Question about Olevia LT37HVS 37 in. LCD HDTV
37" broke - need help
My 37" went out - completely blank no sound or etc. I need some advice please.
    Problem Solver:
  • 7 Answers
After taking the screws out and removing the back, you will see a power supply(where master switch and cord connector are). Remove the 4 screws on the aluminum cover plate to gain access to the fuse. Using a voltmeter, with the power on and switch on, measure the voltage on each side of the round fuse located just behind the cord connector. If voltage is 0, fuse is good. If voltage between 115 and 125 V, replace fuse or have fuse replaced. I think it is a 6.3Ah 250V class fuse that is soldered into the board. IF YOU ARE NOT FAMILIAR WITH SOLDERING TECHNIQUES AND PRECAUTIONS, DO NOT ATTEMPT TO DO THIS. IF YOU ARE NOT FULLY AWARE OF ALL SAFETY PRECAUTIONS NECESSARY TO MAKE THIS REPAIR HAVE A QUALIFIED TECHNICIAN DO IT FOR YOU!!!!!!
If a new power supply is needed, contact these people for repair with 1 year warranty.
http://www.power-supply-repair.com/
please rate solution
Posted on Apr 07, 2009
    Sergeant:
    Champion:
  • 289 Answers
Hi..the reason to this problem is your
power supply might have got failed.
check whether any power is coming
from the supply.This might be the
problem in your tv.
check it out..
thank u..
rate me..
Posted on Feb 11, 2009
My Philips HTS3566D home theater stereo system speakers do not work. Sound comes from the tv, but not from the speakers that came with the Philips unit. I've tried different modes (party, dolby, etc.)...
I have the same problem. The front right and left chanels are fucked up while the center and rear right and left are working normally. I can't imagine what's the problem.
Sep 04, 2010 | Philips HTS3566D/37 Theater System
My phone screen went blank after dropping in the toilet
You should have left it dry instead of turning it on, you probably have corrosion now, find a local place that works on phones to see if they'd work on it.
If you want to try to completely dry it, put it in rice for 24 hours minimum to draw out all moisture.
Aug 03, 2017 | Motorola Mobility RAZR V3
Static shock when we turn tv off and it went blank
Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Nov 15, 2009 | Akai LCT3285TA 32 in. LCD Television
Acer Aspire 5100 new screen and still goes blank.
ACER PICTURE PROBLEM – MY SOLUTION
I had a similar problem, but I got a picture before it broke up and went off. The screen was backlit, but no video (screen was receiving some power).
The LCD needs a very stable voltage to work, this is provided through the LCD connector ribbon. In my case the ribbon was damaged and replaced it.
I have had no problem since.
I discovered this through trial and error; I first changed my transformer power supply and then the video inverter card.
You may find the link below helpful as it contains articles that photographically show you how to open the laptop for repairs.
http://www.insidemylaptop.com/category/1-acer-laptops/
Hope this helps. (Please rate my advice)
Jan 25, 2009 | Acer Aspire 5100 Notebook
JVC LCD TV Screen is Blank but TV Still turned on
if you are getting sound, then chances are its the back light.
Replaceing the back light will cost about $400 but who knows i may be wrong, you need to explain your situation a little more vividly :)
Jan 01, 2009 | JVC LT-37X776 37 in. LCD HDTV
I have a philips 30pw9100/37. i was watching tv when it went blank. now, whenever i turn it on or do anything, i hear a beeping sound coming out of the back of the tv. please help!
it needs to be repair, maybe the zener diode of that was shorted or the horizontal out Transistor. the cause is lose contact of other companents...
janex
Apr 23, 2008 | Televison & Video
Blank Screen No Audio
Ur main video backlight board is dead,must be replace.Try this website,Shopjimmy.com buy the board for $163,replaced it ur tv will work again.
Feb 09, 2008 | Sharp LC37SH20U 37 in. LCD Television
LG VX8600 SCREEN WENT BLANK, PLZ HELP!!!
m8 sounds like your screen is faulty or your ribbon has been damaged in some way.to fix it you will need to open it and have a look at the ribbon if there is any damage vissible no matter how small it means ur ribbon is gone an you need a new 1.it could also be your screen if there isnt any damage on the ribbon then it could be the screen.it could be a combination of both. word of caution: if you try to open it yourself you could damage the ribbon.you wont notice it but its very easy to do.so be carefull. but if you want an expert to do it for try these guys http://www.mobilephoneservicecentre.co.uk/ good luck
Jun 18, 2007 | LG CHOCOLATE VX8500 Cellular Phone
Sound but blank white screen
Hello, please contact your Philips Dealer ASAP. If you need more info please advice. Best regards, Arpi
Apr 19, 2007 | Philips 15MF605T 15 in. LCD Television
Olevia LT37HVS 37 in. LCD HDTV Logo
358 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
