Question about Dell XPS M1530 Laptop
Unable to connect ETHERNET
We have changed the OS to Fedora Core9 64 bit for work station. After that we are unable to get Ethernet. We have downloaded the Device driver for Intel(R)82567 Gigabit network adaptor from the internet and tried. It is installed successfully but still unable to get Ethernet connection. It is not getting activated
    Problem Solver:
  • 17 Answers
Try These Things: 1 Shut Down Computer, 2 Unplug Ethernet Cable From Modem, 3 RESET MODEM, 4 Plug Back in Ethernet Cable From Modem To Computer and 5 Power On Computer. That Should Help You.
Posted on Feb 12, 2009
Gateway Gt 5220 computer will not connect to internet
Open the Device Manager, Network Adapters, Is the Ethernet adapter enabled? Do ALL your Windows and Gateway updates. Your Ethernet driver can be found here, select your OS, 32 or 64 bit : http://support.gateway.com/us/en/product/default.aspx?tab=1&modelId=2890
Feb 13, 2013 | Gateway GT5220 PC Desktop
I am trying to connect a Mac ibook to my cable modem
Use Network preferences to verify your TCP/IP settings and that Built-in Ethernet is your primary network interface. Follow these steps if you are using Mac OS X v10.5:
  1. From the Apple menu, choose System Preferences.
  2. From the View menu, choose Network
  3. Be sure that "Built-in Ethernet" has not the status Inactive listed below the entry in the list of network ports.
  4. Make sure Built-in Ethernet is the selected, or primary, network interface: Click the action button (gear icon) below the list of network port and choose "Set Service Order...".Services can be dragged to change order. Services are listed with descending priority.
  5. Select a network port in the list of port to configure it.
  6. Click Advanced..., then click the TCP/IP tab.
  7. Follow your ISP's instructions for setting up this pane. For more information, see Mac OS X: How to Connect to the Internet With Cable or DSL.
  8. Click OK when finished.
  9. If you have made any changes, click Apply Now.
If you are using Mac OS X 10.4
  2. From the View menu, choose Network.
  3. Choose Active Network Ports from the Show pop-up menu.
  4. Be sure that the checkbox for "Built-in Ethernet" is selected.
  5. Drag Built-in Ethernet to the top of the Port Configurations list to make it the preferred, or primary, network interface.
  6. Choose "Built-in Ethernet" from the "Show" pop-up menu.
  7. Click TCP/IP.
  8. Follow your ISP's instructions for setting up this pane. For more information, see Mac OS X: How to Connect to the Internet With Cable or DSL.
Jul 11, 2011 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Not able to get an IP from the network when connecting thru the Targus docking station model ( APC51US) i am on windows 7. note that i am using the same cable adn it work fine when i connect it to the...
In order to use the ethernet card on your Docking Station ( or Port Replicator), you must first disable any internal Ethernet cards.
To do this:
  1. Type "Network Connections" in the Start Menu seach box, and press enter.
  2. Right click on your computer's internal ethernet adapter (i.e. "Local Area Connection" & select "Disable"
Ref: Targus Support
Apr 19, 2011 | Targus Port Replicator, Docking Station,...
F5d5050 Belkin USB 10/100 Ethernet Adaptor - Does it work with Windows 7 64 bit OS? I have spent hours trying to install a Swann and a Digitech product but none seem to work with the above OS. Any...
You cannot install this adapter in a Win 7 computer because the drivers are not compatible with Win 7.
So far Belkin haven't updated the drivers for win 7 OS. The latest drivers for this adapter is compatible only with
" Windows 98SE, Windows Me, Windows 2000, Windows XP 32-bit, Windows Vista 32-bit "
Click here to see the belkin compatible drivers in the website.
With Regards,
Prema.
Jan 06, 2011 | Belkin Ethernet Adapter F5D5050 Network...
Lenovo WinXP - Ethernet port issue
Hi. Try to check the steps as give below.
  1. Check the ethernet port with other spare wire if you have to check if it is a wire problem or if it is itself your ethernet port.
  2. Try to connect your ethernet port directly to the router to make sure ethernet port is working and there is no connectivity issue with the switch.
  3. Try to check the System BIOS settings and see if it is not disabled from there.
  4. Lastly download any free Live OS of Linux and boot your computer using it. See if the ethernet card is working or not.
Steps from 1-3 is for checking physical connectivity of the ethernet port and the last step is for checking OS issue. If network card do not work with Live OS as well, you can directly come to conclusion that its ethernet card that is not working properly and you need to get is repaired.
Cheers!
Apr 14, 2010 | Lenovo Thinkpad T60 Notebook
Platform: Sony VGN-BZ569P (vgn-560 series) Docking Station: Sony VGP-VRBZ1 OS: XP-SP3 Problem: When docked, there is no network connectivity through the docking station's Ethernet port. Device...
The problem is definitely not with your docking station. Its the ethernet controller that is faulty. Possible reasons can be incorrect driver or device failure(not very unusual).
You said that you "have tried to install drivers from Marvell but no luck". This most likely indicates the device(ethernet controller) failure. Anyways try to download the drivers from the link below and give it one more shot.
Click here
If it still doesn't work a new ethernet controller card should do the trick. Considering the fact that you can get a good one from brands like D-link, Realtek etc., for about 25$ it shouldn't be much of a problem.
Hope this helps,
Sai.
Jan 26, 2010 | Sony (VGP-PRFE1) Docking Station for VAIO®...
Toshiba Cable Modem PCX1100u
OK. First of all you do not need a special or seperate driver for the Ethernet port. Its factory loaded with your OS.
All you need to do is plug the Ethernet cable into the LAN port on your HP Desktop and then into the LAN port (not the WAN port) of your cable modem.
The second thing is if its only a cable modem, then I suggest you proceed with caution as there is NO built-in firewall on a cable modem. Yes you will get on the net, but you are likely to be attacked with virus the moment you connect. I suggest you check very carefully whether the cable modem (if that's what it is) does/does not have a firewall as you would be very unwise connecting up like that.
Next, forget USB connection to the router/cable modem. That technolgy we've moved on from.. Your Vista shodul be 'plug n play' adn should configure the router for you. obviously that bit isn't so slick on yours.
Let me know how you get on..
Aug 31, 2008 | Toshiba PCX1100U High Speed Cable Modem
Cannot obtain internet
if you already have an ethernet card installed in the laptop, then it should be fine. did you try rebooting the modem that you are hooking the laptop to? Sometimes with different ISPs that is one of the major issues.
May 27, 2008 | Compaq Armada E500 Notebook
No ethernet with docking station
It could be the connector on the bottom of your laptop that's creating the problem. Does any other ports work on the docking station when docked?
Jan 14, 2008 | IBM ThinkPad T43 Notebook
Sony vaio r505jl docking station
I googled this and found that both the notebook itself and the docking station have ethernet connections, the docking station ethernet connection seems to be between the usb and monitor connection, The notebook itself has a ethernet connection on the right side of the notebook near the back under a rubber cover. Let me know if that was correct or not.
Oct 16, 2007 | Sony VAIO R505JL Notebook
Dell XPS M1530 Laptop Logo
170 people viewed this question
Alun Cox
