Question about Xerox WorkCentre 4150 All-In-One Laser Printer
Xerox 4150 prints from Macs but not from XP
For whatever reason, printing stopped from my Xerox Workcentre 4150 yesterday.
I get an error message "PCL6 ERROR - undefined XL code".
I tried reinstalling drivers but when adding a printer (install method according to Xerox), XP will not find one on the network.
I installed X64 drivers on a Dell Laptop with Vista, and the printer was recognized and installed just fine.
Macs on the network can print no problem.
XP on an old hp pavilion laptop is where the problems remain.
Any thoughts?
  • Charles Lamm
    Charles Lamm Feb 12, 2009
    We have a service agreement with the copier company, and I will mention the firmware to them.
    I went for a quick fix and did a system restore to last week. I don't know what corrupted the drivers, but if it happens again, I can probably determine the culprit.
    Thanks for your help.
    President:
  • 2,072 Answers
Have you updated the machine firmware? At Xerox.com the machine firmware is there to download and install. Currently the firmeware is at level 10.100.45.018. Even if your machine is new you may have an older version of firmware.
That machine has had tons of firmware updates to it and uploading the machine to the newest level probably will resolve your problem.
There are some versions that fix 300 known problems at an update.
You have to follow the directions carefully, updating it can wipe out your LDAP settings if you use scan to E-mail etc.
If you have a maintenance agreement, or the machine is less than a year old, ( there is a one year on site warrantee on that machine for on site service) call 1-800-821-2797 and request a service call to update your firmware.
Those updates are really critical for that machine to operate properly.
Posted on Feb 12, 2009
  • Rick Kasper Feb 12, 2009
    If your using an AS400 server, the new firmware is designed to resolve those issues. But I really believe the new firmware will help you. Those updates even resolve some copy/print quality issues, toner consumption and just some quarky problems.
    I am not saying this to say that the machine is not a good machine, Please don't misinterpret my comments as that. The 4150 runs well, but he fiurmware update really improves the performance. Most things operators don't really see, but in the long run they improve productivity.
Xerox workcentre 4150 not printing test page on windows 7
Hi Cnorini ,
Check this video and solve your problem.
In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On : Xerox Printer Support
Mar 04, 2014 | Xerox WorkCentre 4150 Black and White...
Xerox Workcentre 4150. Paper keeps jamming in print engine area. We clear the jam and it jams again.
If your Xerox WC 4150 is displaying "Clear the Jam in the Print Engine" or constantly jams as paper exits the machine you should check and possibly replace the fuser actuator (part# 120N00534) This is the most likely cause, if however this does not fix the printer the next step may be to replace the sensor or fuser.
Here is a video that shows you how to check and replace the actuator. ItemInc.com has this part in stock and ships same day. Good luck, and thanks for using FixYa!
Jun 23, 2011 | Xerox WorkCentre 4150 Black and White...
My workcentre 4150 is on my network and sometimes
Check and see if your using the PS driver for that machine, If so switch to the PCL driver. The PS one has been known to run slow.
Mar 22, 2010 | Xerox WorkCentre 4150/C All-In-One Laser...
Xerox WorkCentre 4150 Error code: 20-800/The machine cannot save the fax settings to memory. Xerox service is required to inspect the backup battery. Faxing is disabled, printing and all other machines...
One of 2 things.
EIther you have to enter the Fax User memory, Or the memory battery has failed and needs replaced.
Here is what the service documentation says.
(4150) During a power-off period, the machine has lost its user memory. Check that the backup battery, PL 1.10 Item 5 is holding its charge of about +3V. If necessary, install a new battery, PL 1.10 Item 5.
Dec 17, 2009 | Xerox WorkCentre 4150 Black and White...
Xerox WorkCentre 4150, 3 vertical white lines in all feeder scans
the problem is in the scanner, open it up and see if you can find any smudges, and clean any obstruction, any ink, liquid eraser residuals, can cause this part to appear as lines on your copied faxed image.
dont concentrate on the printer this is a scanner problem
Jul 28, 2009 | Xerox WorkCentre 4150/X Laser Printer
Xerox 4150 Multifunction Printer
From my expreiences with that product, you should reload the machine software.
If the machine is less than one year old call for service it is under warranty.
If not you can go to www.xerox.com and download the firmware,10.100.32.000.
It will resolve many software issues on that product.
You can download it to your computter then upload it to your machine.
Some of the versions of software on that product have some issues. Most are resolved with that version.
You will also need to download the 4150 printer setting utilities if you are going to do this yourself.
You may lose your LDAP settings, so be sure you print out a settings or configuration page before you do the upgrade.
Feb 25, 2008 | Xerox WorkCentre 4150 All-In-One Laser...
Xerox WorkCentre  4150 All-In-One Laser Printer Logo
432 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
