Question about Olympus MJU 300 Digital Camera
MJU 300 battery charged .slide open no power
After the last time i recharged it . when i fitted it Led's flashed then .it failed to power up when slider was opened
    President:
  • 919 Answers
This may be a repair issue with the sensor that is located behind the front sliding lens cover. You may want to call Olympus Customer Service to discuss repair policies and procedures. Their telephone number is 800-622-6372 option 2 and then option 3
Posted on Feb 11, 2009
AA battery recharger is flashing red
All I can see is that your charger is flashing red. There wasn't any brand mentioned. Most battery chargers flash green when in charging mode, solid green when charging is complete and flashing red when there is an issue with the battery/batteries being charged. Rechargeable batteries don't last forever (usually 200-300 charges) and perhaps this is the case with yours. Also, if you are using imported batteries (China), that would be a major red flag!
Aug 15, 2014 | Electronics - Others
The battery wont charge for my lt2802u
POWER SUPPLY & BATTERY PROBLEM
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods. When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Apr 16, 2013 | Gateway Lt2802u Laptop/notebook
Battery operate for 3 minutes and then no last more
If the MP3 player battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Apr 09, 2013 | Audio Players & Recorders
Power problem
Apr 09, 2013 | Compaq Computers & Internet
How to fix hp dv2000 power problem
Jan 12, 2013 | HP Pavilion dv2000t Notebook
No charging battery
Nov 01, 2012 | Computers & Internet
Have had to replace the backup battery in the opener 3 times in the last year. What could be draining the battery?
Here is some general information that you probably already have. The opener should keep that battery charged. I would recommend getting a service technician out. Just when you really need that battery backup it will be out.
On top of your unit is a battery pack with three colored led lights. You can tell what is going on by looking at these. This information is in your manual or here it is. GREEN LED: All systems are normal. A solid LED light indicates the batteries are fully charged. A flashing LED indicates the batteries are being charged. NOTE: Batteries do not have to be fully charged to operate the motor unit. YELLOW LED: The motor unit has lost power and is operating off of the BBU. A solid LED with beep, sounding approximately every 2 seconds, indicates the motor unit is activating the door and is operating off of the BBU. A flashing LED with beep, sounding every 30 seconds, indicates batteries are low. Once the power is restored the BBU will recharge. This is indicated by a flashing GREEN LED. RED LED: An error has been detected and the BBU will automatically shut off. The BBU will attempt to restart by reconnecting to the batteries. If the error is still present it will shut itself off again. This process will repeat every 5 minutes or until the error has been resolved. This is used to prevent further draining of the batteries. If a red LED remains on when the power is restored, and is accompanied by a beep sounding every 30 seconds, please call for service.
Jun 28, 2011 | Sears Craftsman LiftMaster Chamberlain...
My latitude c640 batter do not charge green and yellow light flash when ac plug in
The flashing LED is indicative of a failed battery. The battery for a protable system has a expected lifespan of 300 to 500 discharge recharge cycles, then will eventually fail. If you haven't replaced the battery that is the next step. If the battery has been replaced with a NEW battery and still doesn't charge, then the motherboard would need replacement.
Nov 03, 2009 | Dell Latitude C640 Notebook
Latitude d505 not charging
If the system runs using the AC adapter, but the battery doesn't hold a charge and the battery indicator LED flashes orange, then replace the battery (A battery with an internal failure may flash 4 times orange then once green and repeat)
The normal lifespan of a PC battery is 300 to 500 recharge/discharge cycles (roughly 12 to 18 months)
Jan 31, 2009 | Computers & Internet
Olympus MJU 300 Digital Camera Logo
241 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
