Question about GE XL1800 1100 Watts Microwave Oven
When opening the door a venting sound immediately starts up.
I have a GE Spacemaker XL1800.It will still let you cook and will stop until you open door again. Sometimes a warning will flash to change the charcoal filter. Please advise.
  • William Miller
    William Miller May 11, 2010
    but your subject line was too long and got cut off.
    Please reply
    back with your full model number fro,m the tag and specific symptoms
    so we can help you
    It will be something like JVM18##xx##, etc.
  • GE Master
  • 9,098 Answers
The charcoal filter needs to be changed every 6-12 months, or sooner if it gets clogged.
You can download GE owner's manuals and installation instructions here.
You can find helpful exploded view diagrams and order parts (including charcoal filters) by entering your full model number from the tag on the oven here.
Posted on Feb 15, 2009
GE Spacemaker XL 1800 turns on for 1 second and then resets. The display shows PRESS CLOCK.
Sounds like your losing power, have you tried it on a completely Different circuit??? Either that or bad fuse or connections inside of microwave.
Sep 08, 2017 | GE Microwave Ovens
My ge spacemaker xl1800 light and fan turn on when door is opened. small piece of foil does not spark during this. is there an easy fix?
Kent, most microwaves will turn on the light when you open the door. As for the fan coming on, does it do that all of the time or only after you have used it for a period of time? If it does only after you have used it, you might want to check the back and the underneath of your microwave to see where the fan draws air into the unit and clean any lint built up on the vent holes. Hope this helps!
Feb 09, 2015 | GE JVM3670SK Profile Spacemaker XL1800...
I have a GE Spacesmaker model #JVM1440BH04 that came on by itself and can't be shut off unless the door is opened. It does not seem to be cooking since nothing heats up unless the cook start buttons are...
The problem is in one of the door switches, "it is defective" this is a highly dangerous situation and should be checked immediately, the microwave oven should unplugged until a appliance repairman looks at it.
Jan 18, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
GE SPACEMAKER XL1800 IS NOT HEATING FOOD - GIVING "SENSOR ERROR" ON DISPLAY. I am a handy guy capapble of fixing if you can help me out w/the part I need
if you have a sensor, it means, the door was opened before steam could be detected. Do not open the door until stream is sensed and time is shown counting down on the display.
Steam was not detected in the maximum amount of time. Use Time Cook to heat for more time.The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
Jun 16, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE Spacemaker XL1800 over stove does not cook
This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If the switch mount is broken, it's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you only need a switch, you can order a universal type here for $5 postpaid.
Apr 18, 2010 | GE Microwave Ovens
I have a GE Spacemaker xl1800 - Funny noise, flickering light
very possible your magnatron is faulty. Disconnect 2 transformer wires and make sure they dont short. try the program again. if no noise, replace magnatron:capacitor and HV diode Please i strongly suggest an electrician help you as it is truely dangerous in there. .
Sep 15, 2009 | Microwave Ovens
GE XL1800 Micro fan won't shut off after light burned out
The problem appears, at least in part, to the door latch circuitry which cannot be serviced by the owner. If the unit is still in warranty, call GE customer care. If not, replacing the unit is your best bet. I just bought a new GE 1100 watt oven with great features for less than $100 If the door dosen't latch correctly, you could be exposed to dangerous microwave energy.
Nov 15, 2008 | GE XL1800 1100 Watts Microwave Oven
A simple test is to place a piece of bread in the microwave ( it heats up very fast) and then if your microwave was actually ON and generating RF, the bread would get hot very fast.. If it remains cool then only the fan is on. It appears that you may have a faulty door switch thou because once you open the door, your microwave should be off..
Are you sure the VENT is not on? That blower will operate regardless of the door open or closed so you must switch it OFF.
Sep 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Micro stopped working
Try looking at the microswitches behind the door.
Apr 05, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE spacemaker Profile XL1800 vent fan will not shut off
It may be a bad door switch, a loose door switch mount, or a problem on the control panel, such as a sticky relay.
I would suspect a sticky relay first, but the door switches should be checked.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya:
If you need your control panel assembly (smart board) repaired, we do that for $39.95 nationwide.
You can find helpful exploded view diagrams and order parts by entering your full model number here:
Dec 02, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE XL1800 1100 Watts Microwave Oven Logo
205 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
