Question about Motorola TalkAbout T5000 2-Way Radio
I can rx transmissions but they can't hear me.
We can hear it talking but no one can hear when we answer back
  • mt6391910 Mar 21, 2009
    I have a motorola fv 200 and when I try to use it with my t5000 I can hear transmission from the t5000 but i can't hear from the fv200. when i press the monitor button on the t5000 i am able to hear from thefv200
  • Motorola Master
  • 1,641 Answers
Check the settings of both your interference code eliminator and your Qt filter (if your model has one). These codes need to match the other radios exactly. If the other radios have a Qt filter and your unit does not, then the Qt filter would need to be shut off on the other units.
Posted on Feb 11, 2009
Why does my new Honda CB always show RX receiving transmission no matter where squelch is set?
if this is on a Goldwing, it appears that you have a shorted pin int he connector. Disconnect the radio and make sure all of the pins are straight and connecting properly.
Oct 02, 2014 | Radio Communications
Does the connex 3300hp have talk back
Any radio can have Talk Back.. all it is is leaving the RX active on TX and the sampled audio goes to the speaker that you can hear....
Feb 17, 2014 | Connex 3300 240-Channels Base CB Radio
I can talk through one device and hear fine on the other, but cant hear anything when i talk into the other device
verify, either the operating frequency is not pair/same with the other radio, check the default frequency, tx/rx on the simplex mode should be the same frequency
Nov 21, 2013 | BellSouth Radio Communications
How do you get the RX icon to turn off? The unit just has a contant fuzzy buzz.
RX represents "receive" This indication will be present whenever the speaker is producing audio. The "buzz" you're talking about is probably static, and is technically audio from the speaker. To silence the "buzz" adjust the squelch just until the speaker falls silent. The RX indication should be off at this point.
It is important to note that the squelch is designed to keep the speaker silent until a signal is detected. You adjust the squelch based on the level of static at a particular time and at a particular location. The static level may change depending on those variables. If you adjust the squelch well beyond the point that the speaker is silenced, you may not be able to hear transmissions or calls to you unless the caller's transmitter is physically close to you. This is why the squelch should be adjusted only until the static is stopped and the speaker is silenced.
I hope this helps and good luck!
Apr 30, 2012 | Radio Communications
Radio transmits fine but the receive volume is way down. Can hardly hear it with volume turned up full.
If you have talk back in this radio.( you hear your self through the radio when you transmit) then its a good bet that the RX wire in the mic plug has broken off.
The mic switch is responsible for putting the radio into receive mode when you release the key. If the RX wire is broken, the radio will not go into receive.
Normally when this happens you have no receive at all no matter what, but you will have very low sound if you have talk back installed in the radio.
Because of this, if you have talk back in your radio, and the volume is faint even at full blast, its a good bet that its a broken RX wire in the mic cord or plug.
You can attempt to see if the break is at the mic plug. if it is, you can re solder it and it will solve your problem. If you have no clue, then you can just go buy new 4 pin mic.
Nov 14, 2010 | Uniden PRO510XL 40-Channels Base CB Radio
Please send me Canon Ir all model Error code. How can solve it?
Error codes for iR2016i,2020i for other machines codes you need to get the specific manual, these manuals can be downloaded from Ebay, look for user ID ultimate_sacrifice A seller on Ebay.
No. Tx/Rx Description
##0100 [Tx] at time of transmission, the procedural signal has been transmitted more than
specified.
##0101 [Tx/Rx] the modem speed does not match that of the other party.
##0102 [Tx] at time of transmission, fall-back cannot be used.
##0103 [Rx] at time of reception, EOL cannot be detected for 5 sec (15 sec if CBT).
##0104 [Tx] at time of transmission, RTN or PIN is received.
##0106 [Rx] at time of reception, the procedural signal is received for 6 sec while in wait for the
signal.
##0107 [Rx] at time of reception, the transmitting party cannot use fall-back.
##0109 [Tx] at time of transmission, a signal other than DIS, DTC, FTT, CFR, or CRP is
received, and the procedural signal has been sent more than specified.
##0111 [Tx/Rx] memory error has occurred.
##0114 [Rx] at time of reception, RTN is transmitted.
##0200 [Rx] at time of reception, no image carrier is detected for 5 sec.
##0201 [Tx/Rx] DCN is received outside the normal parity procedure.
##0220 [Tx/Rx] system error (main program out of control) has occurred.
##0232 [Tx] encoding error has occurred.
##0237 [Rx] decoding error has occurred.
##0261 [Tx/Rx] system error has occurred.
##0280 [Tx] at time of transmission, the procedural signal has been transmitted more than
specified.
##0281 [Tx] at time of transmission, the procedural signal has been transmitted more than
specified.
##0282 [Tx] at time of transmission, the procedural signal has been transmitted more than
specified.
##0283 [Tx] at time of transmission, the procedural signal has been transmitted more than
specified.
##0284 [Tx] at time of transmission, DCN is received after transmission of TCF.
##0285 [Tx] at time of transmission, DCN is received after transmission of EOP.
##0286 [Tx] at time of transmission, DCN is received after transmission of EOM.
##0287 [Tx] at time of transmission DCN is received after transmission of MPS.
##0288 [Tx] after transmission of EOP, a signal other than PIN, PIP, MCF, RTP, or RTN has
been received.
##0289 [Tx] after transmission of EOM, a signal other than PIN, PIP, MCF, RTP, or RTN has
been received.
##0290 [Tx] after transmission of MPS, a signal other than PIN, PIP, MCF, RTP, or RTN has
been received.
##0670 [Tx] at time of V.8 late start, the V.8 ability of DIS front the receiving party is expected
to be detected, and the CI signal is expected to be transmitted in response; however,
the procedure fails to advance, and the line is released because of T1 time-out.
##0671 [Rx] at time of V.8 arrival, procedure fails to move to phase 2 after detection of CM
signal from caller, causing T1 time-out and releasing line
##0672 [Tx] at time of V.34 transmission, a shift in procedure from phase 2 to phase 3 and
thereafter stops, causing the machine to release the line and suffer T1 timeout.
Dec 12, 2009 | Office Equipment & Supplies
Cannot send or receive a fax. I can hear a click when I hit tone and that?s it. It worked before but after I fixed error 6502 nothing.
(2) Service error codes
on.
- Logic board
#001 TX Document jam
#003 TX / RX Document is too long, or page time-over
#005 TX / RX Initial identification (T0 / T1) time-over
#009 RX Recording paper jam, or no recording paper
#012 TX No recording paper at the receiving machine
#017 TX Redial time-over, but no DT detected
#018 TX Auto dialing transmission error, or redial time-over
#022 TX Call failed (no dial registration)
#037 RX Memory overflow at reception of an image
#085 TX No color fax function supported in the receiving machine
#099 TX / RX Transmission terminated mid-way by pressing the Stop/Reset button
#995 TX / RX During TX (sending): Memory transmission reservation cancelled
During RX (receiving): Image data received in the memory cleared
Error code TX / RX Meaning
##100 TX Re-transmission of the procedure signal has been attempted the specified number of times, but failed.
##101 TX / RX Sender's modem speed does not match the receiving machine.
##102 TX Fallback is not available.
##103 RX EOL has not been detected for 5 seconds (or 15 seconds in CBT).
##104 TX RTN or PIN has been received.
##106 RX The procedure signal has been expected for 6 seconds, but not received.
##107 RX Fallback is not available at the sending machine.
##109 TX After DCS transmission, a signal other than DIS, DTC, FTT, CFR, or CRP has been received, and re-transmission of the
procedure signal has been attempted the specified number of times but failed.
##111 TX / RX Memory error
##114 RX RTN has been received.
##200 RX A carrier has not been detected for 5 seconds during image reception.
##201 TX / RX DCN has been received in a method other than the binary procedure.
##204 TX DTC has been received even when there is no sending data.
##220 TX / RX System error (main program hang-up)
##224 TX / RX An error has occurred in the procedure signal in G3 transmission.
##226 TX / RX The stack pointer has shifted from the RAM area.
##229 RX The recording area has been locked for 1 minute.
##232 TX The encoder control unit has malfunctioned.
##237 RX The decoder control unit has malfunctioned.
##238 RX The print control unit has malfunctioned.
##261 TX / RX A system error has occurred between the modem and the system control board.
1-7
Oct 13, 2009 | Canon PIXMA MP830 All-In-One InkJet...
on.
- Logic board
I can't hear through my internal or external cb speaker
Can you hear static when the squelch is at minimum ?. If you can hear static then tere is nothing wrong with the audio system. If you are sure about the squelch, connect goosd speaker directly to the 2 wires coming from the main board bypassing the speker jack. if there is still no sound then the audio amp chip is defective. The audio amp can only be damaged if the output is shorted for a long period of time.
Mar 02, 2007 | Uniden PC78ELITE 40-Channels Base CB Radio
Motorola TalkAbout T5000 2-Way Radio Logo
462 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Iron
Iron
OBHighflyer
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
