Question about HHP Alternator/Battery Tester - 125 Amp Load Hand Held
Car hesitation while driving
Can feel a hesitation in the car while driving, at one point the radio went off, and one point the battery light flickered on and off.
  • 33 Answers
Without knowing more about your problem it's hard to say what the problem is. However the fact that the radio went off and the battery light is coming on would indicate an electrical failure.
Have you checked the alternator? Also, your alternator may be fine, but the leads that connect it to the battery can become corroded and cause a poor connection. I experienced this exact issue on a 2002 Chevy Grand Vitara, the lead connections on the back of the alternator just had to be cleaned.
Posted on Feb 11, 2009
Why does my 1991 sl500 Mercedes Benz radio say code
generally is an battery problem low voltage , check the battery
Jun 11, 2017 | 1991 Mercedes-Benz Mercedes Benz 500 Class
Well test the alternator first. I should think you can do that with a simple voltmeter. It should read between 12 to 14 volts. Only answer I can supply, sorry.
Jun 06, 2013 | 1993 Lincoln Town Car
I own a 1995 ford explorer and just put new tires on it. after driver roughly 30 miles the od light started to flash adn the transmission feels like it is hesitant to shift up. when driving, i have to let...
When was last time trans fluid & filter were changed? Should be done every 30k or 3years - sooner of you do any towing. Have it flushed also when doing the filter change.
Apr 04, 2011 | 1995 Ford Explorer
Turned key..nothing happened, dead, no dash lights interior lights or mileage, released hood button, dash instruments came on, turned key car started..while driving radio goes on and off as well as the...
Check ALL Power and Ground connections coming off the Battery to circuit anchor points. Ignition and Services fuses for a Power supply. If all proves ok, then go to the Main Ignition control Relay and check the condition of the Pins and Recepticles. That is where your apparent problem may eventually be. But travel the initial route first, looking and feeling for Loose or Dirty connecting points.
Regards, David
Nov 28, 2010 | 2006 Chrysler Sebring
2004 Freestar-In Jan. it just started hesitating and it would not get over 30 mph. I had it towed to the dealer and they could not find problem. I picked it up and it ran good. I noticed the radio had lost...
Take van to reputable Ford dealer and have them hook it up to computer and check for any codes.
The vehicle computer might have to be reset for the egr system.What they did was disconnect your battery for the quicki reset for vehicle, thats why your radio had reset.
Mar 28, 2010 | 2004 Ford Freestar
Car dies intermittently
THIS ONE IS EASY. CHECK YOUR BATTERY TERMINALS AND CABLES THAT THEY ARE TIGHT. IF THEY ARE, YOUR BATTERY MAY NEED CHARGING OR YOUR ALTERNATOR IS NOT CHARGING YOUR SYSTEM THAT WELL. I WOULDNT DRIVE LONG DISTANCES UNLESS I HAD THAT CHECKED.
Jun 17, 2009 | 1998 Nissan Altima
96 JEEP Gr Cherokee hesitates, surges, later stalls
You might want to start by replacing the crank sensor first.
Nov 24, 2008 | 1993 Jeep Grand Cherokee
Down to the point.
First check the battery voltage if its less than recommend voltage then its the battery ,try jump starting the car if its works then you need replace its battery ....
Good luck...
Aug 26, 2008 | 1994 Chevrolet Cavalier
HHP Alternator/Battery Tester - 125 Amp Load Hand Held Logo
136 people viewed this question
Top HHP Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a HHP Measuring Tool and Sensor Expert? Answer questions, earn points and help others
