Question about HP Officejet 9110 All-In-One InkJet Printer
New color cartridges, poor color, mostly all "pink"
Printer has new cartirdges, but color quality is poor. Its like the blue and yellow are not there!
  • Anonymous Mar 09, 2009
    my ink only shows pink and the other colors arent there
Looking for diagram for dayton chain saw model2z760 is there a site on line to get the diagram for the carbureto
Posted on Feb 11, 2009
The color of my print is very pink and yellow with no blue
If your printer has 3 colored ink cartridges, your cyan (blue) cartridge is empty. Replace it with a new one. If your printer has just one colored ink cartridge, the blue section of it is empty. Replace the cartridge with a new one. You'll find the correct cartridge (normally a number) in the owners manual and/or on the cartridge itself. See the owners manual for instructions on where the cartridges are located and how to replace them.
Oct 12, 2014 | HP Photosmart C6180 All-In-One InkJet...
Www kodak com go support
It might be a matter of cleaning the printer heads and seeing if it makes a difference. See page 34 of the manual available at this site.
http://resources.kodak.com/support/pdf/en/manuals/urg01093/ESP3200Series_XUG_GLB_en.pdf
Aug 07, 2014 | Kodak Esp 3250 All-in-one Inkjet Printer
The blue color is not printing correctly. It comes out sort of pink and greens are yellow. I have a new balck drum. I have put in a new blue toner cartridge. I have tried adjusting color saturation. ...
create a doccument with four identical lines of text.
the text should be as follows:
your text in the colour Black, the cyan, then yellow then magentta
see if they print in the colours you used, if they are all wrong then delete all drivers associated with the printer and delete the printer, then follow the install proceedure again to reinstall, if just one colour is wrong the it is most likely a deffective cartridge.
Dec 06, 2013 | OKI C5100n Laser Printer
I have an HP Phototsmart C4280 that is printing everything in pink. Any idea why?
This is the cartridge color problem, if you've refilled the cartridge, there must be proportion problem (magenta/yellow/cyan), or if you print dark colors like green or blue (which uses cyan and yellow mostly) and never use the red or other color (magenta and black), cyan and yellow might have finished up. If you can refill it proportionately, go ahead, but i would suggest you to purchase new cartridges and install.
Good luck. Thanks for using FixYa.
Jun 04, 2010 | HP PhotoSmart C4280 Laser Printer
Printer won't print yellow
Either theyellow is finished or the nozzles are blocked. Try cleaningthe nozzles of the cartridge.
May 26, 2009 | HP PSC 2175 All-In-One InkJet Printer
Printer S400 won't print out blue and pink ink
Hi..
The nozzles have gone bad...it needs to be serviced or replaced...i appreciate your efforts yoy put in to fix the problem thats best we can do after all its a machine.if the printer is in warranty contact the manufacturer.
Regards,
debroy
Nov 25, 2008 | Canon S400 InkJet Printer
Despite installing new cartridges,cleaning and priming, my HP Deskjet 710C prints pink only. Using Windows XP test page shows no blue, or yellow.
hi,
do you installing both cartridges (black and colour)?
if you do so, my advice is to reinstall the driver for your printer.
if you install ONLY the black cartridge, and the color cartridge remain the old one, (which in my opinion is the present case), your problem is from the color cartridge.
The color cartridge have 3 colors and this are: cyan (some kind of blue), yellow and magenta (similar with a pink color, but more intense). The problem is simple: in your color cartridge has left only the magenta color, cyan and yellow tanks are empty.
have 2 options:
1. buy a new color cartridge
2. refill the color cartridge.
Sep 23, 2008 | HP Office Equipment & Supplies
Pink teal lime
the printer cartridges have the ink Blue (light blue), red (pink) and yellow (lime).I think your printer printing fine do not worry all the printer have same ink........If you have the problem with color on print outs :you this link ::
http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:549:0:0&framed=&docid=ENUS25128&relevance=1
Mar 17, 2008 | Lexmark X5470 All-In-One InkJet Printer
Washed-out color.
Looks like you need some printer profiling...
Washed out prints can be caused by several things... Let's see if we can sort it out.
It could be your printer, or it could be your monitor giving you false readings.
Printer Profiles: If you do not have the correct printer profile, then your prints may turn out faded. This is a gamma thing. You are encouraged to calibrate your monitor, and go to the printer manufacturer web site and look up your printer to see if they offer the correct RGB and CYMK printer profile.
Poor quality paper: most likely the problem is a poor quality paper. You did not indicate what printer and what paper you are using, so we cannot help much. However, try a sheet of the high quality photo paper and see if the colors print more vivid and saturated.
If the above doesn't help, I suggest you find someone else with a different printer who is willing to bring it over and print from your computer. That will proof the printer either in or out of the equation.
If none of this helps let us know and we'll walk you through the creation of a custom printer profile and custom color space.
Nov 24, 2007 | Lexmark X1150 All-In-One InkJet Printer
HP Officejet 9110 All-In-One InkJet Printer Logo
171 people viewed this question
Ben Johnson
