Question about Dryers
Sheets aren't drying
Flannel sheets are rolling up in a ball and not drying,same for loads on clothes, they aren't drying.I recently replaced the exhaust line.Since then we have had this problem.Did I plug an air intake ?
  • boconnor933 Feb 11, 2009
    Checking the exterior vent,the air flow is good.
    Scholar:
  • 105 Answers
Sounds like out take, something blocking the vent, pinched line, birds nest, snow?
Posted on Feb 11, 2009
  • Cary Crook Feb 12, 2009
    Great, good airflow, so now there still could be an internal lint issue, but it may be your thermostat or high limit switch going, possibly the element. What kind of dryer is it? Model number?
Clothes roll into a ball on matag dryer
As you insert the clothing into the dryer make sure you open up the larger pieces fully so they do not ball up. Frequently people put large bed sheets in before opening them up and everything gets rolled inside them. If your load is too small, that might happen, also!
Jan 10, 2013 | Dryers
Two sets of sheets and the dryer wads the sheets in a ball and takes forever to dry. Then I untangle them and try again and still the same wadding up. Checked with other front loader owners and it...
I have Design a new solution it is the Dwadder.
Dwadder made from HDPE plastic. The Dwadder is the first ever Dryer Device that does dry your sheets and blankets faster! The Dwadder keeps your sheets and blankets from wadding up in the dryer. This will save you Time and Money when drying. Dwadder can cut your drying time up to 30 mins or more. Two sheets or blankets can be strapped to the Dwadder at a time to keep from wadding up in the dryer.
One of the most time-consuming uses of a dryer is drying blankets and sheets. The reason it takes so long is the blanket or sheet can be twisted into a tight wad or ball during the drying cycle. Once this happens the dryer is incapable of drying the center of the wadded blanket or sheet. The solution today is to take the blanket or sheet out of the dryer halfway through the drying cycle and unwad the bundle of sheets or blankets. Then place the blanket or sheet back into the dryer to restart the dryer cycle over and over again until the blanket or sheet is dried. If you forget to unwad the blanket or sheet when you get ready to make the bed, the blanket and or the sheet will be wet.In order to fix this problem, the Dwadder is strapped to the sheet or blanket using a silicone cord before it is placed in the dryer. Once the dryer is started the blanket or sheet will wrap around the Dwadder allowing a space to be in the center of the blanket or sheet. With the space that is created by the Dwadder the center of your blanket and sheet will dry faster and will not roll into a tight ball or cylinder shape. This will help save time drying your sheets and blankets. The device will also prevent wadding of your sheets and blankets so you don't have to unwad your blankets and sheets half way between the drying cycles.
How to Use the Dwadder
Simply pull half of your blanket or sheet out of the washer. Then pull the silicone cord to slide the blanket or sheet between the silicone cord and the Dwadder. Slide the Dwadder to the center of the sheet or blanket then put your blanket or sheet in the dryer with the Dwadder attach to your blanket or sheet. You can use both silicone cords for two small blankets or sheets just don't place 2 blankets or sheet on top of each other or it will take longer to dry. For Video instructions please go to the website at www.Defuturesolutions.com or Youtube.
Apr 02, 2011 | Samsung DV337 Electric Dryer
When I dry sheets they ball up into a twisted wad and do not dry evenly. Do you have advice for this problem?
Lisa I find if you put sheets in with other items such as towels this can work to prevent them rolling into a ball and not drying evenly.
Jan 20, 2011 | Kitchen Ranges
Whirpool Cabio washer knots clothes/sheets into tight balls
whirlpool had a service bulletin on this. New agitator design. replace with new design.
Mar 14, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Clothes and sheets come out wrinkled and twisted
Try not to wash large items with small items the large items like sheet will twist around the small item. causeing twisting and wrinkling. Also If you are overloading the clothes or underloading the clothes they will come out wrinkled. I would try to do some testing wash a load of only towels then wash a load of only t-shirts and other light weight items that you may have. Then do just a load of your jeans. What happens? Please let me know
Jan 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Twisted sheets
dry your sheets separately.
Oct 28, 2008 | Kenmore Elite HE4 Electric Dryer
Sheets wind together in a damp ball
I have a different model Bosch dryer, but I have the same problem.
I've found that the flat sheets dry okay if you have them in with other things (like pillowcases and t-shirts). I learned long ago though that you can't put those things in with deep fitted sheets; the little stuff winds up caught in the corners in damp wrinkly wads.
So I dry the fitted sheet separately, and throw in a couple of clean tennis balls. They're noisy, but harmless, and they keep the sheet from balling up.
Oct 26, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Rolling into balls
There is nothing you can do about this. the disadvantage of sheets and blankets.
May 07, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Dryers Logo
113 people viewed this question
Top Dryers Experts
