope this is helpful,good luck,glen also consider the unit could be shot.
Posted on Feb 13, 2009
Error light in my apc smart ups sc 1500va ups
1. Four beeps every 30seconds (On Battery LED will be illuminated)
This alarm indicates that the Battery PowerSupplied outlets are now supplying battery power as opposed to power from theutility. If the UPS determines that the input utility power is unsafe for yourcomputer equipment, the UPS will switch to battery power.
Note: Ifthe power disturbance is brief, you may only hear one or two beeps.
2. Continuous Beeping (On Battery LED will beilluminated)
This alarm indicates that a Low Batterycondition has been reached and that the UPS will soon shutdown. Once the UPStransfers to On Battery operation, it can only stay on battery for a limitedamount of time. The UPS will sound this alarm about two minutes before thebatteries are totally exhausted. Once exhausted, the UPS will shutdown and turnoff its output power to your equipment. If you hear this tone you shouldimmediately shutdown your computer to prevent data loss or corruption.
3. Continuous Beeps for 30 seconds (BackUPS OFFICE 250 and 280 ONLY)
This alarm indicates the unit has detected anOverload condition after it has performed a self-test during start-up.
4. Continuous Two-Tone Beep
This alarm indicates a severe Overload wasdetected while the unit was on-battery operation. This tone will continue tosound until the unit shuts down.
5. Continuous Tone (On Battery LED will beflashing)
This alarm indicates that the battery-poweredoutlets are overloaded.
6. Continuous Tone (On Line and On BatteryLEDs flashing) Back UPS OFFICE 350,400, and 500 ONLY
This alarm indicates that an internal UPS faulthas occurred.
Dec 08, 2011 | APC Smart-UPS SC 1500VA UPS System
@MY APC UPS SURT15KRMXLI is not charging after installation on single phase input
we have installed a new ups but the battery light indicates red light even though its on charge
Aug 12, 2011 | APC SMARTUPS RT 15KVA RM 230V...
We had a power outage for about 45 minutes a few days ago. Ever since then the Powerware 3110 has been beeping. I turned it off and left it plugged in overnight and when I turned it back on the beeping...
This could be several things, fortunately the device should actually be helping you to diagnose the issue. There are different beeps for different issues. They are as follows:
1 Beep Every 5 Seconds = Power Outage\Loose Plug Connection\Tripped Circuit Breaker\Power Cord Damage or Failure
2 Beeps Every 5 Seconds = Low Battery Alarm
3 Beeps Every 5 Seconds = Battery Needs Charging\Service\Replacement
3 Beeps Every 5 Minutes = The Battery is discharged and battery power is unavailable (If this continues battery replacement may be necessary)
1 Beep Ever 1/2 Second = Power Requirements exceed the UPS Capacity (remove some equipment to lighten the load on the unit)
Continuous Beep = Short Circuit / Input Voltage out of Range / UPS Fault (Likely replacement of entire unit)
That should help diagnose the actual issue. If it turns out the battery needs to be replaced they can be found online for around $20. A simple google search for Powerware 3110 Battery should return what you're after. Good luck!
May 05, 2011 | Powerware 3110 UPS System
SO bad, and a bad response... I have 2 UPCs one started beeping for no reason, and will not stop...even when plugged into the wall with the battery disconnected... The other one is still silent. SO the...
These beep error codes may help you.
1. Four beeps every 30 seconds (On Battery LEDwill be illuminated)
This alarm indicates that the Battery Power Suppliedoutlets are now supplying battery power as opposed to power from the utility.If the UPS determines that the input utility power is unsafe for your computerequipment, the UPS will switch to battery power.
This alarm indicates that a Low Battery condition hasbeen reached and that the UPS will soon shutdown. Once the UPS transfers to OnBattery operation, it can only stay on battery for a limited amount of time.The UPS will sound this alarm about two minutes before the batteries aretotally exhausted. Once exhausted, the UPS will shutdown and turn off itsoutput power to your equipment. If you hear this tone you should immediatelyshutdown your computer to prevent data loss or corruption.
3. Continuous Beeps for 30 seconds (Back UPSOFFICE 250 and 280 ONLY)
This alarm indicates the unit has detected an Overloadcondition after it has performed a self-test during start-up.
This alarm indicates a severe Overload was detectedwhile the unit was on-battery operation. This tone will continue to sound untilthe unit shuts down.
This alarm indicates that the battery-powered outletsare overloaded.
6. Continuous Tone (On Line and On Battery LEDsflashing) Back UPS OFFICE 350, 400, and 500 ONLY
This alarm indicates that an internal UPS fault hasoccurred.
Feb 28, 2011 | APC Back-UPS Pro 650 UPS System
I have a ups system that i am feeding with 240 vac phase to phase and both phase to ground readings are 120 vac but when i go to battery power i get 240 vac phase to phase and 1 phase to ground i get 220...
No, I don't think there is anything wrong. Your UPS seems to have a single phase 240V output, which seems to be "floating" (no or only a weak ground reference).
Just be aware that you can only power 240V equipment from it. If you need 120V for some devices _and_ if the UPS provides sine wave output, you could use a step down transformer for this purpose.
Mar 12, 2010 | Tripp Lite Smart Pro UPS System
Strange noise comes out from the ups after a power cut
The Back-UPS Office unit has five different tones or alarms:
1. Four beeps every 30 seconds (On Battery LED will be illuminated)
This alarm indicates that the Battery Power Supplied outlets are now supplying battery power as opposed to power from the utility. If the UPS determines that the input utility power is unsafe for your computer equipment, the UPS will switch to battery power.
Note: If the power disturbance is brief, you may only hear one or two beeps.
2. Continuous Beeping (On Battery LED will be illuminated)
This alarm indicates that a Low Battery condition has been reached and that the UPS will soon shutdown. Once the UPS transfers to On Battery operation, it can only stay on battery for a limited amount of time. The UPS will sound this alarm about two minutes before the batteries are totally exhausted. Once exhausted, the UPS will shutdown and turn off its output power to your equipment. If you hear this tone you should immediately shutdown your computer to prevent data loss or corruption.
3. Continuous Beeps for 30 seconds (Back UPS OFFICE 250 and 280 ONLY)
This alarm indicates the unit has detected an Overload condition after it has performed a self-test during start-up.
This alarm indicates a severe Overload was detected while the unit was on-battery operation. This tone will continue to sound until the unit shuts down.
5. Continuous Tone (On Battery LED will be flashing)
This alarm indicates that the battery-powered outlets are overloaded.
6. Continuous Tone (On Line and On Battery LEDs flashing) Back UPS OFFICE 350, 400, and 500 ONLY
This alarm indicates that an internal UPS fault has occurred.
Jan 06, 2010 | APC Back-UPS ES 700 - UPS ( external ) -...
A-12 Alarm wont go away
I have an ut8k UPS I am getting an A-12 alarm. On the cover it means "tap the regulator alarm. I opened up the unit ...
May 28, 2009 | Powerware Best Power Unity/I Single-Phase...
Opti-UPS 1400ES UPS unit - Beeping 14 Times, stops, Beeps Again.
you can try this asia systems technologies look for our sale person william +65 65478990 william@asiasystemstech.com i suspected that now that u UPS is have hardware issue.. to determine if the unit is really the problem it hav to be do a further diagnos..
Mar 04, 2009 | Opti -UPS PowerES 1400 UPS System
Unwaranted UT3K UPS check battery warning
Hi!
1) By the way, batteries are really new (or "China new")? ;)
If they really new then maybe not start-formed. In this case after little time they will get steady (end of problem). If they are "China new" - it worse, their real capacity usually less then 75% from declared.
2) Try to check batteries connectors, wires and their eyelets. If there is weak contact - charging will be wrong (low current)...
3) Check small orange (voltage sence) connector...
4) Look, what happened with P-62, P-63, P-74 ang P-75 settings? maybe there something is wrong...
Maybe, it will be helpfull?
P.S. Please, excuse my weak english.
Feb 10, 2009 | Powerware Best Power Unity/I UPS System
Beeping and clicks off
When it beeps, that is the internal alarm indicating that incoming AC is not there. It probably clicks off due to the batterys not being charged.
Jun 19, 2008 | APC Smart-UPS 1500VA Shipboard...
Powerware Series 9 9150 UPS System Logo
145 people viewed this question
Top Powerware Computers & Internet Experts
Jax Planet
Jax Planet
Are you a Powerware Computer and Internet Expert? Answer questions, earn points and help others
