Question about Sharp AL 1631 Copier
"l" appears when this copier is warmed up ,but it want copy
Whe we turn on the copier it warms up then we set for maybe 2or more copies we hit the copy ( C ) button and the Letter " L " appears. any suggestions.
"L" and what number? 1?
The scan head is locked. Unlock it
Manual is here:
http://www.sharpusa.com/files/cop_man_AL1641CS_1631.pdf
Posted on Feb 26, 2009
I believe the copier is not warming up as needed to. the code h3-01 appeared on the display screen i have cleared the code but it is taking alot of time to warm up as if its stuck trying to warm up. what...
H3-01 = High temperature detection.
Your copier is warming up ok but for some reason the correct temperature is not being sensed and the machine is detecting 'overheat' and switching off.
First, check that there is no paper stuck inside the fuser unit - it may be blocking the temperature sensor (thermistor).
Does the fuser unit feel warm after the error code is displayed?
Try resetting the code:
P,*,C,*,14,[copy button] ( P,STAR,C,STAR,14,COPY BUTTON)
The machine should reboot.
Hope this helps.
Jan 06, 2011 | Sharp AR-M350U Copier
When I try to print a copy, display says "warming
A well documented problem. Try following the suggestions posted here
Dec 03, 2010 | HP PSC 750 All-In-One InkJet Printer
Smudges on paper and then when it does copy, ink is light.
hi,check copy cartridge or clean corotron wire.try to increase toner.send me result.
thank you.
May 25, 2009 | Sharp AR-5320 Black and White Copier
Locked up AL-1642CS with blinking Drum Light
the clear key may be stuck which seems to lock up your machine. The procedure to reset the drum lite is clear, auto (exposure setting), clear, auto when hit in a timely manner the display will go blank. Enter 24 then press the start key, then enter 07 and press the start key again. If you can't get the keys to work the circuit board may have cold solder joints.
Good luck
Bob
May 03, 2009 | Sharp AL-1642CS Copier
F35 error code
Warm-up was not completed
within a specified period from
the start of warm-up.
• The low fixing temperature
fault detection software is
activated.
The fixing temperature at the
end of warm-up is less than the
specified temperature.
activated.
The fixing lamp does not turn
OFF within the specified period.
SOLUTION
Rewrite the data at
address “P47” in the
25 mode to “0”.
(1) Turn the main switch OFF.
(2) While pressing the numerical keys 2 and 5 of the copy
quantity setting button, turn the main switch ON. This
will enable the 25 Mode. The 25 Mode is used exclusively
to rewrite in memory and, therefore, does not
support normal copy operations.
Apr 21, 2009 | Konica Minolta Office Equipment & Supplies
Longer warm up time accompanied by a loud grinding noise
There are few gears inside the copier that probably need to be replaced causing the grind and the copy quality to happen. It wasn't looked at by the engineer at the time because it happened after they left. They should come back in to fix it.
Aug 30, 2008 | Sharp AR-5316 Advanced Digital Imager...
System fault
Refer to the link i posted and put in you question in the box and that should give you a correct information as its the manufacturer.
May 13, 2008 | Xerox DocuColor 12 Printer
Copier is showing warming up but will not start
the fuser unit has ceased to heat...it has a bad heater. the fuser is a hollow metal roller that usually has a powerful light inside to heat the metal. a continuity test can detect
Mar 21, 2007 | Panasonic Workio DP-150PA Copier
Panasonic DP150 FX Workio information screen is saying "Warming Up"
remove the paper drawer and check at the back of the mc where the cassette was for paper
Sharp AL 1631 Copier Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
